Old 10-31-2004, 10:54 PM   #1
Immerkuhl
Member#: 51358
2007 FXT
Once a month its blue.
Default Right turn grind
when i turn right - at speed, or when accelerating from a stop i get a grinding noise. any ideas?
Immerkuhl is offline   Reply With Quote
Old 10-31-2004, 10:56 PM   #2
Handsdown
Member#: 29355
i got one...
you have a suspension problem?
http://forums.nasioc.com/forums/forumdisplay.php?f=32
Handsdown is offline   Reply With Quote
Old 10-31-2004, 11:02 PM   #3
Immerkuhl
Member#: 51358
2007 FXT
thanks, i'll get that checked out. anything else that might cause this noise that i should have looked at?
Old 10-31-2004, 11:13 PM   #4
Handsdown
Member#: 29355
your wheels could also be the culprit.
http://forums.nasioc.com/forums/forumdisplay.php?f=88
what i'm trying to say here is that the fact you have a naturally aspirated engine probably has very little to do with the fact you get a grinding noise.
check your axels, and CV boots if you think it isn't suspension related. other than that, i can't really help you.
Old 10-31-2004, 11:15 PM   #5
Immerkuhl
Member#: 51358
2007 FXT
stock wheels - '03 2.5TS. no mods yet. tire inflation up to spec.
Old 10-31-2004, 11:16 PM   #6
Handsdown
Member#: 29355
unmodded? take it to the dealer. they'll fix it under warrenty unless you have more than 30k miles on it.
Old 10-31-2004, 11:20 PM   #7
Immerkuhl
Member#: 51358
2007 FXT
thanks for your help. i'll drop it off there and have em fix it. hell i just bought it.
Rear wheel grinding when making only right turn?? ScoobySnacker Brakes, Steering & Suspension 2 09-04-2008 12:39 PM
Rear Right wheel grinding MyRad25rs Tire & Wheel 6 05-22-2005 06:48 PM
grinding sound on right turns not CV joint MRF582 Brakes, Steering & Suspension 5 01-08-2005 09:20 PM
steering wheel is rattling on hard right turns scootr Normally Aspirated Powertrain 10 02-17-2001 12:02 AM
ne1 solve the fuel stravation in right turns problem? Bassem Normally Aspirated Powertrain 14 12-06-2000 08:03 AM
