Old 10-30-2004, 12:07 AM   #1
lj17
Member#: 67381
95 Legacy L sedan
Default 95 legacy rear defrost won't work!
i have a 95 legacy L awd sedan. i checked the fuse- not blown. i don't know too much about subarus, and don't have a shop manual (suggestions for a good one to get? haynes?), any ideas on what else to check?
now, i read in another post that the legacy defrost worked, but took a really long time, like upwards of 35 min. or something. this may be true of mine, as my commute is only 15-20 min. but even if mine does work, it is useless with my short morning commute. so i guess what i'm asking is- is there any way to fix the defrost, or fix a "slow" rear defrost?
i don't expect it to work at the drop of a hat, but damn, my honda's rear defrost clears the window in about 3 min., 5 at the most. but since my subaru is my winter car, this kinda sucks. and i would really like to have a functioning rear defrost before the pennsylvania snow flies...
lj17 is offline   Reply With Quote
Old 10-30-2004, 03:26 AM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
"what is behind you, is not important!"
dunno what to tell you besides splicing open the wire bundle and checking to voltages...
fibuz is offline   Reply With Quote
Old 10-30-2004, 12:59 PM   #3
Hiroki Tada
Member#: 8048
I'd check to see if there's a current reaching the defroster. I have no clue what it's labelled as or where the wire is on a BD. On the BE's, the choke coil is a black coloured harness that's located above the antenna amplifier pack on the rear driver's side. If you find it, pull it out and see if the lead's are corroded. In any case, test the strength of the current that's going through. Not too sure on what's the correct amperage but you could always test another piece on the same series circuit and use that as reference.
Hiroki Tada is offline   Reply With Quote
Old 10-30-2004, 04:25 PM   #4
lj17
Member#: 67381
95 Legacy L sedan
i forgot to mention, when the switch is pressed, the indicator light comes on, so i think i can rule out a faulty switch.
i'll try checking the current, but can you tell me what BD and BE mean? is that the chassis code or something? and what is the choke coil? again, i don't know much about subarus
thanks for the suggestions though. since you guys are scooby specialists, can you recommend a good shop manual? i saw a haynes at the auto parts store for $15. is it worth getting? i would like to have something before i get too far into this. i just want something relatively cheap, but good, that will help with regular maintenance and problems like this.
Old 10-30-2004, 05:44 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
BD/BG are the ~1997-2000 subies.
Haynes (for your year) are a good starting point for a shop manual. Not perfect, but better than nothing.
Old 10-30-2004, 06:16 PM   #6
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I had to resolder the connection at the glass. it was a pain in the ass.
subiekid is offline   Reply With Quote
Old 10-30-2004, 06:47 PM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
*north america only* subtract one year for JDM
BD/BG 1995-1999 sedan/wagon
BE/BH 2000-2004 sedan/wagon
BL/BP 2005-up Sedan/wagon
GTBGUY is offline   Reply With Quote
Old 10-30-2004, 07:52 PM   #8
lj17
Member#: 67381
95 Legacy L sedan
thanks for the info ^^
i already checked the connections at the glass, and they both look fine.
i guess i'll just pick up the haynes manual. i don't want to spend that much and am just looking for some in-depth info on maintenance-related things, nothing too major. my legacy is completely stock, and will stay that way. it is just what i am going to drive in the winter months. but i want to change all the fluids (engine, tranny, rear diff.) and take care of some other little things before the snow flies, including the rear defrost
Old 10-30-2004, 08:14 PM   #9
Hiroki Tada
Member#: 8048
yeah, the haynes manual is pretty good and you could probaly find it in your local automotive store. if not, i think haynes itself has online shopping. basically, a choke coil is something that would take your car alternator's AC signal and manipulate that signal to something useable. in this case, that would be the purpose of defogging your rear window.
im not too sure how far you want to dig into this but i'd check the signal from the relays. again im not sure about your model year but it should be on the same relay as your ac control/unit.
heh. good luck keeping the legacy stock. 1 heavy snow, and 1 hr in an empty parking lot would change your mind.
Old 10-30-2004, 10:26 PM   #10
lj17
Member#: 67381
95 Legacy L sedan
thanks for all this. i actaully saw the haynes manual at an advance auto parts for around $15, so i'll probably just go back and pick it up within the next couple days. maybe after i get the manual i can really start troubleshooting the rear defrost...
i just got my legacy back in july, so this will be the first winter i have it. i probably will want to get some things for it, but since my pockets aren't real deep, it will most likey stay stock. for this winter anyway, we'll see...
Old 10-31-2004, 09:45 AM   #11
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
yeah, basically, a choke coil is something that would take your car alternator's AC signal and manipulate that signal to something useable. in this case, that would be the purpose of defogging your rear window.
Ummm..... , HUH?
The full bridge rectifier (inside the alternator) does this. This is then the DC power FOR EVERYTHING electrical in your car.
There should be no AC power outside the alternator.
If the rest of the electrics are working, I would skip the alternator. Checking the fuses (best way is to unplug both connectors to the glass heater and plug a DC voltmeter into it and hit the defrost switch), relays, wiring and switches are next.
If you don't have power to the rear connectors on the glass, go backwards until you do, then fix the problem.
If you have power at the glass connectors, it is the heating film itself.
Rear defroster not working at all silence2-38554 Electrical & Lighting 9 03-06-2009 12:49 PM
Help my rear defroster wont work wantsti Electrical & Lighting 2 01-03-2009 03:13 PM
Rear defrost not working HomerCF Electrical & Lighting 5 11-10-2007 01:42 PM
92 Legacy heater/defroster dosent work Wildde North West Impreza Club Forum -- NWIC 6 10-17-2007 09:21 PM
Rear defrost stopped working b0dh1 Electrical & Lighting 1 02-15-2006 09:24 AM
