Old 10-27-2004, 12:45 PM   #1
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
Default JDM Ver 7 Vs. USDM STi cams
What benefits (if any) will I see from swapping my Ver. 7 STi cams for USDM STI cams? The motor is already out, would this be a worthwhile upgrade? Thanks
Surb00 is offline   Reply With Quote
Old 10-27-2004, 01:04 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
I think to get replys that help, you have to give a bit more info on the project you are doing.
When I used the search function to look up similar information I came up with
http://forums.nasioc.com/forums/showthread.php?t=630797, that might get you started.
As it is now you I think you have to define your quesiton a lot more.
zaxrex is offline   Reply With Quote
Old 10-27-2004, 01:28 PM   #3
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
I did not find any info on either cam in that thread. My setup is a ver. 7 motor, 4-2-1 headers, 3" exhaust, fmic, and 20g. I am just interested in how the peak power and curve might change when swapping in the USDM Sti cams. I would be interested to hear from anyone who has installed USDM Sti cams in a ej205 or ej207.
Old 10-27-2004, 03:46 PM   #4
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Why would you? The US STi cams have higher lift but will not work the 8K+ rpm's that the JDM motors see. If you plan on staying below 6500 then sure. However, I believe the cam sensors for AVCS are different so you may loose your AVCS.
Peak power would be made sooner as it is higher lift. I believe. Don't quote me. Check it out. Those are designed for a motor that runs at lower RPM's so makes peak power lower in the rpm range. The JDM cams have longer duration which is what you want on a motor that spins.
If you want to change, I would source some RA cams and retain the AVCS. Or stick a JUN cam in there that is designed for the 2.0 and get mad power. Of course you'll loose the AVCS.
Nothing on the US STi is better than what you have. No, it is not a worth while upgrade. IMHO since you asked. Good luck.
ebeck is offline   Reply With Quote
ARE USDM STi Came Gears the same as JDM Ver 7 Cam Gears? ScoobyDoo42 Mid West Subaru Owners Club Forum -- MWSOC 9 04-27-2010 05:41 AM
Analysis of Cosworth AVCS cams vs USDM STI cams bboy Built Motor Discussion 89 06-18-2008 03:48 PM
How much lower is JDM V7 spring vs. USDM STi or WRX spring txl146 Brakes, Steering & Suspension 3 12-22-2005 07:19 PM
FS TX: JDM Ver 7. Take Off STi Suspension - Full Set! salaki Private 'For Sale' Classifieds 4 08-23-2005 01:04 AM
JDM Ver.7 harnessfor USDM WRX to RS swap..?? Boost4U Subaru Conversions 3 11-02-2003 06:29 PM
