Old 06-24-2001, 11:32 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Can you just use zip ties for spats (GC8)?
I was wondering if you could put the screw into the part that is closest to the tire and then just tighten 3 zip ties to hold on the rest of the spat. I was also thinking, can I just put in the screw near the tire and then 1 zip tie the part closest to the liscense plate skipping the middle two mounts. This way would only require one hole be drilled for each spat. Do you think either way would be sturdy enough. Will there be a threat of the ties melting or breaking? Any ideas or cautions would be greatly appreciated. Thanks.
garface is offline   Reply With Quote
Old 06-25-2001, 08:05 AM   #2
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
I put all the screws in except the one closest to the licsence plate. The supplied hardware doesn't really even work. For that I used a zip tie, with the metal bracket removed. You still need to drill a hole for the zip tie to go through, but the zip tie allows you to pull the spat end tight to the bumper. All zip ties might work al well but you might get some saging/movement in the middle part of the spat. The screws in that area work and fit fine, so use 'em. It is hard, from an emotional stand point, drilling holes in the bumper, but it's all for the best.
Bob
Bob O is offline   Reply With Quote
Old 06-26-2001, 12:03 AM   #3
garface
Member#: 1581
MY00 RS/STi7
If you bump it, they will come.
Old 06-26-2001, 03:53 AM   #4
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
You can zip tie the end closest to the license palte, but the other attachment points should be screwed in. It isn't that hard and I am going to try a new technique when I do my third set in a few days. If it works better I will post it on http://www.scoobymods.com The current technique I have used is listed on the site now.
Aaron
AaronB is offline   Reply With Quote
Old 06-26-2001, 03:59 PM   #5
garface
Member#: 1581
MY00 RS/STi7
Do you mind explaining briefly the new technique?
Old 06-26-2001, 09:38 PM   #6
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Garface ,, like the others said use the screws fr all but the ones closest to the liscence plate,use zip ties there.Took me and my son about an hour fr both.And yes you have to drill holes in the bumper,who cares your gonna cover the holes anyway.
My two centavos
Rudy
jagcars26 is offline   Reply With Quote
Just got unmarried 04 AP, can i just use it? o2sys AccessPort 5 04-23-2006 10:31 AM
ALWAYS USE ZIP TIES OR HOSE CLAMPS on VAC Lines redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-30-2002 09:58 AM
How much horsepower can you really use in a non-tarmac rally? Gravel-Fun Motorsports 12 07-18-2002 02:18 AM
Air silencer removal: can you just remove it? dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-03-2002 10:46 PM
('93-'01) can you just buy cobb CAI and use it safely without the unichip? S-WRX Impreza Forum 2 09-03-2001 11:30 AM
