Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-30-2004, 09:39 AM   #1
huck369
Member#: 26201
1989 Frankenwedge
EG33 Powered XT6
Subaru Stars 95 Impreza...OBDI or OBDII ?
Which one?
And can I pull the codes from the ECU myself?
I can pull the codes on my 89 XT6, and could on the 91 Legacy I used to have.
But haven't seen the procedure for the 95 Impreza.....
Any help would be welcome....
Thanks,
Huck
huck369 is offline   Reply With Quote
Old 10-30-2004, 12:48 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Hey Huck,
You can just look for the connectors and see what happens. Also, I believe if the ECU connectors are yellow, it's OBD 1.
josh
Legacy777 is offline   Reply With Quote
Old 10-30-2004, 03:32 PM   #3
huck369
Member#: 26201
1989 Frankenwedge
EG33 Powered XT6
Question
Josh,
Where would the connectors be at on an Impreza?
And how would I pull the codes on it if it is a OBDI ?
It just quit getting fire...I'm leaning toward the Crank position sensor, as they were prone to failing about that year....but I don't have a meter to check it with...
I've got a spare igniter, and I tried it, still no fire....any suggestions?
Huck
Old 10-31-2004, 02:21 PM   #4
Legacy777
Member#: 4800
The connectors should be under the dash in roughly the same area that they are for the legacies.....or so I think.
Old 10-31-2004, 02:47 PM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
IIRC, anything '95 or before is OBDI, 96+ = OBDII.
jamesfacts is offline   Reply With Quote
Old 10-31-2004, 04:27 PM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Legacys, older ones such as the BG have them conviently enclosed behind a flap above the hood release, the newer ones are just sticking out right underneath the hood release near the electrical jungle.
GC/GM/GF Imprezas have them in the center in a recessed area, being connected mearely by a few clips on the reciprocal side that sometimes dislodges itself.
-paK +1
Pakin is offline   Reply With Quote
Old 10-31-2004, 04:56 PM   #7
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Subaru's MY95 had a mix depending on your engine. EJ18s were OBD-I while the EJ22s were OBD-II.
MY95 EJ22 equipped were only availible in the 4EAT drivetrain.
You can also look at it this way, if you have a stick, it's OBD-I.
Even though the MY95 EJ22 was OBD-II (operational with repective scan tools) standard emissions will still inspect it under OBD-I parameters for emmisions: sniffs instead of plug in.
-paK +10
Old 10-31-2004, 09:21 PM   #8
huck369
Member#: 26201
1989 Frankenwedge
EG33 Powered XT6
Thanks for the replies,
It's a AWD 5-Speed EJ18...I found the connectors...it was the Cam postion sensor....
Thanks again.
Huck
Is my car OBDI or OBDII? Jutboy Normally Aspirated Powertrain 19 06-08-2008 01:30 PM
OBDI -> OBDII (with piggy back EMS) Jutboy Engine Management & Tuning 2 01-07-2008 10:47 PM
OBDI -> OBDII (with piggy back EMS) Jutboy UTEC 0 01-06-2008 12:15 PM
Give me the truth on a 95 impreza OBD1 or OBD2 help mellow65 Subaru Conversions 14 02-19-2007 09:26 PM
WTT: 95 Impreza Coupe for 95 Impreza Sedan bigboss MWSOC Private Classifieds 9 02-18-2007 05:40 AM
