Old 11-02-2004, 11:16 AM   #1
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Default 95 Impreza L w/ 2.2L engine won't rev over 4100 RPMs - any thoughts?
Checked MAF sensor, replaced O2 sensor, replaced plugs and wires, replaced Camshaft Positioning Sensor, running good gas...Car stopped revving over 4100 rpms!
Could it be a Crankshaft Positioning Sensor? Feels like the car's running really rich and smells like it too.
Only mods are a cold-air intake, and WRX catback exhaust.
Any suggestions are greatly appreciated!
//marcus
marcus12 is offline   Reply With Quote
Old 11-02-2004, 12:28 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Had a similar problem with an 84 RX-7 GSL-SE. The cat was up to about %25 backpressure.
Does it hit a wall at 4100, or kinda creep up there and not run well?
DLC is offline   Reply With Quote
Old 11-02-2004, 01:04 PM   #3
rabbitnutz
Member#: 51940
could it be in limp mode ? try resetting the ECU by removing the negative battery cable for 10 minutes, and before you put it back on, step on the brakes a few times.
rabbitnutz is offline   Reply With Quote
Old 11-02-2004, 01:44 PM   #4
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
DLC - it just hits a wall - like it's topping out. The engine shakes really hard and the car bucks until I let off the gas.
rabitnutz - have tried to reset ECU multiple times to no avail.
Oh, more info - looks like I have a CEL with two codes:
17 and 23 for OBD-I. I think they are Cylinder 3 misfire and MAF sensor respectively. MAF checked out fine and the replacement of spark plugs and wires should've taken care of the cylinder 3 misfire.
Any other thoughts guys?
//marcus
Old 11-02-2004, 10:42 PM   #5
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
Any mods?
RyansJDMgc8 is offline   Reply With Quote
Old 11-03-2004, 09:39 AM   #6
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
just a cold-air intake filter w/adaptor for my stock intake tube and a WRX cat-back exhaust. Everything else is virtually stock.
I wish it were as simple as a bad MAF sensor, but when plugged in, the car works fine. When I unplug the MAF sensor, the car sputters and stalls. So I'm assuming it's working properly, otherwise the car would sputter and stall all the time.
thanks
//marcus
Old 11-03-2004, 11:09 AM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I think the problem is you need a new shortblock... definitely an ej22T and maybe a vf22 too.
jamesfacts is offline   Reply With Quote
Old 11-03-2004, 11:10 AM   #8
jamesfacts
Member#: 51282
98 RS
Seriously, though: coil-pack?
Old 11-03-2004, 12:14 PM   #9
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Clear the codes out, reset the ECU if you haven't and see if you can get a different coilpack and even an ECU. It does almost sound like it's hitting the rev limiter, wierd.
Old 11-03-2004, 06:09 PM   #10
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
I can grab a coilpack for cheap, so I'll try that out, thanks for the suggestion!
AmericanYouth - I had an EJ22T longblock and TD04, but decided to go with a ring for my girl...I shoulda turbo'd my car - it woulda been more fun
//marcus
Old 11-03-2004, 09:57 PM   #11
jamesfacts
Member#: 51282
98 RS
Yeah I know. It was a joke... G/L w/ the na - let me know if you need a hand.
Old 11-17-2004, 10:59 AM   #12
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Hmmm...any more thoughts?
//marcus
Old 11-17-2004, 02:07 PM   #13
Pocon
Member#: 17479
1999 Impreza WRX
Silverthorn Metallic
Have you tried cleaning your injectors?
Pocon is offline   Reply With Quote
2.2l Engine whistle at high RPM boyleia1 Normally Aspirated Powertrain 11 10-24-2007 04:37 PM
FS: Red 95 Impreza L Coupe - 2.2L AWD, 4EAT Ghomer1 MAIC Private Classifieds 27 03-02-2007 02:25 PM
Replacing a 2.2L engine in a 95 Impressa Mowatimp Normally Aspirated Powertrain 4 08-12-2005 12:03 PM
P1544 and motor won't rev over 2K rpm? KJR Engine Management & Tuning 4 09-17-2004 11:50 AM
Guaging interest in 95 Impreza AWD Coupe 2.2L marcus12 Private Vehicle 'For Sale' Classifieds 13 11-12-2003 04:57 PM
