Old 10-27-2004, 10:59 PM   #1
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default v7 versus USDM STi valvespring comparo
Doing a little tinkering, found some interesting data:
USDM STi JDM v7 STi
free length: 1.860 1.730
installed height (1.417")pressure: 50 lbs 50 lbs
pressure @ 9.55 mm: 107 130
This is assuming you use a USDM STi camshaft with the JDM v7 valvetrain. When I measured these, it was evident that coil bind would not be an issue. Use this info for what ever you feel it's worth, I'm not suggesting you do anything with your EJ257 valvesprings.
n2xlr8n is offline   Reply With Quote
Old 10-28-2004, 01:16 AM   #2
ryu12341
Member#: 44164
2004 wrx sti
blue
im a newb. are you saying they are just as good?
ryu12341 is offline   Reply With Quote
Old 10-28-2004, 10:25 AM   #3
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
At first glance, it seems the JDM springs would provide a higher rpm limit. How you would make power on a EJ257 without the supporting headwork and camshafts is "new science"....or lots of boost.
Just wanted to provide the community with the data; what they derive from it is up to them.
Old 03-08-2006, 02:13 PM   #4
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Bump for move to "built engine forum"
S.
Old 03-08-2006, 02:23 PM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
done
nhluhr is offline   Reply With Quote
FPGreen, JDM v7 heads, USDM STi block, CP Pistons Rizzo314 Engine/Power/Exhaust 0 08-11-2006 01:23 PM
V7 sb/ USDM STi heads rexnprogress Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-16-2006 09:16 PM
V7 sb/ USDM STi heads rexnprogress Subaru Conversions 0 01-12-2006 06:35 PM
04 US STi cams, v7/USDM STi intake manifolds n2xlr8n Private 'For Sale' Classifieds 52 04-26-2005 10:57 AM
USDM STi valvesprings = USDM WRX valvesprings? TexRex2002 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-12-2005 11:59 PM
