Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-25-2001, 10:14 PM   #1
aarneson
Member#: 3383
Question If I do an ECU reset will it erase the datalogging?
As the title says, I was wondering , if you reset the ECU will it erase the datalogging? How much info and what kind can they really log into the ECU about my driving habits? Can they tell if you properly broke in your engine? I wish they would disclose that info before you buy! - Arne
aarneson is offline   Reply With Quote
Old 06-26-2001, 12:10 AM   #2
aarneson
Member#: 3383
bump
Old 06-26-2001, 12:10 AM   #3
tmaler13
Member#: 1992
There probably monitering you right now.....
Quick go inside grab some tinfoil and wrap it around your skull,
This helmet will protect you but only if its on your head.
be sure to wear it while driving.
(shiny side out)
-Terry
tmaler13 is offline   Reply With Quote
Old 06-26-2001, 12:18 AM   #4
aarneson
Member#: 3383
Really?? Do you think it would work? I worry it might afect the ecu's learning curve since it won't be able to read my brainwaves! Maybe a wet towel around my head would work better until I can get my **s to Mars Thanks for the funny anyways- Arne
Old 06-26-2001, 01:25 AM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I think you're screwed with the datalogging... mine held a CE light for about 3k miles!
Brian
AIM: captaindamorgan ICQ: 84483950
http://www.northursalia.com
Conjunction Junction, what's your function?
Old 06-26-2001, 09:46 AM   #6
MBX Motorsports
Member#: 3726
2001 2.5RS
Blue Ridge Pearl
The computers in all vehicles have onboard batteries in the event that you unplug your battery. It's kinda like the BIOS on a desktop computer, if you unplug it, it doesn't forget what kind of hard drive you have a week later.
As far as data logging, I think you're all paranoid. I've had the computer out of many different vehicles to rewrite code and remove rev-limiters, etc and I've never found a "data logger." At least not in a sub 30K vehicle. Perhaps BMW, Mercedes and more expensive exotic cars would have it ... but I seriously doubt a 20-25K Subaru would have it.
In fact ... I'm going to take the comptuer out of my car this weekend and prove that we don't have one (2001 2.5RS).
MBX Motorsports is offline   Reply With Quote
Old 06-26-2001, 06:12 PM   #7
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
You can still clear the ECU, however, battery or no battery.
I would suspect that it doesn't log anything other than fault codes, but if you clear em, you clear em. Using the proper procedure from the shop manual, my codes cleared immediately. Thankfully (and inexplicably) they have not returned (BPM CEL issue, after second reset...600 miles since).
take care,
rob
Conduit is offline   Reply With Quote
Old 06-26-2001, 10:47 PM   #8
aarneson
Member#: 3383
Hey thanks for the replies, MBX email me on what you find out if you don't mind. take care - Arne
How can you see if an AP is married to an ECU without hooking it up to a car? casurfballa Engine Management & Tuning 3 09-22-2005 06:17 PM
When is an ECU reset no longer needed? Thunder Lungs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2003 12:43 PM
Can you do an ecu reset with the utec still plugged in? waitandbleed92 Engine Management & Tuning 4 03-31-2003 03:49 PM
Easy way to do an ECU reset. omahasubaru Normally Aspirated Powertrain 2 08-31-2001 07:49 PM
('93-'01) Does an ECU reset change the way an auto tranny shifts? subymamma Impreza Forum 14 05-18-2001 11:44 AM
