Old 06-25-2001, 12:45 PM   #1
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
Default Check Engine Code P0302, "#2 Misfire"
Just as a heads up, my 2000 Legacy GT is currently suffering from a #2 cylinder misfire, according to the P0302 error code. A dealer is trying to find the problem now, but it doesn't seem to be either possibility listed ( plugs and/or wires ).
If anyone has BTDT, I'd be interested to hear it. Neither dealer I've spoken to has seen this, certainly not at 26,000 miles.
There are a few more details in this thread, if you are interested;
http://i-club.com/forums/showthread....threadid=64903
I'll advise when a solution is found.
hillman is offline   Reply With Quote
Old 06-25-2001, 01:19 PM   #2
subarurabbit
Member#: 4083
2011 OB 3.6R
Missfire codes are more likely to be caused by manual transmission cars. It has to with acceleration sensors and crank position sensors.
Is your car a stick?
Roger
subarurabbit is offline   Reply With Quote
Old 06-25-2001, 02:49 PM   #3
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
I just posted in your other thread. That is very interesting, my 98gt is coding the same thing right now. I've been tossing the injector thing around. Let us know how it goes. since I've been getting this code, I've replaced: plugs (2 times), wires, coil pack, fuel filter, fuel lines @ filter (with high pressure lines), currently using a different ignitor. Any suggestions? Oh yeah, PCV valve, new gas cap and I don't remeber what else I've done to it.
pleiades is offline   Reply With Quote
Old 06-25-2001, 03:58 PM   #4
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
The Legacy is a stick. I'm supposed to pick it up tonight, and if it is running properly, I'll assume the injector was the root cause and let you know.
Otherwise, I'll be complaining about another service department.
Old 06-25-2001, 04:01 PM   #5
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Thanks! Let us know as soon as you know!
Old 06-26-2001, 03:14 PM   #6
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
As detailed in the other thread, the #2 injector was apparently the problem.
Check Engine Code 1507 OArmijo Service & Maintenance 4 09-02-2003 12:23 PM
check engine codes gpd323 North West Impreza Club Forum -- NWIC 9 10-17-2001 06:17 PM
Help with check engine code Meche 2.5RS Normally Aspirated Powertrain 1 10-10-2001 06:20 PM
Check engine codes Wildman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-21-2001 07:04 PM
Check engine codes Kruf General Forum Archive 1 12-17-2000 05:46 AM
