Old 11-03-2004, 09:20 PM   #26
STi-MAN
Member#: 70252
05 STI
blue
well there has been 3 dynos out on this intake and all have seen gains of over 11hp, so for me it dyno proven
STi-MAN is offline   Reply With Quote
Old 11-03-2004, 09:31 PM   #27
John Sever
Member#: 22866
2007 Victory
Vegas 8 Ball Black
why doesn't everyone that wants the car to be dynoed again......paypal Aaronwrx the money?.....i think he's done great service to everyone already.
John Sever is offline   Reply With Quote
Old 11-04-2004, 09:10 AM   #28
scooby24
Member#: 56414
2004 Forester XT 5MT
With all this skepticism and negativity towards the dyno results of the Intake, how can you say ANYTHING gives more power?
"I just put on my Catless up-pipe, TBE, and Header and I dynoed 40 hp more"
Skeptic: "No you didn't get ANY power its all the ECU fluctuation. At best I'd say you got 10 hp"
give me a break people.
I had a short ram intake on my stage 2 WRX and consistenly ran 2/10ths of a second faster with it than I did without it. yes that's right...CONSISTENTLY...meaning ECU re-learned. 60' times the same, track conditions the same.
Just admit for once your guys' stereotypes of the intakes just MIGHT be wrong.
scooby24 is offline   Reply With Quote
Old 11-04-2004, 09:42 AM   #29
Tobey
Member#: 21400
2015 WRX Limited
ISM
10,000 dyno charts will not help either. there is no telling some people otherwise...
Tobey is offline   Reply With Quote
Old 11-04-2004, 09:57 AM   #30
soso3
Member#: 36794
89 T I T A N
If we're not going to spend money on an intake, why would we pay someone else to do another dyno run?
Intakes are the debbil!!!!!!!!!
soso3 is offline   Reply With Quote
Old 11-04-2004, 10:03 AM   #31
kedrin
Member#: 48380
Im skeptical because.... well there arent really any good intakes out there for our cars.
I never said the dyno results werent true, i just said they can be misleading sometimes.
kedrin is offline   Reply With Quote
Old 11-04-2004, 10:16 AM   #32
STi-MAN
Member#: 70252
05 STI
blue
i think its good to be skeptical, just not too much.
Old 11-04-2004, 10:18 AM   #33
BryanH
Member#: 993
There aren't any good intakes but this one made 12 whp....what is your definition of a good intake? Is it because its not chromed?
BryanH is offline   Reply With Quote
Old 11-04-2004, 10:40 AM   #34
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Did the intake make the 12whp? Or did the reflash trick that has been known to give 10-20hp higher readings on the dyno do it?
You cant and you shouldnt... maybe if you pulled the motor off and put it on a engine dyno. Chassis dyno are designed to help you tune the car and not measure exact power. http://www.pumaracing.co.uk/power3.htm
http://www.vishnutuning.com/dynos_dont_lie.htm
All some of us are saying is think and dont blindly belive a print out. Some of you take it as a personal atack.
Old 11-04-2004, 11:01 AM   #35
mnavarro
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
I have to say I put this intake on my STI and coupled with a downpipe (no ecu reset) I made 249 horsepower and 240 torque when stock cars are on a mustang dyno stock cars make 220s. You can feel that the car breathes better up top, like it opens it up a bit, even when that was the only mod I had.
mnavarro is offline   Reply With Quote
Old 11-04-2004, 11:08 AM   #36
GotHP?
Member#: 51138
2015 LE STI
Just think about what has physically changed with an intake upgrade. We went from a plastic tube to an aluminum one (which may be a bit smoother). And the filter will have less restriction. But if people are saying 12 whp, that might be 15-16 hp at the crank? Now think about it, isn't that a bit much for this small of a change?? A smoother intake tube isn't that big a deal here, intake air velocity isn't all that high. Unfortunately the ECU response does confuse dyno results and they do need to be questioned.
GotHP? is offline   Reply With Quote
Old 11-04-2004, 01:03 PM   #37
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
Its not just less restriction on the filter (which is a larger change than you'd imagine), its also an increase of filter surface area
SLKWrx is offline   Reply With Quote
Old 11-04-2004, 01:06 PM   #38
scooby24
Member#: 56414
The more air running to the engine the more power it makes. It's a simple theory.
My old car (nissan 200sx se-r) had a similar setup for intake. I dynoed a baseline and then added Hotshot intake. Got 8hp at the wheels. This was a car that is very steady on the ECU and didn't fluctuate power easily. Why wouldn't it make sense that a TURBO car would make 4 more hp at the wheels?
Open up the filter, make the pipe length shorter, remove the silencer, yeah it's gonna make more power. It's not hard to figure out.
Old 11-04-2004, 01:08 PM   #39
Tobey
Member#: 21400
2015 WRX Limited
ISM
you guys can speculate all day long, but the facts are that there are two dyno sheets above showing a gain in HP from an intake change. if you guys want to argue that point, prove your side. until you come with evidence (not opinion) then your argument is junk.
Old 11-04-2004, 01:14 PM   #40
totoherbs
Member#: 7321
.... 122 IggPoints
Prove your side...? I have yet to see proof of anything. Well maybe another confirmation that shivs reset trick works.
Old 11-04-2004, 01:17 PM   #41
scooby24
Member#: 56414
Do we even know they did the reset trick? How do we know the reset trick works on the STi ECU?
Old 11-04-2004, 01:30 PM   #42
totoherbs
Member#: 7321
.... 122 IggPoints
Originally Posted by AaronWRX
The ecu was reset. paypal me some $$ and I can test your theory.
Yes, and yes there are many reports of people using the reset trick.
Originally Posted by DangerousWRX
We also did the perrin light weight crank pully, and that FREE vishnu "How to reset your factory computer for more horse power trick" and it worked just as they said.
http://forums.nasioc.com/forums/show...ht=reset+trick
Old 11-04-2004, 01:31 PM   #43
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
I've been running the K&N for 7,000 miles now, and am very pleased with it. 12whp? I dunno.....wouldn't surprise me, but I'm happy with it in any event. Car felt like it breathed better up top, 5th felt more responsive immediately (I thought I must've been in fourth, honestly, the first time I took her out after the install), and when I got my UTEC in my AFR's were rock solid throughout the RPM band. I've nary a complaint.....and feel it was a solid purchase.
Stu
mindchatter is offline   Reply With Quote
Old 11-04-2004, 01:57 PM   #44
soso3
Member#: 36794
89 T I T A N
Originally Posted by Tobey
until you come with evidence (not opinion) then your intake is junk.
Old 11-04-2004, 02:12 PM   #45
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
I believe it DOES NOT work. I have yet to see concrete proof otherwise.
dsmperformance is offline   Reply With Quote
Old 11-04-2004, 02:47 PM   #46
Tobey
Member#: 21400
2015 WRX Limited
ISM
is pulling the neg battery terminal (resetting the ecu) and shivs 10-20whp ecu / reset trick the same thing? it's common law to reset your ecu after doing a mod, so by theory a 20whp gain from a turboback is only worth... nothing?
Old 11-04-2004, 02:52 PM   #47
scooby24
Member#: 56414
Exactly. Their arguements are pointless.
Old 11-04-2004, 02:56 PM   #48
Mach V Dan
Member#: 12029
Okay, here's my blow-by-blow of the intake install.
Dyno STi, three pulls.
Aaron & Dan and others dink with intake install for a bit. Battery is disconnected during this (as is prudent during any install).
Dyno STi again, three more pulls. All three are higher by 12-13 hp than the first three.
There was no fancy 2600-rpm reset trick done. There was no other trickery or adjustments done. The whole process was witnessed by many bystanders. Assuming that the car actually starts out at only 8 degrees of timing after a cold ECU restart, and then slowly regains its normal timing, it should have been DOWN on power (all other things being equal) after the power being disconnected.
If the graph above doesn't sway you, well, I don't know what to tell you. But I didn't sell this intake before, and now I do, because it looks to me like a pretty clear gain.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 11-04-2004, 03:06 PM   #49
AaronWRX
Member#: 7194
2011 997.2 Turbo
ahem!! i'm right here... There is no need to speculate on what I did or didn't do. If you want to know if I did the ECU reset trick... ask me!
Let's define the ECU reset trick...
"With the car fully warmed up, reset the ECU. ...... Push the go pedal down slightly so boost stays right around 2-4psi. You will need to MAINTAIN 2500rpm and 2-5psi for approx 5 seconds. You can do this by left-foot braking gently as to prevent acceleration."
Now what sane person would think that I would spend my $$ on this product, and dyno time, only to fake myself out with the ecu reset trick? What sane person thinks that K&N R&D read the shiv thread and did the ecu reset trick to inflate their numbers?
Do I work for K&N? Hell no!
Did I do the Ecu reset trick? Hell no, that would have been totally asinine!
Do I have ANY reason to talk up their product? Hell no!
Was I surprised by the results? Hell yes!
Do I wish more Nasiocer's would put up or shut up? HELL YA!
This was done at Mid-A's monthly dyno day event... it wasnt just me and the dyno operator cooking up numbers to sell more K&N's. There were ton's of other Mid-A'ers their to watch ....
My advice to the next guy who tries to provide real data to nasioc... even if the instructions say, "pull the negative battery terminal to avoid damage to you MAF sensor..." ignore that so you can make sure your ECU doesnt reset. If you do that, EVERYONE will be happy and much more accepting of your data.
AaronWRX is offline   Reply With Quote
Old 11-04-2004, 03:12 PM   #50
totoherbs
Member#: 7321
.... 122 IggPoints
See there you guys go thinking its some personal atack... crap life must be hard for you; when every time someone disagrees with you you think its an atack.
We will just have to agree to dissagree on intakes.
WA. FS. K&N Typhoon, stock airbox W/K&N filter lucio Engine/Power/Exhaust 19 11-20-2009 08:13 AM
New SOA-Approved Intake; Dyno Proven +5 hp, +10 lb-ft Jon [in CT] Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 723 08-15-2006 06:58 PM
Looking for dyno proven Exhaust gains Mechkiller31st Normally Aspirated Powertrain 10 03-20-2006 01:24 PM
any dyno proven gains for STi hood scoop? Butt Dyno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-17-2003 10:46 PM
-Dyno Proven custom 2.5RS header- impRSa01 General Forum Archive 7 03-10-2001 10:59 PM
