Old 10-26-2004, 07:08 PM   #1
Kregg
Member#: 68974
05 STI
CGM
Default 05 STi OEM Wheel ID Needed
Could someone tell me the inner diameter of the stock wheel for 2005 STi? To the nearest 1/16th of an inch should be sufficient. I would like an accurate number since I will use this to determine if a set of wheels will clear my calipers.
Thanks in Advance,
Craig
Kregg is offline   Reply With Quote
Old 10-26-2004, 07:47 PM   #2
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
hi craig,
they have brake templates out there i just googled this...
http://www.zeckhausen.com/Brembo/whe...t_template.htm
good luck
hope that helps.
SD
suby_dude is offline   Reply With Quote
Old 10-26-2004, 11:06 PM   #3
Kregg
Member#: 68974
05 STI
CGM
This explains to measure the distance from the center of the hub to the outside of the caliper. Seems to make sence this would be the critical radius the wheel radius would need to be greater than. I would still like to know if anyone has made this measurement already, or if they know where I would get the information on the OEM wheel diameter (radius) from the manufacturer or a reliable source.
Old 10-29-2004, 01:05 PM   #4
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
I have a set of stock wheels off the car - the inside sort of tapers from back to the front (toward the spokes.) But at the narrowest - near the spokes and about where the brakes would be - the inside diameter is a hair over 15 inches, looks like 15-1/8".
austinpike is offline   Reply With Quote
Old 10-29-2004, 01:27 PM   #5
Kregg
Member#: 68974
05 STI
CGM
Thanks for the help Pike. I measured my wheels a couple of nights ago and got the same number you did! Sounds like we are on board, thanks again!
-Craig
FS: 05 STi heads, 05 STi OEM Flywheel, 05 STi OEM Fuel Rails, Camshafts, STIStalker Engine/Power/Exhaust 1 12-05-2010 08:10 PM
WTB: 04-05 wrx/sti tail light (driver's side only) and (1) 05 wrx oem wheel its Brian SCIC Private Classifieds 33 02-03-2010 05:18 PM
WTB: NYC: 05+ STi OEM BBS Wheels 5x114.3 S1MPSONS Private 'Wanted' Classifieds 1 01-08-2009 02:27 PM
06 WRX & 05 STi oem wheels/tires for sale 2005WRXST! RMIC Private Classifieds 23 04-08-2007 02:00 AM
Need help 05 STI OEM gauge install PARAMEDIC Interior & Exterior Modification 2 12-11-2004 11:00 AM
