Old 06-25-2001, 04:46 PM   #1
Kachukaa
Member#: 2527
1997 Legacy 2.5GT
Quicksilver Metallic
Default Grinding Gears Help!
Just started happening. Clutch all the way in, when downshifting form 5th to 4th or 4th to 3rd I hear and feel a grind. I have a cobb short shifter, but I don't think it's the short shifter grinding but I could be mistaken. I'm thinking bad clutch, but my car is at 62,000, I would think the clutch would last longer. The clutch has not been abused so I'm looking for what the problem is and how to fix it.
Thanks in advance,
Pete
Kachukaa is offline   Reply With Quote
Old 06-25-2001, 04:51 PM   #2
BigElm
Always under your radar!
Member#: 1568
You're lucky your stock clutch has lasted that long, even if it's not abused. It's not your short shifter...it's time for a new clutch. The clutches on Subaru's are not that strong to last you a long time...heck there are even issues of it being replaced when new (flywheel and all). So, to answer your question...change the clutch and get a better one ~ aftermarket.
Good luck!
BigElm is offline   Reply With Quote
grinding gears baldcherub Newbies & FAQs 6 10-11-2001 03:45 PM
Grinding Gears tripl3s3v3n Normally Aspirated Powertrain 4 06-04-2001 06:48 PM
Grinding gears when shifting into 1st? Fred Fredburger Normally Aspirated Powertrain 12 01-11-2001 01:06 PM
75W-90NS Tranny oil and grinding gears vinman Normally Aspirated Powertrain 10 12-28-2000 10:39 PM
Message Board Statistics All times are GMT -4. The time now is 04:51 PM.
