Old 10-25-2004, 11:58 PM   #1
MO REX
Member#: 52583
2002 WRX sedan
Default Cobb stage 2 target boost question
I have a 02 WRX, Accessport stage 2, stock restrictor, STI pannel filter, STI upipe, TXS DP, TXS midpipe with cat and a Blitz Nur-Spec R catback with the silencer.
When I first flashed stage 2 I was hitting target boost then after some learning boost decreased to around 14.5 psi so I went with the HWG map and the same thing happend. Now I adjusted the WGA 2 turns (without the HWG map) and I'm hitting target again and the car feels stronger but boost will fluctuate + or - .5 psi but never go over 16 psi. I'm prety sure this is not considerd a boost spike since it is not overboosting but I just wanted to make sure. I did some searches and couldnt find the answer I was looking for and I was hopeing someone could give me the definition of boost spike. Is it only a spike if you overboost or is it considered a spike when you fluctuate a certain amount (1psi or what)?
I am also wondering why my boost is decreasing after the ecu does some learning. Is it because the car is knocking (cant hear knock) or what?
Thanks
MO REX is offline   Reply With Quote
Old 10-26-2004, 12:49 PM   #2
Alizarin
Member#: 53769
2004 WRX JDM STi v8
IAM = 0 FTL :(
I just got my stage 2 up and running on Saturday. At first it was hitting target boost, and then on Sunday afternoon it was only hitting 14.5 like you said. On Sunday night it was back to 15.5. I am only assuming it was heat soak or just a hot day or something since it came back once I got moving on the way home.
Alizarin is offline   Reply With Quote
Old 10-26-2004, 12:54 PM   #3
03WREX
Member#: 38932
2003 WRX
WRB - Cobb Stg2
I've been stage 2 for a few months now and I'm seeing boost at about 15.5 - 16psi. I believe thats normal. Are you getting your readings from a boost gauge or are you getting it directly from the accessport? I would assuem the accessport is more accurate.
Also, have you tried the revised stage2 map? I believe this is different than the HWG map.
03WREX is offline   Reply With Quote
Old 10-26-2004, 05:56 PM   #4
MO REX
Member#: 52583
2002 WRX sedan
I have taken readings from the accessport and my boost gauge at the same time and my gauge is pretty close to the reading on the AP.
I have only tried the revised HWG map and I would think it is the same as the revised stage 2 with the exception of the waste gate duty.
Old 10-26-2004, 06:03 PM   #5
MO REX
Member#: 52583
2002 WRX sedan
When I first did the flash and hit target boost it was around 75 degrees and fairly humid. By the time my ecu had time to learn and I was only hitting 14.5 psi the temp had droped to 50 degrees with little to no hunidity and my IC definately wasnt heat soaked. I have a feeling the ecu is detecting knock and is decreaseing boost to take care of it.
Old 10-26-2004, 06:31 PM   #6
rex-machine
Member#: 18811
2002 Rex
What gear are you testing your boost in. I think boost for 1-2-3 is not full 15.8. I think only 4th and 5th are supposed to get 15.8.
rex-machine is offline   Reply With Quote
Old 10-26-2004, 07:20 PM   #7
MO REX
Member#: 52583
2002 WRX sedan
3rd - 5th.
Old 10-27-2004, 02:22 PM   #8
CFar
Member#: 51896
16 WRX
You know Ive got a similar if not the same problem. I dont know if its a problem though.
If I pussyfoot around town for a day or so, and go to full throttle all of a sudden all Ill see is about .9 bar. Usually goes away after one or two full throttle runs through most of fourth, I see full boost through 3rd-5th. Even 2nd sees almost full boost.
I hope its not knocking. I dont hear any that I know of (unless the scratching noise at partial throttle is detonation). I dont think it was because I changed maps to valet and it did the same thing.
Any more insight from someone that knows about Cobbs programming.
CFar is offline   Reply With Quote
Old 10-27-2004, 02:59 PM   #9
Alizarin
Member#: 53769
2004 WRX JDM STi v8
IAM = 0 FTL :(
I get kind of a metallic scratching/tapping noise between 3-4k, so I think its wastegate flutter. Doesn't sound like det... I hope so at least, because the ECU doesn't pull power even when accelerating "slowly" (read: about half throttle).
Cobb Stage 2 (ACN91) Boost level question sd 05 sti AccessPort 7 07-03-2008 08:35 PM
stage 2 target boost? smr_wrx AccessPort 2 03-18-2007 01:19 PM
stage 2 target boost? Predator3 Engine Management & Tuning 34 06-23-2005 05:22 PM
Cobb Stage 2.5 boost question WRexxer Engine Management & Tuning 4 06-17-2005 09:22 PM
Cobb stage 2 target boost Soob02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-16-2005 01:31 PM
