Old 11-01-2004, 09:31 PM   #1
markk26
Member#: 54698
1997 Legacy GT
red
Default head bolts
After i changed head gaskets...should i get brand new head bolts or can i re-use the same ones?
i know head bolts are not re-usable , dont know about Subaru's
And , doea anyone has a tric to torque head bolt properly whit and engine out of the engine bay?...whit no engine stand?
thanks
markk26 is offline   Reply With Quote
Old 11-01-2004, 10:34 PM   #2
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Most people (including some certified subaru mechanics) reuse the subaru headbolts, but replacing them is still not a bad thing to do.
With the engine out, you should definately place the engine on the ground or something. Hanging from a chain, it would be really hard to torque the bolts. Try finding an old tire or something similar to place the engine in so that it can sit without the oil pan hitting the ground. You don't want the weight of the engine resting on the oil pan, but it's fine to place weight on the base of the block.
j
ilmaestro is offline   Reply With Quote
Old 11-02-2004, 04:37 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
they don't need to be replaced, just follow the torqueing procedure and you'll be fine
Old 11-02-2004, 06:57 PM   #4
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Reuse the head bolts? I've been brought up being told *never* to do that. According to what I know about materials engineering, those bolts are designed such that they can only be put through the torquing procedure once. The second time, they either stretch too much resulting in a leak or break off resulting in copious use of the f-word. Maybe they use different bolts or materials now, but I would wholeheartedly recommend replacing them. Besides...what's a set cost? $20?
Al_Smokemcrack is offline   Reply With Quote
Old 11-02-2004, 07:58 PM   #5
markk26
Member#: 54698
1997 Legacy GT
red
ok , so i can re-use them and absolutly not....
riiiight....very clear.
lets be democratic....nah!...i'll check whit the dealers mecanics.
And i think a complet set goes for around 50 bucks.
Old 11-02-2004, 07:59 PM   #6
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
thats not true. they are reusable. they are not like a gasket that crushes under impact. haha!
darioc is offline   Reply With Quote
Old 11-02-2004, 08:21 PM   #7
dkl
Member#: 63096
1998 2.5RS
Green
Also, not that I suggest dropping the whole engine on it, but Subarus are unique in the fact that you can put some weight on the oilpan. I've jacked up engines by the oilpan many times. My vote goes for reusing the headbolts, assuming no other circumstances precluding it.
dkl is offline   Reply With Quote
Old 11-03-2004, 07:14 PM   #8
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
The bolts stretch. You shouldn't reuse them. You're asking for a leak.
Old 11-04-2004, 03:10 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
you sir are incorrect the bolts are DESIGNED to stretch multiple times, i have done many many many headgaskets w/o replacing bolts(unless it a 88-92 civic engine that needed headbolts that DO stretch on purpose). They'll be fine if they are reused.....trust me, if you are worried about it there is a procedure to measure the diameter of the bolts to verify that they are or aren't in specification, if they are no longer in spec then obviously replace them, but for FWIW i've never seen a car that needed a new set.
jeremy
Old 11-04-2004, 08:57 AM   #10
quantum
Member#: 73416
05 CTS-v
Stealth Grey
I don't know about subarus, but I've rebuilt a bunch of chevys and I've never had a problem reusing the head bolts on them. And I think the head bolt torque specs for a all iron 350 are greater than that of the aluminum alloy subaru ones. Unless the manufactureer of the bolts says otherwise I don't see why reusing them would be a problem. But like I said I don't know subaru's that well yet.
quantum is offline   Reply With Quote
ARP head studs V's OEM sti head bolts bugeyes Built Motor Discussion 89 11-08-2016 08:50 PM
Re used head bolts... caused head gasket to blow again? brian3676 Normally Aspirated Powertrain 14 05-01-2008 08:00 AM
WTB: ej257 gasket kit, ARP head bolts and case bolts 69_Lex Private 'Wanted' Classifieds 3 02-20-2008 11:38 AM
Can I reuse block bolts/head bolts Tattoo Collector Normally Aspirated Powertrain 19 01-22-2005 02:35 AM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 08:30 AM
