06-25-2001, 10:40 AM | #1 |
Member#: 1594
Vehicle:1999 2.5 RS 2002 Legacy |
Replacing Tranny & diff fluids instructions
Well I'm at 30k now and it's time to upgrade to some better Tranny and diff fluid.
I'm looking to get redline MTL for the tranny and MT 70 90 for the diffs. The rear diff looks rather easy to change out, but the transmission dosen't. Well we have no Chilton Manuals for our cars and our maintence and owner's manuals only cover the amount of fluid needed, not how to change it. I doubt a dealership will let you bring in your own fluids to do this and I don't want to pay their prices. Could go to a tunning shop, but would rather experience and do it myself as then I know it's done right and no hot rodding occurs in my car. Let me if you have done it your self or if there is a 'write up' somewhere of how to do it. Thanks in advance, Jon http://www.nebraska.mwsoc.org
06-25-2001, 11:41 AM | #2 |
Member#: 7752
I just finished doing it myself (at only 6k!). After you lift the car, you'll see only a drain plug for the front tranny/diff housing, unlike the rear diff which also has a fill plug.
After draining the fluid and reinserting the drain plug, I lowered the car, popped open the hood, and put new fluid in through the tranny's dip stick opening, which you can access with a long funnel at the left rear of the engine compartment. Make sure you have the right funnel or tube to reach the dipstick opening. Hope this helps. Alex |
06-25-2001, 11:45 AM | #3 |
Member#: 1904
TXIC
Vehicle:2017 Impreza Sport E36 M3/4/5 |
heh, oddly enough, I've been adviced my both my friend's who are kinda mechanics), and by my mechanic to not replace my tranny gear oil.
as for the diffs, I need to do those, too |
06-25-2001, 11:53 AM | #4 |
Member#: 1594
Why not?
Why did they say not too? Redline's MTL has a friction additive designed for sychronized transmissions so it would be perfect for our cars. It will be much better protection all around compared to the stock fluid too.
06-25-2001, 12:24 PM | #5 |
Member#: 1904
TXIC
i've been told that once replacing the gear oil, that none of the seals will sit properly anymore...this is what my friends told me
my mechanic said that my tranny would start making like clicking or grinding noises (they don't think they can be technical with me). so, whatever... |
06-25-2001, 12:41 PM | #6 |
Member#: 2958
NWIC
Vehicle:2001 2.3RS? |
Some mechanics are wary about synthetic lubes like the Redline products. A synthetic lube is much less viscous than a convetional oil. It can cause seals and gaskets to start leaking just because it is thinner than the regular oil, even the same visoucity ratings. The synthetic lubes are designed to act like a thicker oil, due to the molecular structure. The chains in the synthetic lube are different than the dyno oil.
As far as clanking and grinding, that sounds like they have expereince with improper selection of synthetic oil grades. We are using MT-90 in our trannies and love it. Shifts are smoother. For the rear diff, Redline 75-90NS. There is a great tech article at www.cobbtuning.com |
06-25-2001, 01:31 PM | #7 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
I'm using Redline 75W90NS in my trans and IMHO, it's too thin. I can't change gears nearly as fast I could before. Granted I went turbo, so slowing down between shifts is good since I want to keep this stock trans, but NA folks should be aware of that.
06-25-2001, 03:19 PM | #8 |
Member#: 1594
MTL?
Has anyone used the MTL-90 like mentioned on Cobb's tech article. I see lots of people use the 70-90NS for their diffs, but why not use an MTL line for the 'L' additive for synchros?
So does anyone have this in their car? |
Want to change Trans. Fluid & Diff. fluid what should i use? | enjoiwrx | Service & Maintenance | 16 | 08-18-2010 04:07 PM |
Tranny & diff fluid changes are cake | R_W | Service & Maintenance | 54 | 04-16-2009 09:47 AM |
about to do a 6mt tranny and diff fluid change...where to get fluid? | OneArmedScissor | Texas Impreza Club Forum -- TXIC | 9 | 10-21-2007 01:07 AM |
Redline Tranny & Diff Fluids | Ginseng | Car Part Reviews | 10 | 05-02-2003 04:42 PM |
Tranny and Diff fluid | schlong8 | Service & Maintenance | 14 | 01-13-2003 06:49 PM |
