Old 10-26-2004, 09:17 PM   #1
bobert517
Member#: 56656
2003 WRX
buy my pants!!!
Default check engine light
i have a 2003 wrx with a k&n typhoon, hks down pipe, tsudo cat back exhaust, turbo-xs rfl blow off valve, s&s custom chroming headers and up-pipe, and a perrin O2 simulator ( http://www.jscspeed.com/wrx/electron...rrin_o2sim.htm ) . this simulator supposoly take the cel off, but mine is still on. i was wondering if you guys or ladies have any ideas on what to do about this problem i got. its been on a while occasionly it goes off but like in 5 miles it will come back on.
bobert517 is offline   Reply With Quote
Old 10-26-2004, 09:30 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
#1- Why are you posting this in the Normally Aspirated forum?
#2- Go to Autozone, or find someone nearby with a scanner, and get the code read. Then come back and post the code (in the proper forum) and we can help you further.
Old 10-26-2004, 10:40 PM   #3
Handsdown
Member#: 29355
autozone will read the code for free and then the factory 2.0 turbo forum will be able to help you once you tell them the code.
it could be anything, the O2 simulator may be disfunctional, or it could be something altogether different. i'd put my money on something altogether different.
with those mods you might be running a lean or rich mixture(BOV would make it rich) and you could have ignition codes being thrown.
go to autozone and get it read. it's free, and you'll be able to know what's wrong rather than guesswork.
Handsdown is offline   Reply With Quote
Old 10-27-2004, 08:19 AM   #4
bobert517
Member#: 56656
2003 WRX
buy my pants!!!
sorry i messed up and posted it in the naturally asperated one. i must of clicked in here by mistake but thanks for your help
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
