Old 11-15-2004, 02:45 PM   #1
WRXerist
Member#: 20235
2006 FX45
Default Noise from engine when weather is cold
It just happened recently. I don't know if it is the fan belt that's causing this problem or something else. I have a set of AEM aftermarket pulley set installed awhile back but never had a noise problem. When the car is warm, it goes away. What can I do to remedy this problem? The sounds it produces is a shreeking sound and goes higher when I gas the accelerator.
WRXerist is offline   Reply With Quote
Old 11-15-2004, 02:48 PM   #2
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Sounds like either a belt or a pulley bearing is going. Change your accessory belt and see if it goes away, then the timing belt. If it's still there, check the pulleys.
Al_Smokemcrack is offline   Reply With Quote
Old 11-16-2004, 10:12 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Set your belt tension correctly. The anodizing on the pulleys is slippery so the tension may need to be tighter than normal. Perhaps a new set of accessory belts would help.
You can isolate the problem with a mechanics stethascope. I got mine at sears. If it is a bearing the sound usually does'nt go away.
Tim Sanderson is offline   Reply With Quote
Old 11-17-2004, 12:14 PM   #4
WRXerist
Member#: 20235
2006 FX45
Thanks for the suggestions. I will it out today and see if it is any of those problems. It is very annoying to have a great car sounding like a broken down car.
Popping noise...worse when it is cold out? Mystery Machine Brakes, Steering & Suspension 7 03-28-2011 03:38 PM
Popping Noise From Exhaust, When I Rev Engine 06WRX_GUY Newbies & FAQs 43 04-28-2009 11:02 AM
Odd squeaking+screech noise from engine bay when dropping to idle forsaken Factory 2.0L Turbo Powertrain 1 03-01-2006 12:02 AM
initial uppipe noise when car is cold. ellinopedo182 Factory 2.0L Turbo Powertrain 2 02-17-2003 01:49 PM
Anyone hear a weird noise coming from engine bay in the cold weather? WRXVII Service & Maintenance 1 12-29-2002 06:13 PM
Message Board Statistics All times are GMT -4. The time now is 03:04 AM.
