Old 06-24-2001, 11:19 PM   #1
roadsclr
Member#: 2478
Question Replacing Fuel Filter
Hi all,
I have a '00 RS w/ 30Kmiles on it. I'm planning on replacing the plugs, air & fuel filters this weekend. I think the plugs and air filter should be relatively easy. My only concern is the fuel filter. Does anyone have any tips on changing it? Do you need to first pull the fuel pump fuse while the engine is running to minimize the amount of fuel in the lines/filter? Any pointers would be greatly appreciated.
Thanks,
Jeff
roadsclr is offline   Reply With Quote
Old 06-24-2001, 11:38 PM   #2
richeich
Member#: 1353
2001 Impreza 2.5RS
I'm sure there's an official method to do it, but I just did mine first thing in the morning, after it sat all night. Cold engine, no fuel pressure, no problem. Just took the lines loose, and put the new one in.
Good luck-
Rich
richeich is offline   Reply With Quote
Old 06-24-2001, 11:42 PM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Pulling the fuse greatly helps to reduce fuel spillage.
I've always hated working on fuel lines in the engine compartment, as the heat tends to harden up the fuel hoses. They can be very difficult to remove from the fuel filter barbs, so be careful not damage the hoses. I had to cut one of mine off and replace the hose, since it was on so tight.
When you're ready to start the car up again, turn the key from Off to Ignition several times to help prime the fuel system, with a few seconds pause between each step. Mine took about 3 times before fuel pressure built up to 30+ psi. It's not entirely necessary, but it's better than waiting a second or more longer for the fuel lines fill back up again while cranking.
-WaC
Wayne
Edit: removed option.
wac is offline   Reply With Quote
Old 06-25-2001, 09:17 AM   #4
roadsclr
Member#: 2478
Default Thanks
Thanks for your advise!
Old 06-25-2001, 03:40 PM   #5
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
If you let the car sit overnight, there's no need to pull the fuse and run the car. There is very little pressure in the fuel lines, at that point.
It's very simple to do, just unclip it and remove/reconnect the hoses. The filter is still full of fuel, though, so watch that.
Plugs can actually be pretty tricky, just because of their location. Take a look and make sure you have the proper tools before you get started.
gavin is offline   Reply With Quote
Old 06-26-2001, 10:21 PM   #6
roadsclr
Member#: 2478
Default Thanks
Thanks Gavin for your reply. Good information.
Old 06-27-2001, 12:20 AM   #7
jjimpreza
Member#: 1269
2000 RS to WRX
to Forester to LGT to GF8
I just replaced my fuel filter and plugs too, I have 30K on MY00. Let me tell you the fuel filter is a breeze and these are good tips your getting.
Now the pain in the azz I thought was the plugs. I had to buy an extension because the plugs are so deep in the heads(no big deal rightbut thats not it.) It is pretty tight on the back plugs. I had to pull the wiper box out to get to the plug. You might want to look for some pointers on the plugs. I found them to be the real task.
Fuel filter=Cake walk
Plugs= bloody knukles
JB
jjimpreza is offline   Reply With Quote
Old 06-27-2001, 04:59 PM   #8
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
It's pretty much standard proceedure to pull the washer fluid reservior out for the spark plug change. Two little screws and the pump plug, not really a huge task. On the MY99, you have to remove the top of the stock airbox and panel filter also.
Be prepared to spill a few drops of gas on the fuel filter change. The filter itself will be full of gas. Just have a rag handy and use the caps from the new filter to plug the old inlet tubes as you do it, one tube at a time. That should minimize the spillage. Fuel filter change takes about 15 minutes if that. Make sure the key is not in the ignition, or you have the fuse pulled. And don't smoke when you do it (DUH!)
Fred
PS- don't forget anti-sieze and dielectric grease for the new plugs.
Fred Zaplitny is offline   Reply With Quote
Old 06-27-2001, 11:25 PM   #9
roadsclr
Member#: 2478
Default Thanks All
Thanks everyone for your tips! Much appreciated.
Old 06-28-2001, 10:51 AM   #10
travman733
Member#: 5649
2002 WRX wgn bl stg2
(sold)'93 Impreza L Sedan
Woa...I didn't realize the fuel filter was so easy to change. I always change my spark plugs and didn't think it was all that bad.
travman733 is offline   Reply With Quote
Old 06-28-2001, 10:37 PM   #11
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Cool
I didn't even know where the fuel filter was when I bought the replacement. When I saw where it was eeeeeeeeaaaaasy!
Spark plugs were a snap too, I was used to jacking up the car and going in through the wheel wells on my old Chevy's!
Old 06-28-2001, 10:51 PM   #12
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
Um, what do ya have to remove to get at the plugs?(washer bottle, etc.?????)
imprezadan is offline   Reply With Quote
Old 06-29-2001, 12:13 PM   #13
Dozza
Member#: 5868
2005 Baja Turbo, ABP
'07 Outback, NBP
Pretty good info here!!!
I'll be doing my 30K work next week on my MY99 OBS. Couple of questions though, assuming you picked a Subaru fuel filter; how much was it and did you get it from the dealer or somewhere cheaper? Also, just where is the location of the fuel filter? I'm betting that there isn't much difference btw the 2.2L and the 2.5L location.
Thanks folks!!
-Glenn
Dozza is offline   Reply With Quote
Old 06-29-2001, 12:18 PM   #14
Dozza
Member#: 5868
'07 Outback, NBP
imprezadan- pretty much all you need to remove is the washer fluid resevior. Though I haven't gotten around to changing the plugs yet (everyone around here is out of the NGKs
Check out www.azscooby.com and goto the mods section for the impreza. There are instructions as what needs to be done.
Hope this helps.
-Glenn
Old 06-29-2001, 03:06 PM   #15
Dozza
Member#: 5868
'07 Outback, NBP
Anyone? Please, help with the location of the fuel filter....
-Glenn
Old 06-29-2001, 03:10 PM   #16
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
on the 2.5, the fuel filter is right next to the windshield washer fluid reservoir. it's a silver can-shaped thing, about 3 inches tall with 2 bent pieces sticking out the top.
roger
froggert is offline   Reply With Quote
Old 06-29-2001, 03:38 PM   #17
Dozza
Member#: 5868
'07 Outback, NBP
Thanks Roger!!
I took a gander and there it is right in front of may face; it looks like easy would be an understatement. It's right where you pointed it out. Only thing was that it's a black canister.
Thanks again for the info, off to Pep Boys!!
-Glenn
replacing fuel filter in 2002 2.5 liter OBS rogeryung Service & Maintenance 5 05-20-2003 03:41 PM
How to replace fuel filter and PCV Valve? H5N1 Service & Maintenance 3 09-26-2002 05:25 AM
replacing fuel filter Blindeye_03 Normally Aspirated Powertrain 12 05-24-2002 01:39 AM
Best way to replace fuel filter WRXVII Service & Maintenance 4 05-11-2002 06:35 PM
