Old 06-25-2001, 01:16 PM   #1
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Question Wich type of motor oil do you use?
Wich sae of motor oil do you typically use? and wich brand would you think is the best?
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 06-25-2001, 01:42 PM   #2
roninscar
Member#: 2306
2000 RS Sedan
Blue Ridge Pearl
I go with Mobil1 10w30. The was a lot of discussion here awhile ago about when you would make the switch to synthetic (so that your engine was properly broken in) but synthetic oil is superior in every measurable category to conventional. It is slipperier, it resists shearing, it takes significantly more heat to burn, it suspends particles better, it just plain rocks.
Go synthetic after 8k miles, your car will thank you.
Cheers,
scotto
roninscar is offline   Reply With Quote
Old 06-25-2001, 01:43 PM   #3
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Castrol Syntec
10w 30
change every 6000 miles
skidplatez is offline   Reply With Quote
Old 06-25-2001, 01:49 PM   #4
Member#: 5354
I am about to shift to synthetic, right now my car has 17K on it and i am using some MOTUL stuff, but is not synthetic, and i am planning on changing to Redline 10W30, since i changed my tranny oil the other day wit MTL 70W 80 and my rear diff with 75W90 Redline, and i really can notice the difference in my gears. And because some mechanic told me the other day, that with a really good oil you can get a lot more power from your engine. What do you think?
Old 06-25-2001, 02:04 PM   #5
inpreza kid
Member#: 3334
don't know about getting more power with oil but when i switched to mobil 1 synthetic i noticed the engine ran smoother and quieter.
inpreza kid is offline   Reply With Quote
Old 06-25-2001, 02:10 PM   #6
Soob
Member#: 7631
1999 Impreza RS 2.5
Black Pearl
I have had the same experience as Impreza Kid. Once I switched over to Mobil 1 synth, I immediatly noticed that my engine ran smoother at higher revs. I also used the same weight as roninscar did. I'd totally recommend switching over. And hey, why not spoil your car alittle?
Soob is offline   Reply With Quote
Old 06-25-2001, 02:12 PM   #7
MBX Motorsports
Member#: 3726
2001 2.5RS
Blue Ridge Pearl
I switched to Mobil1 10w30 at 3,000 miles on the counter. I always run Mobil1 in all of my cars, including the '97 Cherokee.
MBX Motorsports is offline   Reply With Quote
Old 06-25-2001, 02:34 PM   #8
CSM101
Member#: 2805
2001 Impreza 2.5RS
BRP
Mobil 1 5W-30, switched at 10,000 miles.
CSM101 is offline   Reply With Quote
Old 06-25-2001, 02:42 PM   #9
Fusion
Member#: 553
2000 2.5RS Coupe
Silverthorne Metallic
I use Lubro Moly. It's a german brand I think. My friend (a partner in auto parts wholesale distributor) said it's the best oil he has access to.
Fusion is offline   Reply With Quote
Old 06-25-2001, 02:45 PM   #10
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Currently I'm running Mobil 1 5W-30. I wanted 10W-30, but the store that i bought my oil from didn't have any in stock. It's still within the acceptable range for my Scooby and since I live up here in Vancouver, we very rarely see +40C temperatures during the summer time!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 06-25-2001, 03:09 PM   #11
Martin Ritchie
Member#: 6771
2002 WRX WagonSilver
04 WRX Sedan Red
Mobil 1 5W-30 after 3,000 miles or 4,800 kilometers, whichever comes first.
Martin Ritchie is offline   Reply With Quote
Old 06-25-2001, 03:11 PM   #12
Member#: 5354
What do you think about Redline 5w 30 or 10W 30?
Old 06-25-2001, 03:37 PM   #13
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Redline is very good. Everything I've read about synthetics ranks em about like this:
1) Amsoil
2) Redline
3) Mobil 1
There is no magic number for switching to synthetics. You just need to wait until your engine is broken in. Usually the first regularly scheduled oil change is fine.
I'm not sure about the newer models, but 5w30 is the recommended weight for my vehicle. I usually run 10w30 in the summer, though, since I drive it pretty hard.
gavin is offline   Reply With Quote
Old 06-25-2001, 04:09 PM   #14
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Castrol Syntec 10w30.
If it were a higher performance machine I'd worry about more. AMSOil series 2000 would be waste of good money in this EJ25 truck motor.
Syntec is good enough, and I save enough to buy parts that make a difference.
ColinL is offline   Reply With Quote
Old 06-25-2001, 04:46 PM   #15
geoffj
Member#: 9
I just switched from syntec blend to syntec today and I can really notice a difference. The engine runs alot smoother and seems to rev a little faster. I thin it was good for like 10 mental hp
geoffj is offline   Reply With Quote
Old 06-25-2001, 06:00 PM   #16
jlyttle
Member#: 2815
2004 Forester XT 5sp
Default Mobil 1
5w30 at first, just switched to 10w30
I switched at 1250 miles. I use Mobil 1 because I can get it anywhere, and it is as good as I need.
jlyttle is offline   Reply With Quote
Old 06-25-2001, 07:29 PM   #17
Dirty Underwear Gang
Guest
Member#:
I use AMSOIL 5w-30/Subaru filter every 3000 miles. Car runs much smoother with the AMSOIL compared to Mobil1. It is worth the $7.99/qt I pay for it.
Old 06-25-2001, 07:44 PM   #18
Overtime
Member#: 1346
I've never noticed a difference between a car with fresh synthetic and a car with fresh dino oil. It just feels good to have a car with the oil changed.
Speaking of oil, does anyone have any opining to do on the Valvoline VR-1 racing oil?
Overtime is offline   Reply With Quote
Old 06-25-2001, 09:04 PM   #19
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
I picked up my 99 GT w/ 24k on it last Oct... switched it to 5-30w Mobil 1 in Feb. Noticeable difference... i dunno... like OT said, "It just feels good to have a car with the oil changed"
Sat was subie maint. day, I changed the engine oil and while I was at it drained the trans and am now running some Redline 70-90w. I have yet to treat the rear diff. Sure did notice a sugnificant difference in shifting... much smoother, less crunchy. Better mileage?? I'll take it if I get it.
I was bummed that I failed to realize (until too late) that the trans drain plug is larger... and had no fresh sealer/crush ring (anyone know what size ring this takes ?? M20+ ?). Is this an issue? It doesn't seem to be leaking... yet!?!?
How about filters everyone? Strickly Subaru parts... or Fram basic, TG, DG... or other? They've all got to be about the same, eh?
snowone is offline   Reply With Quote
Old 06-25-2001, 09:49 PM   #20
Member#: 5354
How many qts of oil do our engines need? i have never changed the oil myself
Old 06-25-2001, 09:59 PM   #21
Penphoe
Member#: 269
The 2.5 engine takes about 4 litres of oil. Look in your owners manual for the correct amount.
LaterZ!
Darren!!
Old 06-25-2001, 10:22 PM   #22
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
It's rated at just over 4 quarts, but I use an even 5 quarts every oil change, if you change the filter, too.
Old 06-25-2001, 10:52 PM   #23
Bottom Feeder
Member#: 2808
Snowone-
The general concensus here is that the bottom-end orange Frams are crap. The higher-end grey-painted Frams are supposedly decent, but relatively expensive. Go with Purolators or genuine Subarus, which are said to be made by Purolator anyway.
And to the other guys-
The 2.5 takes a hair under 4.5 quarts with a filter. 4 quarts will put it between the marks on the stick, wich is an acceptable range, but 5 quarts will overfill it.
Bottom Feeder is offline   Reply With Quote
Old 06-25-2001, 11:18 PM   #24
ExchangeGuy
Member#: 4383
2012 Camaro RS
Blsck/gray
I have used mobil 1 one oil change then I wanted to try anything to get a little more torque out of the eng. So i switched to Royal Purple 10w-30. I do feel a slight bump in torque when I sling out of the corners when auto-xing. the engine also runs cooler and feels more powerful. Of course the mileage sucks more cuz my foot is heavier...
It's like 6.99 a qt but in my opinion it's worth it. My times have been improving since changing to RP. I have also install a water wetter in the radiator from RP that has dropped temps about 4-5 deg. The eng runs even more powerful now than ever! Especially since I live in the hot climate of houston Texas with the A/C on full blast! Just my opinion.
Forrest
Texas Subaru Motorsports
ExchangeGuy is offline   Reply With Quote
What type of engine management do you use? bonzai Engine Management & Tuning 0 11-28-2009 01:17 PM
What motor oil do you use? jmang Newbies & FAQs 76 11-15-2009 10:17 PM
Which brand motor oil do you use? Shootist Service & Maintenance 27 06-27-2006 10:41 PM
Whats motor oil do you use? Impr3zy0u Service & Maintenance 34 01-12-2006 03:01 PM
What type of Christmas tree do you use? [27] Off-Topic 22 11-11-2002 07:31 PM
