Old 06-26-2001, 12:08 AM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Question Anyone know where I could find a DOHC 2.5L dyno graph?
I'm fiddling around with shift points that would (theoretically) be optimum on the track. Unfortunately, the only dyno graphs I have are from SOHC cars, which have a considerably different power curve, and a lower rev limit. Anyone have a DOHC dyno graph?
Thanks,
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-26-2001, 09:24 AM   #2
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
I asked this question a couple of weeks ago but to no avail. I'm also looking for a graph of the power curve for the phase I engines for optimal shift points as well. If you have any luck finding it on the web, let me know.
Thanks,
Jason
2.5GT is offline   Reply With Quote
Old 06-26-2001, 02:14 PM   #3
dscottf
Member#: 3312
1999 Outback Wagon
Sapphire Blue
Cool You mean like this:
dscottf is offline   Reply With Quote
Old 06-26-2001, 03:05 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Keep in mind the gear ratios when you go to figure it out. You could shift into peak torque on the next gear, but your multiplied torque at the previous gear may have been higher for quite a while still after shifting.
Old 06-26-2001, 04:06 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Thanks, dscottf, that's perfect!!
You are correct, 8, but you can actually figure this out without having to actually calculate torque to the wheels. Check out this thread http://www.corner-carvers.com/forum/...ML/000353.html , in particular the second post. In that post is a link to http://www.boostaholic.com/supra/shiftpoints.html , which is an example of how to work out the shift points the easy way.
Looks like I've got a project to fiddle around with this evening.
Pat
Old 06-26-2001, 04:22 PM   #6
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Does that go for the 99' Legacy's with the DOHC, and the phase 2 block? My fathers car has one, boy would that make one cool engine build! Yummmmm....big N/A power!
Later,
Seth E.
Ru fan is offline   Reply With Quote
Old 08-22-2001, 11:49 PM   #7
m750
Member#: 2278
8Sti | 07 allez
White | Comp
pat, did you find the proper shift points, and how did you find them?
AO
m750 is offline   Reply With Quote
Old 08-24-2001, 08:14 PM   #8
Blindeye_03
Member#: 4418
2016 Focus ST
I would like to know aswell...
-justin
Blindeye_03 is offline   Reply With Quote
Old 08-25-2001, 12:34 AM   #9
Pilot
Member#: 513
Well, based on the graph that dscottf posted, for the DOHC motors the proper shift point is....drumroll please....redline! For every shift. I guess it's due to the narrower torque band (relative to the SOHC's torque band).
Pat Olsen
No, I'm not Pilot
Pilot is offline   Reply With Quote
Old 08-26-2001, 12:13 PM   #10
Blindeye_03
Member#: 4418
2016 Focus ST
As far as I knew the torque curve was about the same. And what is even stranger, why is the SOHC rated @ higher torque output?
-justin
Old 08-26-2001, 10:28 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
It's rated at a higher torque output because....uh....it has a higher torque output. Not only does it have a higher torque output, but it has a broader torque band. I worked out shift points using the dyno graphs that Cobb Tuning had posted last year, and for the SOHC engine you only need to redline it for the 1-2 shift. After that each shift drops a bit more in RPM.
I'd be interested in seeing the SOHC and DOHC dyno graphs laid over each other to more clearly show the difference.
Pat
Old 08-27-2001, 03:01 PM   #12
Blindeye_03
Member#: 4418
2016 Focus ST
This seems sooo odd to me...I always thought that DOHC engines were inherently better than their SOHC counterparts (ie: d16 series hondas vs b16 series engines).
-justin
Old 08-27-2001, 06:00 PM   #13
m750
Member#: 2278
8Sti | 07 allez
White | Comp
thanks pat, I completly forgot to 1. check this post again, and 2 to ask you face to face.... Doh'
I'm not a huge drag fan, but I do want my car to be as fast as possbile.
AO
Anyone know where I can find these at PSM_02_WRX Mid Atlantic Impreza Club -- MAIC 10 06-02-2010 08:16 AM
Anyone know where I could find an XT? nomorepoison Mid Atlantic Impreza Club -- MAIC 9 03-13-2010 02:53 PM
Does anyone know where I can find a 2 gauge pillar pod for 60mm guages? D Money Interior & Exterior Modification 1 03-11-2007 02:02 PM
Anyone know where I can find an AWD Dyno.. ScoobyNubieToo! Tri-State Area Forum 5 01-18-2005 12:07 PM
Anyone know where I could find a P1 Impreza front spoiler, real or replica? 4wheelmotion Interior & Exterior Modification 3 10-16-2000 07:29 PM
