Old 10-27-2004, 09:40 PM   #1
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Default funky noise at 3000RPMS
I have a bone stock 2004 RS (stick) with 20k miles.
I have noticed recently when I am accelerating or decelerating in gear and I hit around 3000-3500 RPMs there is a pronounced rattling noise coming from the engine bay. It is hard to explain, but its sounds as if something is clanking around really fast and goes away when I either rev up or let the RPM's drop lower. I can also have the car at idle and give it gas upto 3000RPMs and it will make the noise. So it makes the noise, in gear, out of gear, clutch in or out.
I had my roomate stand in front of the car and listen to see where it was coming from and he said it sounded like it was coming from the airbox or right underneath it on the drivers side. I replaced the stock airfilter with a K&N and the noise is still there. I dunno if something is loose or the noise is normal and Im just noticing it?
I know its hard to diagnose something with just a description of a noise but its worth a shot.
Its a stong roar like rattle that is fast passed. I have been in older cars that make this noise.
I just did a service on my car, Mobil 1 oil change.
-Jeff
JeffrWRX is offline   Reply With Quote
Old 10-27-2004, 10:02 PM   #2
chadr111
Member#: 37718
02 TS, (too Slow)
black
my 02 ts does the same thing, but I just assumed it was my cobb intake rattling around. I'll have to check it out.
chadr111 is offline   Reply With Quote
Old 10-27-2004, 10:04 PM   #3
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
ok thats good to hear that someone esle has the noise. My engine has been noise from day 1 but this seemed to be a new noise, but I could be wrong.
Old 10-27-2004, 10:58 PM   #4
DreddRS25
Member#: 51642
2008 WRX
Pitch mount is just under the airbox. May want to check the bolts are tight.
DreddRS25 is offline   Reply With Quote
Old 10-27-2004, 11:04 PM   #5
Airboy
Member#: 72829
2006 WRX
2015 WRX
The Integra that I had before getting my 2.5RS made a metalic buzzing noise at ~3000rpm. It had something to do with the heat shield around the catalytic converter. On the RS, the cat is also on the side of the air box isn't it? Just a thought.
Airboy is offline   Reply With Quote
Old 10-28-2004, 12:12 AM   #6
BlackAndBlue
Member#: 40617
on the rs the cat is approx. underneath the cd player, after the headers nowhere near the airbox
BlackAndBlue is offline   Reply With Quote
Old 10-28-2004, 01:12 AM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Heat sheilds?
jamesfacts is offline   Reply With Quote
Old 10-28-2004, 01:35 AM   #8
rawrFERNY
Member#: 51517
2007 Outlander LS
Originally Posted by americanyouth
Heat sheilds?
i think thats it because i had the exact same problem until i got borlas
rawrFERNY is offline   Reply With Quote
Old 10-28-2004, 08:52 AM   #9
Pat L.I.
Member#: 20498
2006 WRX TR
Im definately going to go with heat shields on this one, this should be the first thing you should check. Mine rattled like crazy exactly as you are describing. In the beginning i feared it was something to do with my pulleys. Turns out the heat shield around the cat just needed to be bent slightly.
Pat L.I. is offline   Reply With Quote
Old 10-28-2004, 01:56 PM   #10
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
awesome thanks guys, I will check it tonight. Do I need the heat sheild anyways? I am going to get headers/exhaust soon.
-Jeff
Old 10-28-2004, 02:06 PM   #11
rawrFERNY
Member#: 51517
2007 Outlander LS
-Jeff
ehhh, if you're getting headers/exhaust soon i wouldnt bother checking
Old 10-28-2004, 02:18 PM   #12
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Well like 1-2 months soon...LOL. The noise is irritating so I will check it out tonight.
Is it easy to get to?
-Jeff
Old 10-28-2004, 04:44 PM   #13
rawrFERNY
Member#: 51517
2007 Outlander LS
shouldnt be too hard to get to but i would imagine it would be hard to identify which of the pieces is making the noise. i would check the piece between the header and the cat first but im not totally sure
Old 10-28-2004, 06:48 PM   #14
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
the heat shields rattle all the time on subarus. i dont know how many people i write-up every week at tri-state subaru for that complaint. just resecure them.
darioc is offline   Reply With Quote
Old 10-28-2004, 08:21 PM   #15
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
I hear the same thing but it comes from my engine bay and i also hear it from the exhaust and when i told my friend to rev it i look at my exhaust and see slight flames pop out. I think i could have a timing problem.
Caplin 2.5 is offline   Reply With Quote
Old 10-28-2004, 10:47 PM   #16
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
I dont think im shooting flames. Its basically a brand new car. No mods. I didn't get time to check the heat shields, but I will tomorrow.
-Jeff
Old 10-28-2004, 11:49 PM   #17
Caplin 2.5
Member#: 71203
2005 2.5rs
Haha mine is a bone dead stock 05 rs. Man I got owned twice in one day by 2 different STi's. Im gonna get my car supercharged..... thats somethin different.
Old 10-31-2004, 11:20 AM   #18
alo
Member#: 55266
any update?
basically i got a funny clicking noise too.. it comes on when the engine is warmed up.. and usually when the rpm goes above 3k ie higher loading.. so it can get rather irritating when one is cruising..
wonder if anyone else got this problem before..
alo is offline   Reply With Quote
Old 11-01-2004, 09:12 PM   #19
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
UPDATE
I finaly got around to getting the car off the ground and check things out.
-The heat shield seem to be ok. They are on tight and do not rattle when reving it.
-I would look under the car and have my roomate rev it and I can't seem to figure it out.
I am going to take it to Norm Reeves in Temecula on Saturday and see what they say.
I will keep ya updated.
-Jeff
Old 11-02-2004, 07:26 AM   #20
robsgotit
Member#: 59674
06 06/2.5i 03/1.8t
there silver
it definitly sounds like one of the 64 heatsheilds that cover yhe exhaust from the manafold back to the midpipe, wait til its 2 years old
robsgotit is offline   Reply With Quote
Old 11-02-2004, 08:41 AM   #21
Pat L.I.
Member#: 20498
2006 WRX TR
sometimes the rattle was hard for me to duplicate unless the car was under load. You may want to try bending the shields a bit anyway. especially the ones around the cat. Cant hurt to give it a shot! (unless of course you touch them while they are hot!)
Funky A/C noise at idle (no, not the 'hissing' sound everyone freaks out over)... Obsessive Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-25-2006 06:47 PM
bov does not blow off at 3000rpm vaznlyfe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-30-2006 09:16 PM
Only .6 Bar at 3000rpm? Normal? sc00bywagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-31-2005 07:29 PM
engine shutting down at 3000rpm ne1990ls Legacy Forum 3 06-27-2005 11:32 PM
