Old 11-01-2004, 07:24 AM   #1
hernan
Member#: 51477
Default What should I get first, tuna or UTEC?
I have recently blown my motor (rod bearings). I have been running a bit more boost (18psi w/AVCR) with forged pistons, upgraded fuel pump, adjustable FPR, catless exhaust, FCD, stock ECU. I don't know if I blow the bearings from det or just bad oil or a combination of both.
I live in Argentina and the only practical tuning solution is the UTEC (AU version). I'm planning on getting a Utec with the turner, as I will have to tune it by myself.
I'm a bit short of cash by now after paying for the rebuilt and I'm thinking on getting one product at a time.
What should I get first?
Many people have used the Utec alone, just loading the staged maps with no problem. Is this a "safe" option? Is the Utec datalogging and knock detection enogh for tuning?
Getting the Tuna first do nothing for the car performance but is always nice to know how you are running and if knocking is present. I could still "play" a bit with boost and fuel pressure if I know my AFRs until I could get my hand on the UTEC. (I have boost and Egt gauges)
What do you think?
hernan is offline   Reply With Quote
Old 11-04-2004, 08:32 AM   #2
hernan
Member#: 51477
Anyone?
Old 11-04-2004, 09:44 AM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Well.... the tuna will just tell you if you have a problem from fueling or knock. Kinda moot without the means of correcting for it.
So honestly, if you're going to get one, get both.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 11-04-2004, 11:29 AM   #4
hernan
Member#: 51477
Jorge (RiftsWRX)
www.ProjectWRX.com
Thanks, right way of thinking.
One more question: How about getting a knocklink device and then just the Tuner (not the Tuner Pro)?
Old 11-04-2004, 05:29 PM   #5
03WRXMA
Member#: 35081
2012 WRX
This will once again allow you to monitor both fueling/internal conditions, but do NOTHING to change them.
ie. add fuel if you are running leaning, cut timing if you see knock.
03WRXMA is offline   Reply With Quote
Old 11-04-2004, 09:11 PM   #6
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
End user adjustable engine management without a wideband 02 sesnor is like having a Ninja Motorbike and no eyes
You dont need a tuna - but you need access to a wideband to do your tuning - (unless you have a lof of experience and know how to read spark plugs)
Dyno Flash is offline   Reply With Quote
Old 11-05-2004, 05:51 AM   #7
hernan
Member#: 51477
This is why I asked the first question. As Jorge has said, getting both is the right thing. I have no "practical" access to a WB, then I prefer to get the tuna. I am running an EBC. This is why I thought that getting the tuna first could be a nice way of monitoring the car AFRs and knock with the increased boost.
Old 11-06-2004, 08:04 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hernan,
imo, if you know you're going to get both, get the tuner first. hook it up, run on it for a while, get it configured to read rpm...
i am working on a small circuit to adapt the tuner pro's additional analog logging input to a thermocouple, so that you can read egts, intake temps, oil temps, coolant temps, etc. if you're handy with a soldering iron, we're talking about 20 USD worth of parts for the electrical portion.
having the tuner hooked up will let you play with the wideband afr logging, and the built-in knock sensor amplifier will allow you to listen to how your engine sounds. getting the tuner first and using it to collect baseline information before you start tweaking isn't a bad thing. no one has EVER broken their engine from using a tuner without a utec, but PLENTY have the other way around!
imo, the txs basemaps are so generic they are useless, at least in terms of fueling. you might as well just run "normal" (ie non open loop) fueling and let the oem ecu control things, set your offsets to zero, and leave the utec out of it if you don't have a way of tuning fuel yourself... and as you know without a wideband you're shooting in the dark.
i would spend the money and get the tuner _pro_, btw. the extra analog and digital inputs along with the detcans makes it more than worth it for me.
hth
ken
Old 11-06-2004, 01:22 PM   #9
happasaiyan
Member#: 37731
if only one at a time, tuna first...
...but preferably both at the same time.
happasaiyan is offline   Reply With Quote
what should i get first? bugeye-joemomma Brakes, Steering & Suspension 17 01-17-2009 02:59 PM
what should i get first for PS3??? ODiz413 Off-Topic 35 10-11-2007 01:05 AM
What should I get first? Springs or Swaybars? volkl23 Brakes, Steering & Suspension 19 05-18-2007 09:07 PM
what should i get first, gauges or AP? jojotherider AccessPort 10 07-30-2006 09:16 AM
What should I do first? Turbo, or FMIC setup? GMTarkin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-22-2004 10:29 AM
