Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 10-26-2004, 05:03 PM   #1
RavSpec
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
2002 Impreza
WRX
Default Clutch/Flywheel On Sale (Spec, Exedy, Fidanza, RPS)
RPS,the leading manufacture of clutch / flywheels. They are the only company that offer carbon / carbon clutch for high torque drag cars. All RPS clutch has the option to be rebuild if needed. Avoiding the need of purchasing a complete clutch kit.
MAX SERIES (Street Disc)
02+ WRX (400 Torque) - $499.00
04+ STI (500 Torque) - $599.00
MAX SERIES (6 Puck Sprung Hub)
02+ WRX (550 Torque) - $559.00
04+ STI (600 Torque) - $669.00[/b]
MAX Series Info:
If you have the power, this is your clutch!! Turboclutch MAX Series clutches have powered many of the fastest cars down the track for the past 10 years. This is a proven winner that has been perfected over the years to become the standard it is today.
MAX pressure plates offer 400 to 600 pounds of extra clamping force to hold your biggest power. 9 second Supra’s, 10 second 300ZX’s and 3000GT VR4’s, 10 second Honda’s and Eclipse’s all use Turboclutch MAX!
RPS is the only clutch company with a U.S. Patent (#5,769,973) on their single diaphragm pressure plate technology. Our unique dual diaphragm technology allows us to create almost any clutch unit with any pressure ranging from stock to double stock in 100 pound increments. If the stock pressure is 1400 pounds we can make MAX pressure plates 1800, 1900, 2000, and so on up to 2800 pounds. This flexibility can only be found at RPS.
RPS’s all new PRO MAX Series is the last pressure plate you will ever have to buy. This pressure plate uses our patented (#6,793,057) segmented heat shield design that helps prevent warpage and is replaceable for the life of your car. If you ever wear out this pressure plate simply replace the segmented heat shields and you’re good to go. These replacement shields sell for a fraction of the cost of a new pressure plate. The PRO MAX is ideal for drag racing applications where short clutch life is the cost of going fast and RPS is helping reduce that cost.
TEL: 718-358-6102
EMAIL: [email protected]
AIM: ravspec02
RavSpec is offline
Old 10-26-2004, 05:07 PM   #2
RavSpec
Member#: 26854
2002 Impreza
WRX
Spec clutches are some of the highest quality on the market -- with a specific stage for any level of performance in your WRX. We reccomend replacing or resurfacing your flyhwheel with any of these clutches.
Clutch Kit For 02+ Impreza WRX / STI
Stage 1:
02+ WRX - $ 325.00
04+ STI - $ 525.00
High clamp pressure plate, steel-backed woven organic disk, bearings and tool.
Torque Capacity: 410 lb/ft.
Stage 2:
02+ WRX - $ 379.00
04+ STI - $ 579.00
Torque Capacity: 470 lb/ft.
Stage 3:
02+ WRX - $399.00
04+ STI - $579.00
Great Street/Strip clutch. High-clamp pressure plate, 3-piece disc with carbon or ceramic material, bearings and a tool.
Torque Capacity: 530lb/ft
Stage 4:
02+ WRX - $399.00
04+ STI - $579.00
High-clamp pressure plate, 2-piece rigid disc, bearings and a tool. Available in 3 or 6 wing design for serious road racing and drag racing.
Torque Capacity: 530lb/ft.
Stage 5:
02+ WRX - $499.00
04+ STI - $579.00
High-clamp load pressure plate, iron disc, bearings and a tool.
Torque Capacity: 680 lb/ft.
TEL: 718-358-6102
AIM: ravspec02
RavSpec is offline
Old 10-26-2004, 05:22 PM   #3
RavSpec
Member#: 26854
2002 Impreza
WRX
Default Exedy
Exedy Stage 1 (Single Plate Organic Sprung Center Damper)
WRX (15802) - $399.00
Exedy Stage 2 (Single Plate Cerametallic Sprung Center Damper)
WRX (15950) - $456.00
STI (15951) - $459.00 <-- perfect for OEM replacement
Exedy Stage 3 (Hyper Single Sprung Center Damper, including Flywheel)
WRX (FH01SD) - $899.00
STI (FH02SD) - $899.00
Exedy Stage 4 (Twin Plate Sprung Center Damper SD Type)
WRX (FM012SD) - $1359.00
STI (FM022SD) - $1359.00
Exedy Stage 6 (Twin Plate Carbon Sprung Center Damper)
WRX (FM012SBMC) - $2399.00
STI (FM022SBMC) - $2399.00
Click Here For Detail / Order
Fidanza Flywheel For WRX - $319.99
Fidanza Flywheel For STI - $379.99
Fidanza Flywheel For GC8 - $319.99
SPEC Flywheel For WRX / STI - $359.99
Exedy Flywheel For GC8 / GDA - $342. 00
RavSpec is offline
Old 11-13-2004, 05:16 AM   #4
billyr2.5
Member Sales Rating: (2)
Member#: 53663
2011 WRX WR Blue
2000 Coupe, Sedona Red
would it be posible to get a little discount if i was intereasted in buying a wrx SPORT SERIES (Street Disc) and the Fidanza Flywheel For WRX together?
billyr2.5 is offline
Old 11-13-2004, 04:20 PM   #5
RavSpec
Member#: 26854
2002 Impreza
WRX
yup, free shipping for you if you in the lower 48 states. If not, $20 more for alaska and Hawaii.
RavSpec.
RavSpec is offline
Old 11-15-2004, 02:46 PM   #6
RavSpec
Member#: 26854
2002 Impreza
WRX
bump ...
RavSpec is offline
Old 11-18-2004, 02:52 PM   #7
RavSpec
Member#: 26854
2002 Impreza
WRX
still on sale...
RavSpec is offline
Old 11-19-2004, 08:51 PM   #8
TyranosaurusWRX
Member Sales Rating: (18)
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Bump and PM'd you
TyranosaurusWRX is offline
Old 11-21-2004, 11:31 AM   #9
raglan
Member#: 65168
asking my roomie to back out of the driveway, he seemingly burned out my clutch. i am looking to replace with better components to build upgrades to my 03 wrx. i would like to do all the work myself, or with some help (not paying some wrench monkey to do it in his garage). is clutch replacement difficult, as compared to changing intercooler, hoses, intake, brakes ("simple mods") or is that on another different level. im a fast learner and not afraid to dive right into shtuff. i have the shop manuals and all the tools. just wondering if i should brave this myself or if i should let a subaru shop do it? (also interested in purchasing a new clutch)
raglan is offline
Old 11-22-2004, 10:41 AM   #10
RavSpec
Member#: 26854
2002 Impreza
WRX
raglan:
It's much harder job to do than brakes, intercooler, hoses etc. It's even harder if you don't have a lift. It take an experieces subaru tech about 3 hrs to do the clutch on a lift.. Definitely not recommend if you haven't done a clutch job before.
RavSpec is offline
Old 11-27-2004, 07:17 PM   #11
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Thumbs up
Mark, I received the clutch on time. Thanks for your help in working w/me!
Old 11-29-2004, 03:06 PM   #12
RavSpec
Member#: 26854
2002 Impreza
WRX
TyranosaurusWRX:
No problem, thank you for your business.
RavSpec is offline
Old 11-29-2004, 05:53 PM   #13
n2xlr8n
Member Sales Rating: (26)
Member#: 18960
02 WRX MBP
It lives! ; )
I have a JDM 6MT in my car with a Exedy Hyper Single (clutch, PP, Flywheel). It has approx. 35k miles on it. It is in need of rebuilding. Would I go through a vendor to have this service performed? Thank you for your time!
Steve
n2xlr8n is offline
Old 11-29-2004, 05:54 PM   #14
RavSpec
Member#: 26854
2002 Impreza
WRX
steve:
Yes, through exedy dealer , try (www.daikin-clutch.com)
RavSpec is offline
Old 11-29-2004, 05:56 PM   #15
slowwrx
Member#: 31482
2003 wrx
black
Default Flywheels
How much do each of the flywheels weigh.
I need a Spec Stage 2 Clutch and a flywheel.
I just want to know what the flywheels weigh before I order.
Oh Do you take paypal?
Thanks
Matt
slowwrx is offline
Old 12-07-2004, 06:18 PM   #16
RavSpec
Member#: 26854
2002 Impreza
WRX
Hi: The flywheels weight about 9.9 lbs.
RavSpec.
RavSpec is offline
Old 12-08-2004, 05:07 PM   #17
kingsubi
Member Sales Rating: (59)
Member#: 19239
2011 WRX
stage 2 GC8 ??
kingsubi is offline
Old 12-08-2004, 05:12 PM   #18
RavSpec
Member#: 26854
2002 Impreza
WRX
$399 for stage 2 GC8. Torque capibility is 355 Torque
RavSpec is offline
Old 12-08-2004, 11:08 PM   #19
kingsubi
Member#: 19239
2011 WRX
ACT or SPEC??
kingsubi is offline
Old 12-09-2004, 12:25 PM   #20
RavSpec
Member#: 26854
2002 Impreza
WRX
Spec
RavSpec is offline
Old 12-14-2004, 01:42 PM   #21
RavSpec
Member#: 26854
2002 Impreza
WRX
just updated all the pricing for Exedy clutches. Check out the pricing above !!
RavSpec is offline
Old 12-14-2004, 01:53 PM   #22
ami2fst4u
Member Sales Rating: (10)
Member#: 40638
'04 PSM STi
Has some work done... ;)
Price on a Exedy Twin Plate race/street clutch shipped to 01741....
Rick
ami2fst4u is offline
Old 12-14-2004, 02:43 PM   #23
RavSpec
Member#: 26854
2002 Impreza
WRX
Hi Rick:
It will be $1359 shipped.
RavSpec is offline
Old 12-15-2004, 03:11 PM   #24
RavSpec
Member#: 26854
2002 Impreza
WRX
price listed are shipped price !!!
RavSpec is offline
Old 12-22-2004, 12:36 AM   #25
RavSpec
Member#: 26854
2002 Impreza
WRX
bump ...
RavSpec is offline
Closed Thread
Subaru Drive Train Super Sale! ACT / Exedy / Fidanza / ACT / Quarter Master and More! Built Industries Drivetrain 12 04-28-2010 10:17 AM
ACT, Exedy, Spec clutches/flywheels on sale EviL Performance Drivetrain 15 06-09-2008 09:10 PM
Clutch / Flywheel Super Sale (Spec, Exedy, ACT) - Free SS Clutch Line RavSpec Drivetrain 47 11-21-2006 03:35 AM
ca: Used Exedy Twin Disc Clutch / Flywheel for sale STEALTH-WRX Private 'For Sale' Classifieds 7 03-29-2005 08:14 PM
