Welcome to the North American Subaru Impreza Owners Club Thursday March 26, 2015
Old 10-29-2004, 10:34 PM   #1
mycarsux
Member#: 32049
2002 2.5RS slowbaru
+Canon 5D & 30D
Default need help w/ jdm hid
i just bought the jdm black/chrome hid lights, but can't put them on. it came with the bulb, and i think the ignitor (the thing on top of the bulb.. ) anyways, i'm currently running brightstar hids on my stock headlamps. i was wondering if i can use the brightstar ballast and plub it into the jdm lights. however, i found out that the plug is the same exact one. they are both female ...or male..dunno which one is which, but they are the same exact plug. i was wondering if i can just cut off the plug on my brightstar ignitor and solder it in place of the plug on the jdm lights. the plug for the ignitor is the one that has a orange plastic covering over the wires right? any help is appreciated.
mycarsux is offline   Reply With Quote
Old 10-30-2004, 05:13 AM   #2
nqwan
Member#: 2916
02 duburu arr exu
if your brightstar ballasts have built in ignitors you cannot just splice into the orange/brown/black wires in the orange loom. doing this will have two ignitors wired in series per bulb, which i know from experience doesnt work...
if the ballasts are d2s/d2r spec, they will work. if they do have internal ignitors, the easiest way would be to no use the stock ignitors and plug the bulbs into the plug from the ballast, but routing the wires in the housing and mounting the ballasts will be more difficult since lengthening the wire between the bulb and ballast is not an option.
nqwan is offline   Reply With Quote
Old 10-30-2004, 03:28 PM   #3
mycarsux
Member#: 32049
2002 2.5RS slowbaru
+Canon 5D & 30D
my brightstar ballast doesn't have built in ignitors, the ignitors are seperate. so can i use the plug on the brightstar ignitor and use it for the jdm ignitors? it wouldn't cause any harm right? what kind of souter (however you spell it) should i use? should i use some kind of clamp or other electirical thingis instead?
just found out that the wire on the brightstar ignitor looks like one big wire..it doesn't look like the jdm wires, where its orange, black, and red. still has the same plug though...is it still a good idea to use the plug from the brightstar ignitor?
Old 10-30-2004, 05:45 PM   #4
nqwan
Member#: 2916
02 duburu arr exu
i'd suggest cutting off the connectors and wiring your own. you're not going to be able to find the male end of the plug on the orange loom for any affordable price.
Old 10-30-2004, 06:01 PM   #5
mycarsux
Member#: 32049
2002 2.5RS slowbaru
+Canon 5D & 30D
yea...i might try it today. hmm..i tried looking if the brightstar is a d2s/d2r spec, but it doesn't say. but is it still okay to use the ballast as long as the ignitor is seperate?
Old 10-30-2004, 10:59 PM   #6
mycarsux
Member#: 32049
2002 2.5RS slowbaru
+Canon 5D & 30D
ok...well...i tried and it doesn't work...i don't know what it is..i guess the jdm hid bulb is bad or the jdm ignitor is bad. i dunno what to do now...damit i want my jdms on right now. im also running on stock halogen..damn it sucks. does anybody know if any h1 size bulb will fit in the jdm hid headlights?? i was wondering if i can just get an h1 bulp and put in.
Old 11-20-2004, 10:36 PM   #7
mycarsux
Member#: 32049
2002 2.5RS slowbaru
+Canon 5D & 30D
hmm...well little update about my headlights..i bought the hid kit from gruppe-s. and i know it said that the kit was for the jdm projectors...but they don't fit at all. it goes right through the hole. does anybody know what the heck the correct bulb size is for the jdm hid headlights? are the non-hid jdm headlights and the hid jdm headlights' bulb different size? the kit said h1 on it, but it didnt fit, so me and my friends made some custom brackets to make it fit, but it doesn't light up anything! even halogen lights out power mine! aurgh...
Old 11-20-2004, 10:57 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
OEM HIDs use industry-standard D2S bulbs. The ones in your retrofit kit are rebased and non-standard, and have been reconfigured to mount in the non-HID JDM H1 housings. You can't mount them in the D2S receptacles in the JDM HIDs. You can't mount H1's either, or any other halogen bulbs. Only D2S bulbs will fit properly.
Old 11-21-2004, 02:28 AM   #9
mycarsux
Member#: 32049
2002 2.5RS slowbaru
+Canon 5D & 30D
ahh...so thats how it is...hmm...well the thing is, i don't know if the ignitor or the bulb is bad that was on the jdm headlights. will any ballast that has the ignitor seperate work for a d2s bulb?
Old 11-21-2004, 06:06 PM   #10
mycarsux
Member#: 32049
2002 2.5RS slowbaru
+Canon 5D & 30D
another quick question...can the ignitor go bad? all i can find is d2s bulbs, but no ignitor or ballast. i dunno if it was my bulb that was bad or the ignitor. thanks..
HELP WITH JDM HID projectors sp99ling Private 'Wanted' Classifieds 7 04-14-2009 04:38 AM
Need help rewiring JDM HID projectors kenny08 Southern California Impreza Club Forum -- SCIC 7 01-29-2007 10:26 PM
Need help installing JDM HID projector headlamp facs Vancouver Impreza Club Forum -- VIC 7 01-15-2006 01:36 AM
need help w/ jdm hid im imprezd Electrical & Lighting 0 08-17-2004 02:09 AM
HELP with JDM HID SSFWRX Electrical & Lighting 0 06-17-2004 12:51 AM
