Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-24-2001, 10:35 PM   #1
Jaemmo
Member#: 5574
16 WRX
Angry What's the max boost showing on your factory gauge pack for WRX?
Just got my factory gauge pack installed on my WRX, and holy sh#@!! It's only showing .045mpa max which is like 7psi!
Is the gauge calibrated wrong? Or am I only getting half the boost I'm supposed to be getting? Does the ECU limit the boost until car's reached a certain milage? Or did the dealer screw the install? What reading are you guys getting? I do get up to -.09mpa of negative vacuum, -.07mpa at idle.
Another thing. Like others, the boost gauge only lights up only half as bright as the other two. Plus, the oil temp is on the right and volts in center. Isn't these two supposed be other way around?
Jaemmo is offline   Reply With Quote
Old 06-24-2001, 11:13 PM   #2
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
As I understand, first gear is limited to around 7psi, so give it a shot at WOT in 3rd in the mid-RPM range (it tapers off near redline too).
Thats the whole reason a lot of people put boost controllers on the WRX's... not to give it more peak boost, but to even out the boost that it does get.
Redline8k is offline   Reply With Quote
Old 06-24-2001, 11:34 PM   #3
Rexy
Member#: 5811
...just make sure your gauge reads 0 with the engine off
Rexy is offline   Reply With Quote
Old 06-25-2001, 07:24 AM   #4
AndyHidley
Member#: 1031
Default AndyHidley
My MAX is .1.. Car is stock
AndyHidley is offline   Reply With Quote
Old 06-25-2001, 08:23 AM   #5
OnceAgain
Member#: 7354
2002 WRX Wagon
I have a Blitz guage that reads just under .1 Kpa max, with only about half that in first.....
OnceAgain is offline   Reply With Quote
Old 06-25-2001, 12:53 PM   #6
NJ WRX
Member#: 6929
02 Impreza WRX
Free boost?
I here if you cut of the vacuum with a cotter pin or something it will run at max all the time.
true?
NJ WRX is offline   Reply With Quote
Old 08-11-2001, 02:08 PM   #7
Fubaru
Member#: 6046
'08 Prius
I see about 1.2 kg/cm2 or about 17psi peak pressure
This is during pretty hard acceleration but not WOT
Usually it's about 15psi peak. I hope my engine doesn't blow up.
Fubaru is offline   Reply With Quote
Old 08-13-2001, 10:11 AM   #8
NJ WRX
Member#: 6929
02 Impreza WRX
Fubaru,
RUN THAT THING!!
You should be fine....are you still running the stock turbo?..all the computers that are coming out raise the boost to 15-17psi, so i wouldnt worry.
NICK
Old 08-13-2001, 03:29 PM   #9
deadbolt
Member#: 990
96 Brighton and...
many
Rexy, actually if your factory gauge is setting at 0 with the engine off you have problems.
deadbolt is offline   Reply With Quote
Old 08-13-2001, 03:50 PM   #10
hkwan
Member#: 7536
2005 WRX STi
Deadbolt,
would you please elaborate a little bit? I believe all the meters should be showing "0" when the engine is off - no vacuum nor boost when engine is off, correct?
hkwan is offline   Reply With Quote
Old 08-13-2001, 03:52 PM   #11
bdowell
Member#: 7524
2002 WRX Sedan
Platinum Silver
Why's that deadbolt? It has neither boost or vacuum with the engine off, so what else should it say besides 0?
bdowell is offline   Reply With Quote
Old 08-13-2001, 07:00 PM   #12
dannyboy7
Member#: 5432
2006 Spec Beezie
Well, I have had the factory gauges since i got the car(12000 miles now, and when it was bone stock, boost would go just below 1 bar in 2nd, 3rd...etc, meaning it was showing correct boost, but when the car is off, it reads a little below zero, is this correct? OH man, I hope I am not running like 17 psi or something, cause with the ebc, I am running 1 bar, so hopefully its calibrated correctly. Deadbolt, i would also like to learn your wisdom.
dannyboy7 is offline   Reply With Quote
Old 08-14-2001, 01:40 AM   #13
Jaemmo
Member#: 5574
16 WRX
I also first noticed that mine sits slightly below '0' when off. BUT if you lower your head so that the gauge is eye-level, the needle sits between the 0 mark.
BTW, turns out you gotta floor it to get max boost in stock form. Since I was breaking it in, I was babying it and only going 2/3 WOT. Stock turbo is not responsive at all. It only 'wakes up' at WOT. Boost controller fixed all that, of course. But I remember only getting .09mpa which is like only 13psi during post-breakin WOT runs.
Old 08-14-2001, 02:23 AM   #14
Rexy
Member#: 5811
Thanks Deadbolt...I know already because I installed my gauge pack and noticed what the booklet said. SOA tried to say that it was normal. I sent them the page from the manual and told them I was calling them on their BS.
cheapest place to get the spt gauge pack for wrx? japspecjohn Newbies & FAQs 10 10-06-2009 04:36 PM
Would you get the Subaru symbol tattooed on your genitalia in exchange for... Asinine Off-Topic 33 04-27-2005 01:02 PM
WTT factory gauge pack for clock and $$ blkbdrx Private 'Wanted' Classifieds 2 01-12-2004 04:48 AM
Urgent Help on the factory gauge pack installation V6 Interior & Exterior Modification 4 12-07-2000 04:00 PM
Urgent help on the factory gauge pack installation V6 Car Audio, Video & Security 4 12-06-2000 10:45 PM
