Old 11-01-2004, 11:35 AM   #1
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Lightbulb Figured out a new use for the AccessPort *Oil change*
OK this isn't earth shattering, but I think it is pretty clever.
When you change the oil you leave portions of the oil system with air in it, even if you prime the oil filter which most people don't do. The best way to avoid the "new oil piston slap" is to crank the engine over without it starting.
1. change oil and filter
2. Load the antitheft B real time map.
3. Crank the car for 30-60 seconds ( Map wont let the car start)
4. Load your regular Real time map.
5. Start the car with the oil system primed!
Valhakar is offline   Reply With Quote
Old 11-01-2004, 12:12 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, I used to turn off the injectors on my Haltech every time I had to replace/rebuild my motor, specifially to prime the oil and pump up the fuel system.
Old 11-01-2004, 02:47 PM   #3
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Or simply unplug one of the three large engine harness connectors in the engine bay. Two by the battery and one by the turbo.
Clark
Kingpin is offline   Reply With Quote
Old 11-01-2004, 04:32 PM   #4
hondaeater69
Member#: 60324
good for turbo changes too!!
Old 11-01-2004, 04:37 PM   #5
happasaiyan
Member#: 37731
yep...
ive used the UTEC "7" map switch for such occasions as new turbo and oil changes.
very convenient.
happasaiyan is offline   Reply With Quote
Old 11-01-2004, 04:38 PM   #6
jdchmiel
Member#: 926
isnt this what the efi fuse is for?
jdchmiel is offline   Reply With Quote
Old 11-02-2004, 02:08 AM   #7
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
30 to 60 seconds is too much for your starter all at once.
santofontana is offline   Reply With Quote
Old 11-02-2004, 05:05 AM   #8
roadtalontsi
Member#: 64572
9310 supra, c63
white, matte silver
true dont crank a starter for over 15 seconds. then allow a good 30 seconds for it to cool off. Starters are dead shorts thus if you crank for 30-60 seconds you may just melt or weld some starter components rendering it useless. Clever idea though with the oil priming.
roadtalontsi is offline   Reply With Quote
Old 11-02-2004, 07:20 AM   #9
Valhakar
Member#: 39514
Mostly Blue
I usually give it 10 seconds, 3 times with a few seconds in between.
As for the connectors and EFI fuses, what a PITA. AP plugs in to the ODB-II port and takes 10 seconds to flash a realtime map.
Old 11-02-2004, 08:29 AM   #10
pezman04wrx
Member#: 66558
Good call ... That certainly beats trying to crank the car and not have it start up ... ... Really though, good find ...
pezman04wrx is offline   Reply With Quote
Old 11-02-2004, 01:33 PM   #11
jayblizzo
Member#: 58957
2010 WRX STI
SSM
what good does it do vs not doing it?
jayblizzo is offline   Reply With Quote
Old 11-02-2004, 01:39 PM   #12
Valhakar
Member#: 39514
Mostly Blue
It is recomended you fill the oil filter up with oil before installing it to reduce the dry sump issues. Even when you do this, there are other areas through the oil system that have air in it.
Cranking the engine but not letting it start purges the air and lets the whole engine get oil before you add any real load by starting it.
As for what can happen? Worst case? You knock a few thousand miles off the engine life every time the engine catches before the oil gets to it. You hear that ugly "clack clack clack" till the oil reaches it. Remember our pistons are laying on their sides.
Old 11-02-2004, 03:46 PM   #13
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Sounds good but: I run the engine before draining the oil so all the piecy parts have a oil coating. Plus I don't let it drain all day when I change the oil. If you watch oil pressure gauges you'll see very little difference in the time it takes the oil to build pressure compared to any other cold start.
WRX03 is offline   Reply With Quote
Old 11-02-2004, 06:42 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you want horror stories of "big ends" failing after oil changes, go visit scoobynet.
Old 11-03-2004, 07:57 AM   #15
Valhakar
Member#: 39514
Mostly Blue
When you drain the oil, you leave air in the system. There is significant latency in the oiling of the car as it purgest the air.
Exactly. Better safe than sorry. Why add wear to the engine?
Old 11-03-2004, 11:45 AM   #16
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Thou are quite concernedst with the longevity of thou engine.
mexicanpizza is offline   Reply With Quote
Old 11-03-2004, 11:48 AM   #17
Valhakar
Member#: 39514
Mostly Blue
Yes I am. 2003 WRX bought in March 2003. 39K miles. I run a very conservative stage 2. I expect the engine to go 150K at least.
Old 11-03-2004, 01:04 PM   #18
ScoobyNights
Member#: 68619
03 WRX
There is enough lubrication to prevent any wear if you 1)warm and run the engine before draining, 2) drain the oil quickly, 3) start the engine after filling, and 4) not rev the engine at first start up.
I see this benefitial if you don't do above, rebuild an engine, or the engine has sat for a long time.
If this is so important you might as well do it for every cold start, because you'll get more wear from all those than an oil change.
ScoobyNights is offline   Reply With Quote
Old 11-03-2004, 01:11 PM   #19
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
good point.
Bishop is offline   Reply With Quote
Old 11-03-2004, 07:03 PM   #21
ScoobyNights
Member#: 68619
03 WRX
I must concede SOME on the topic after doing some reading, but are we comparing apples to oranges here? Was it truely an oil change problem(s) or something else?
Also I would say that hardly anyone or company goes through this process for an oil change. Why then here in the US are we not having main bearing failures? I haven't seen a post about it? In addition why are there so many flat 4 Subaru's running around with high mileage?
I'm not saying it's a bad ideal, but do you really believe it does any damage and that you are going to spin a bearing if you don't?
Old 11-03-2004, 09:13 PM   #22
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if it bothers you, don't do it.
you have to promise that when you have a bearing problem you'll post about it here though... just so we can add you to the list.
Old 11-03-2004, 09:21 PM   #23
5spdfrk
Member#: 46407
blew
I couldn't get teh drain plug out, but I could get the filter off. So, I just cranked the car up and let it run, until all the oil came out from where the filter was. Worked like a charm.
5spdfrk is offline   Reply With Quote
Old 11-03-2004, 09:30 PM   #24
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
is this a troll?
you CAN'T be serious...
Old 11-03-2004, 11:14 PM   #25
Bishop
Member#: 59993
Ass, grass or cash
i remember that thread
cannot figure out this exh rattle for the life of me! dLo R6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-29-2009 06:24 PM
Check out this new bumper for the 06 STi 9! wrxdriver83 Interior & Exterior Modification 44 01-04-2007 12:57 AM
Using Subaru for the standard oil change Steveee Warranty Issues & SOA Problems 6 12-11-2006 09:15 PM
New use for your Cobb AP (Oil Change) Valhakar Mid Atlantic Impreza Club -- MAIC 7 11-01-2004 02:06 PM
We need to figure out where to meet for the caravan... delectron Bay Area Impreza Club Forum -- BAIC 5 03-25-2000 06:52 AM
