Old 10-30-2004, 11:49 AM   #1
Alpha_32
Member#: 35876
2008 Legacy GT SpecB
Grey
Default hissing noise?
after I got my borla (4th gen) headers installed at half throttle to WOT i can hear this mono pitched hissing sound from under the car...any idea what it is or if it's normal or anything?
Alpha_32 is offline   Reply With Quote
Old 10-30-2004, 04:20 PM   #2
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
a leak? did you use old gaskets?
JeffrWRX is offline   Reply With Quote
Old 10-31-2004, 12:03 AM   #3
Blue98leg
Member#: 65036
2013 WRX
mine have this sound too, but im pretty sure its not a leak.
Blue98leg is offline   Reply With Quote
Old 10-31-2004, 12:40 AM   #4
rawrFERNY
Member#: 51517
2007 Outlander LS
mine had it and it went away after a while so i dunno
rawrFERNY is offline   Reply With Quote
Old 10-31-2004, 01:24 AM   #5
rabbitnutz
Member#: 51940
break in noise ? headers fully broken in when noise goes away ??
rabbitnutz is offline   Reply With Quote
Old 10-31-2004, 12:54 PM   #6
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
intake?
RS_to_WRX_swap is offline   Reply With Quote
Old 10-31-2004, 01:47 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
To check for a leak, hold your hand under the header w/ the motor running.
Run your hand up and down (don't touch!) and see if you feel any air.
jamesfacts is offline   Reply With Quote
Old 10-31-2004, 03:24 PM   #8
Alpha_32
Member#: 35876
Grey
hmm i havn't checked for a leak, i did buy all new gaskets, my injen intake makes it's own special noise, and i have put like 5k miles on them
Old 10-31-2004, 07:12 PM   #9
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
I'm pretty sure thats a normal noise for any header.. Its just exhaust gasses pinging in the primary tubes.. Nothing to worry about. Mine do it too.
SubyGC8 is offline   Reply With Quote
Old 10-31-2004, 07:33 PM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
nomral header noise.
an exhuast leak wouldnt be steady hissing noise, a vacuum leak would give you a hissing noise.
but the noise you are hearing is probably the normal noise the headers make. Some people complain that it is to loud and have taken the borla headers off for the reason.
Jay
Old 11-01-2004, 03:42 PM   #11
DreddRS25
Member#: 51642
2008 WRX
Ditto. Went away after a month or so for me.
DreddRS25 is offline   Reply With Quote
Old 07-07-2010, 02:02 AM   #12
JPCII
Member#: 248024
Unhappy Borla headers on 2.5i
Put borla headers on my 2010 outback sport this last week and they hiss pretty loud. Absolutly no leaks anywhere, but the noise only happens when above half throttle under a load. Any ideas? Just the nature of the headers or is there a point in time where that will go away?
JPCII is offline   Reply With Quote
Old 07-07-2010, 01:31 PM   #13
ttatsumi
Member#: 85763
wrap the header with exhaust wrap and the sound will go away. i think the aftermarket ones are made with thinner piping. pretty sure this will fix the hissing sound since mine went away.
ttatsumi is offline   Reply With Quote
Old 07-07-2010, 10:06 PM   #14
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Vegas, eh? Heading there end of August!
/threadjack
Old 07-07-2010, 10:16 PM   #15
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
seafoam the engine. check for leaks when you start it up after the ingestion on seafoam
kewlboxer2 is offline   Reply With Quote
Hissing noise on acceleration MaLT Newbies & FAQs 17 12-04-2006 08:59 PM
Weird hissing noise now? abosworth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-24-2006 10:16 PM
Hissing noise from acceleration? Yblast Newbies & FAQs 8 10-01-2004 02:44 PM
Hissing Noise AlfredWRX Newbies & FAQs 4 05-08-2003 04:34 PM
Hissing noise???? Dave DD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-18-2002 05:01 AM
