Old 10-30-2004, 10:28 AM   #1
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Default URGENT: Oil pan Removal
Spent 3 hours to take out the rear 4 bolts of the oil pan. All the bolts removed but the oil pan won't drop. I've read everything from exact-o knife to beating it to crap with a hammer. It just won't drop. I don't have a hoist.
2003 Subaru Impreza RS.
I spent 6 hours from 11PM-5AM on trying to just remove it. Can someone PLEASE help?
fukamoto is offline   Reply With Quote
Old 10-30-2004, 11:30 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Use a razor blade to cut all the way around. Use a screw driver on a corner to pop it up by sticking it in the space between the block and pan and turning the handle of the screwdriver. Make sure that you have every bolt out too. Be careful not to scratch the block when turning the screwdriver. Another thing you might try is smacking the side of the oil pan with a rubber mallet to break the seal. It can be a pain but it will come off. Before reinstalling the pan make sure to clean the mounting surfaces of the block and the pan completely or it wont seal right. Good luck man.
Drac9 is offline   Reply With Quote
Old 10-30-2004, 02:14 PM   #3
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Then when you go to reseal it, use some quality sealant like Hondabond HT, or Yamabond.
Don't go cheap here, unless you really like taking your oil pan off again to fix a leak
IowaRS is offline   Reply With Quote
Old 10-30-2004, 03:34 PM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Best advice ever...
-Brett
ExecNav is offline   Reply With Quote
Old 10-30-2004, 03:37 PM   #5
fukamoto
Member#: 13339
2014 SWP WRX Wagon
The passenger side can fit a knife into it but it cannot cut around towards the drivers side. I have no idea how to cut around the left side as there is no room to manuveaur. This is killing my whole body....
Old 10-30-2004, 04:15 PM   #6
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Don't be afraid to make that oil pan your biotch. Just be very careful not to bend or scratch the edges. Also, try not to damage the oil pickup when you pull it off. You have to maneuver the oil pan around the oil pickup.
-Brett
Old 10-30-2004, 05:25 PM   #7
tulit
Member#: 338
09 STi
Yeah its a pain. What I did on mine was remove the oil filter and just pry it off from that corner there. It took some time, but it eventually popped off (though there were a few marks on the block in the area I was prying. It hasn't leaked in over a year though, so I think its fine).
The easiest way to get the pan off the oil pickup is once the seal is broken on the pan, you should have enough room to loosen the three bolts holding the pickup to the engine. Some say this isn't necessary, but I couldn't find a way to do it without doing this first (keep in mind, I didn't jack the engine up off the cross member like most people do. If you do this step, you may be able to remove the pan without loosing the pickup)
tulit is offline   Reply With Quote
Old 10-30-2004, 08:09 PM   #8
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
when i took mine off me and my friend just beat the hell out of the pan until eventually it popped off. Then i cleaned the block with alcohol and used super black rtv.
Derk1127 is offline   Reply With Quote
Old 10-31-2004, 10:11 AM   #9
4wheelmotion
Member#: 2044
1999 2.5 rs-T
rally blue/ '96 jetta vr6
all you should have to do is tap the oil pan with a rubber mallet. that simple. done 2 that way with no problems.
4wheelmotion is offline   Reply With Quote
Old 11-01-2004, 03:31 AM   #10
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Where did you guys drill your oin return line on the oil pan?
I drilled it and welded it only to find out the frame was still in the way. I have to re-weld it and drill 1/2" lower or find a new spot. I drilled it at the opposite side of the dipstick almost at the same level.
Oil Pan Removal? fukamoto Vancouver Impreza Club Forum -- VIC 1 10-30-2004 12:20 PM
oil pan removal twisty 'Old School' Subaru Forum 4 08-09-2004 05:45 PM
Oil Pan Removal samtheblur Outback Forum 3 01-15-2004 06:48 AM
Oil Pan Removal tulit Normally Aspirated with bolt-on Forced Induction Powertrain 23 05-28-2003 03:20 AM
oil pan removal cleaning akcel Normally Aspirated with bolt-on Forced Induction Powertrain 6 03-02-2003 09:14 PM
