Old 10-26-2004, 08:35 PM   #1
Craigs
Member#: 24030
07 mazda3
Protoform p2
Default Pulling ABS fuse in 00 RS AT - urgent question
Today at NHIS I lost brakes twice under hard braking. They came back after some scary moments - through the escape in the tirewall in 3 and in 6 used way too much of the banking for my liking. The fluid and pads were new and the system was recently bled.
I want to pull the ABS fuse for tomorrow at the track.
Which fuse is it exactly? 2000 RS sedan with AT.
Thanks,
Craig
Craigs is offline   Reply With Quote
Old 10-26-2004, 08:51 PM   #2
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
Did you by chance use ATE Super Blue Racing brake fluid. I pulled the ABS fuse two days after I bought my WRX. I can't stand the ABS system in these cars. Once you have it pulled the ABS light will stay on. At least in my car that's what happens. I race a 1988 BMW M3 and don't use the ABS in that either. Have you looked in your fuse boxes for the fuse?
Good luck,
Rexfan
Rexfan is offline   Reply With Quote
Old 10-26-2004, 08:55 PM   #3
Craigs
Member#: 24030
07 mazda3
Protoform p2
motul 600
no fuse that i saw clearly labeled.
Old 10-26-2004, 08:58 PM   #4
Craigs
Member#: 24030
07 mazda3
Protoform p2
Do I pull both or only one:
"fuse 8 is the ABS soleniod.....Fuse number 14 is ABS control and cruise control"
Old 10-26-2004, 09:07 PM   #5
Rexfan
Member#: 50993
02 WRX Wagon
I would pull the number 8 fuse only.
I'll run out to my car and check to see what fuse number I have pulled.
I'll post back soon.
Old 10-26-2004, 10:51 PM   #6
Draken
Member#: 16
1968 Saab
Sonett II V4
Craig: look under on the inside of the fuse box cover. It should label the ABS fuse. I used to pull it for rallycross. Your ABS light should come on the dash.
c'
Draken is offline   Reply With Quote
Old 10-27-2004, 03:59 AM   #7
Craigs
Member#: 24030
07 mazda3
Protoform p2
Thanks a lot. Time to shower and head out.
Can I Overcome P0500 (VSS low/malfunction) by pulling ABS fuse? Tony Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-13-2010 10:30 PM
Help with pulling ABS fuse Bean75 Tri-State Area Forum 10 12-11-2003 10:37 AM
Is pulling ABS fuse legal in Solo stock? Ultralight Motorsports 12 01-29-2003 10:41 AM
Pulling ABS fuse, dumb question Fatty Jones Brakes, Steering & Suspension 14 06-04-2002 09:11 PM
