Old 06-25-2001, 10:20 PM   #1
DaveK
Member#: 2338
1988 323 GTX
black
Question Acceptable offset for a race only rim
I know all about the offset debate for oem or closed to oem sized tires, but this question is more towards undersizing. To add to this, the new search function won't allow searches for anything under 4 characters, so searching for any info on a "43" offset won't work
I came across a set of used Speedline 5 spoke 15X6.5" wheels with an offset of 43. I know for a street tire this offset would result in rubbing.
Here's my question: if I were to put 225/45/15 kumho extca victoracers (not released yet that I know of) would I end up with rubbing? These tires will overall be about 1.5-2" shorter than my snow tires 195/65/15 (on subaru steelies).
Car stats: DMS golds with ~ 1" drop
Any help would be appreciated. Thanks.
DaveK is offline   Reply With Quote
Old 06-26-2001, 09:51 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
The 225/45-15 is nearly 2" less diameter, no I seriously doubt it would rub on a 15x6.5 +43.
I wouldn't use that wheel personally. Your scrub radius is going to be pretty ugly, not to mention the load on your already less-than-bulletproof Subaru wheelbearings.
Argh! The <a href=http://www.tolan-hoechst.com/cars/tirecalc.htm>wheel & tire combo calculator</a> is down. Damn, I hope not for good... I knew I should have snagged a copy of the source and hosted it myself. Well anyway, I don't want to crunch the numbers by hand right now but this combination wouldn't be desirable to me.
ColinL is offline   Reply With Quote
Old 06-26-2001, 02:17 PM   #3
DaveK
Member#: 2338
1988 323 GTX
black
I forgot to add my allgnment specs:
-1.9 camber up front 1/8" total toe out
-1.3 camber in the rear
Colin or anyone else:
when you say this is bad for the wheel bearings, is this only if these are used for street driving, or would the bearings be ok if this was used exlcusively for auto-x (ie about 2 miles per race day?) Thanks.
Old 06-26-2001, 02:18 PM   #4
DaveK
Member#: 2338
1988 323 GTX
black
Oops, I forgot to ask, what is the scrub radius?
2007 STI, acceptable start for a race car? Virgil Motorsports 20 10-30-2009 09:05 AM
AccessPORT will only accept maps for an automatic transmission NaSTI25 AccessPort 2 06-30-2008 11:48 AM
Acceptable size for 18" rims? djchang84 Newbies & FAQs 19 09-05-2006 04:11 PM
Acceptable offset range for '00 Outback BrokenCrank Tire & Wheel 1 09-04-2003 10:30 AM
Acceptable offset. (Did search!!) Tats Brakes, Steering & Suspension 10 05-18-2001 04:54 PM
