Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 10-31-2004, 05:53 PM   #1
yeager
Member#: 39121
2004 sti- URstg3
psm
Default utec engine-kill map
question :
last night i left my car (sti) parked in a garage and apparently i left the map selector on '7'- the map that completely disables the engine (flashing CEL, no start). apparently, they had to move my car and couldn't figure it out, so it seems they connected the terminals together under the steering column (puts it in some type of test mode - same as when you flash the ecu with an AP). i disconnected them. After starting the car, i now have a nice flashing cruise light all the way back from NY to CT. the car drives fine, but i'm curious as to why it would cause this... what exactly does the immobilize map do (no fuel? no spark? dumps fuel?)
anyhow, i did a good ol' fashioned neg-terminal disconnect reset. flashing cruise is gone (hopefully for good). i searched and found that the flashing cruise could be an O2 sensor code.
any ideas?
many thanks in advance.
eric
yeager is offline   Reply With Quote
Old 10-31-2004, 06:26 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You could get the code pulled at Autozone and see what it was/is......and if it dosen't come back....all's good....
Uncle Scotty is online now   Reply With Quote
Old 10-31-2004, 06:33 PM   #3
yeager
Member#: 39121
2004 sti- URstg3
psm
thanks for the reply, i think i will take it over to my mechanic and see if there is still a code to read. i'm just curious as to what in that immobilizer map could cause a cel/flashing cruise to be triggered. hmmmm.
Old 10-31-2004, 06:56 PM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Did they get it started?
PaulRex is offline   Reply With Quote
Old 10-31-2004, 06:59 PM   #5
yeager
Member#: 39121
2004 sti- URstg3
psm
i don't think they did. they pushed it so it wouldnt be in the way. whoops.
i was not about to leave my car on the street in Queens.
Old 10-31-2004, 07:02 PM   #6
TurboXS (Pete)
Member#: 16704
The security map disables both fuel and ignition. i.e. no fuel and no spark.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 10-31-2004, 07:06 PM   #7
yeager
Member#: 39121
2004 sti- URstg3
psm
thanks pete.
Old 11-01-2004, 09:16 AM   #8
jayblizzo
Member#: 58957
2010 WRX STI
SSM
regards
Pete
(TurboXS)
kool. so i should hide the remote map switch?
jayblizzo is offline   Reply With Quote
Old 11-01-2004, 01:27 PM   #9
yeager
Member#: 39121
2004 sti- URstg3
psm
so, just had the codes pulled:
o2 sensor (low temp?) rear
then o2 sensor, front
***? could something like cranking my car while in 'kill mode' ruin my o2 sensor(s)?
any advice o2 sensor gurus? are these critical when using a utec?
thanks again.
Old 11-01-2004, 02:24 PM   #10
yeager
Member#: 39121
2004 sti- URstg3
psm
new o2 sensors for yeager? the obd scanner did show the o2 sensors were working, but i'm not sure what type of voltage i should be seeing.
Old 11-01-2004, 03:41 PM   #11
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
The front O2 sensor is the most critical piece of drivability equipment on your car. Seriously. It will not drive riht without it, and you would KNOW if it was shot badly, as you would be in limp mode.
The rear is an emissions tool.
Perhaps they cranked the car for a very long time in kill mode, and the UTEC blocks the O2 sensor outputs to the ECU in security mode. Clear the codes, and then just see if they come back. If they don't, like Scotty said, it's no harm, no foul.
-Sean
big_adventure is offline   Reply With Quote
Old 11-01-2004, 04:26 PM   #12
yeager
Member#: 39121
2004 sti- URstg3
psm
-Sean
thanks for the input, sean. the car is running good. a little too good
my only concern is the flashing cruise. i have reset the code once with a battery disconnect, then again with the OBD scanner. came back both times. BTW I have a PEP MIL eliminator on the rear sensor, not sure if it makes a difference.
should i replace the sensor? that light is disconcerting...
UTEC w/ EVERYTHING + Map sw: 02-05 WRX $315 OBO || Cams & Engine Mounts for 2.0 CHEAP Fongers Engine/Power/Exhaust 1 11-22-2008 09:13 PM
UTEC w/ EVERYTHING + Map sw: 02-05 WRX $315 OBO || Cams & Engine Mounts for 2.0 CHEAP Fongers SCIC Private Classifieds 1 11-22-2008 04:54 PM
Where 2 start with a jdm utec/engine w/maps? serious Engine Management & Tuning 1 10-18-2004 07:44 PM
utec stage 4 map and stage 4 tmi map the same? datdudedennis Engine Management & Tuning 4 03-18-2003 11:37 PM
TXS UTEC Stg. 4 map vs. Stg. 4 map w' TMI? S-1 Engine Management & Tuning 2 10-24-2002 06:24 PM
