Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-26-2001, 04:10 AM   #1
imprezaej25
Guest
Member#:
Default pulley
I am having trouble taking off the stock pulley, can anyone help me out?
Old 06-26-2001, 10:25 AM   #2
steve_d
Member#: 315
You need about 200 ft-lbs to break it loose. the trick is holding the pulley.
all it took was the special tool and a bigger breaker bar....
ps. the special tool didn't work on my MY98....the hole pattern in the pulley was different than the tool...very odd....I don't know how the shops do it...there's not a whole lot of room in there...
you'll get more room if you take the fans off.
loosen but do not remove the bottom bolts...there's two...the fans are slotted to slip into place...the fan plug is at the bottom also. remove the two top bolts and the passenger side radiator stay.
on the drivers side, you have to take the overflow bottle off. it's just the top two bolts.
everything comes right out.
sjd
steve_d is offline   Reply With Quote
Old 06-26-2001, 04:25 PM   #3
imprezaej25
Guest
Member#:
Thanks very much, I will try it out
Old 06-26-2001, 06:46 PM   #4
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
I know this may sound silly, but make sure you are turning it in the right direction. You unbolt it by turning counterclockwise. It is set up so that the bolt tightens while the engine turns. You can check this by bumping the engine over with the starter. The instructions in the Mods section make this clear. They say unbolt counterclockwise.
A buddy of mine and I had this problem. We printed out the directions and it cut off the counter part of counter clockwise.
Just get someone to sit in the car. Put your ratchet (a breaker bar would be better) on the bolt, Stick a big piece of pipe (like a 5 foot piece of galvanized), get someone to sit in the car with the breaks on, and crank away as hard as you can. It will come loose.
Suba_Roo is offline   Reply With Quote
FS : JDM 660cc Injectors-GFB Lightweight Pulleys-AEM Wideband-Various Turbo Gauges-MORE! Audioexcels Engine/Power/Exhaust 37 11-02-2010 03:34 PM
pulleys, pulleys and more pulleys msingell Transmission (AT/MT) & Driveline 5 12-23-2007 12:27 AM
Which pulley, N1 three pulley or Cobb Pulley NNeves Normally Aspirated Powertrain 24 04-13-2002 03:38 AM
Part #'s for stock pulley belts...removing UR pulley SFsube Technical Forum Archive 4 08-26-2000 10:46 PM
Pulley sizes for all models and the UD pulley MPREZYA Technical Forum Archive 0 08-14-2000 01:06 AM
