#1 |
Member#: 54698
Vehicle:1997 Legacy GT red |
Ok , here it is...
The idle on my 97 Legacy GT 2.5 DOHC (125 000 KM) stays at about 1800 rpms. Out of the blue , no idea what it can be. Yesterday i changed my oil like i did a hundred time , took a little run around the block , everything was peachy. Today , take my car to go the store , out of the blue , idle wont get down from 1800 rpms. Nothing happend , no idea. The only thing is that i changed from synthetic oil 10w30 to normal Valvoline oil 10w30 , used the exact same brand and model of oil filter. I noticed that my engine "knock" is getting louder , that's why i'm looking into completly changing it. Anyone has an idea what it could be?
#2 |
Member#: 71203
Vehicle:2005 2.5rs Crystal Gray Metallic |
When you get in your car, give it a few good revs before you get goin, it should drop down below to 1000 w/ ac on and maybe lower without ac on. but if it doesn't drop then i don't know.
#3 |
Member#: 54698
It's close to freezing point now here in Montreal ! , no need for a/c !..
And this problem is not at a cold start , it is when i have been driving for a long time and the engine is at running temp. Still no clue. |
#4 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
idle air control valve could be sticking open a bit. Unfortunatly its a very expesnsive part to guess at.
Jay |
#5 |
Member#: 32846
Vehicle:1998 Impreza L-SOLD Arcadia Green |
Try cleaning your IAC valve with alcohol or throttle body cleaner. I've used both recently on my mother's car. It fixed the problem for a week, and then the surging came back again. On the 3rd try, I used WD-40, which is a good cleaner and decent, at best, lubricator. Problem fixed.
-Charles- |
| Thread Tools | |
| Display Modes | |
| 2.0-2.5 swap problems, STARTER & FUEL INJECTOR STUCK ON??? | aarongivey | Factory 2.0L Turbo Powertrain | 2 | 07-31-2010 02:16 AM |
| Help on a 2.5 idle issue | Morningriders | Legacy Forum | 2 | 12-02-2004 09:09 AM |
| 2.5 Backfire problem | Cooljo2.5rs | Normally Aspirated Powertrain | 10 | 04-29-2004 06:02 PM |
| 99 2.5 idle prob | garret | Normally Aspirated Powertrain | 0 | 09-17-2003 09:17 PM |
| '04 STI 2.5 motor problems??? | alfriedesq | STi Forum Archive | 5 | 01-19-2003 02:18 AM |
