Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 11-05-2004, 11:12 AM   #76
Mach V Dan
Member#: 12029
(Looks at huge banner ad at bottom of page). Next we should test the Turbonator!
It supercharges any car! I would like a supercharged turbocharged WRX!
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 11-05-2004, 11:35 AM   #77
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Originally Posted by drees
The ECU shouldn't need to relearn fuel if the intake is properly designed as the ECU will get the same amount of air for the same MAF readings. This is what the K&N Typhoon appears to do.
You should be able to swap back and forth without any problems or learning required, the only difference will be increased power.
I thought that the APS 65mm was one of the good intakes that acted like the stock intake?
Why whouldnt it need to relearn a new fuel curve? The intake flows differntly, right? Thats how it makes power, no? Now with a properly designed intake it will let the maf does its job, but they are all going to have some effect on fuel.
Old 11-05-2004, 11:38 AM   #78
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Well, if you do back to back dyno runs as others have and the A/F ratio stays the same, seems to me that there is no significant amount learning required or necessary.
You might get some additional learning at the higher air-flow rates and engine loads as you'll now be encountering those more often.
drees is offline   Reply With Quote
Old 11-05-2004, 11:44 AM   #79
speedypete
Member#: 62012
2004 FXT 5speed
Cobb stage 2
I'm assuming that this was tested on a STOCK sti ecu? How about if you have the cobb accessport running stage 2? Will you get the same results with the typhoon or is the cobb reflash specifically designed for the stock intake?
speedypete is offline   Reply With Quote
Old 11-05-2004, 12:01 PM   #80
totoherbs
Member#: 7321
.... 122 IggPoints
According to cobb its made for the stock intake. Which is why they have an intake map for the injen intake. IIrc the made that one because the demand was so high. Will it work? It may... but most of the people with AP's on the wrx end up pulling thier intakes.
Old 11-05-2004, 12:02 PM   #81
Hummer
Member#: 31892
2004 STi
TTIWWP so....
Hummer is offline   Reply With Quote
Old 11-05-2004, 12:37 PM   #82
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
The first statement is true. There is no map offered for the STi using an Injen intake, only for WRX users. The ECU on the WRX and STi are totally different, so what you are saying is no relevant to the topic.
There have been reports on the Cobb Forum of people using the Typhoon intake without any problems. They also noted that the AFR's did not change when adding the intake.
dsmperformance is offline   Reply With Quote
Old 11-05-2004, 12:45 PM   #83
totoherbs
Member#: 7321
.... 122 IggPoints
Old 11-05-2004, 01:09 PM   #84
soso3
Member#: 36794
89 T I T A N
Originally Posted by nhluhr
jesus christ. The absolute misunderstanding of how the ECU works, how good this intake is and the doubting of the validity of Aaron's results in this thread astound me (although they don't really surprise me).
First of all:
There is NOT IAM factor in the STI ECU. There may be some other factor but IAM doesn't exist in the STI. All this talk of "ECU Reset is making the power" is absolute rubbish. His car would have to have been detonating BADLY and in limp mode for the ECU reset to cause an INCREASE in power. If anything, countless people have shown that the car's power will be decreased after a reset and it will rise run after run until it finds it det limit and backs off again.
I was one of the very early adopters of this intake and from the very start, I've said it makes more power than the stock intake without ****ing with the air/fuel trims. I have Tuna wideband permanently installed in my car so my judgements are qualified.
The single biggest restriction in the engine's intake path is the air filter. This is the MAIN reason intakes with large cone filters make power. By increasing the surface area of the filter, you reduce the restriction through it. This results in less pressure drop in the turbo inlet hose, which has lots of benefits for a turbocharger system.
VE is increased, intake charge temp is reduced, lag is reduced, etc etc.
To all the longtime naysayers:
This whole "agree to disagree" thing is such an overused phrase. How about this one:
You're stubborn and you'll never have a clue what you're talking about.
What a load of B.S.
Good info!
But seriously! Some of you guys get too worked up over this stuff!
soso3 is offline   Reply With Quote
Old 11-05-2004, 04:33 PM   #85
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
hummer how did that intake mate up to the perrin inlet? i have the exact same setup ordered, just in red.
thanks!
cnstman is offline   Reply With Quote
Old 11-05-2004, 04:59 PM   #86
cann
Member#: 8618
anyone got the dreaded CEL with the STI and the K&N intake?
cann is offline   Reply With Quote
Old 11-05-2004, 05:48 PM   #87
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Originally Posted by soso3
What a load of B.S.
Good info!
I hope this was sarcasm, as I'll readily have you search "pressure ratio" for an explanation of my claims.
nhluhr is offline   Reply With Quote
Old 11-05-2004, 05:51 PM   #88
soso3
Member#: 36794
89 T I T A N
Yes, it was. That's why I used the .
Old 11-05-2004, 07:21 PM   #89
Hummer
Member#: 31892
2004 STi
thanks!
It mates perfectly {biting tongue on juvenile response}. It does seem quite peppy. I had a Perrin and Apexi before and I found both wanting. I can't wait to see how it does with a GT12 and UR 785 injectors.
WA. FS. K&N Typhoon, stock airbox W/K&N filter lucio Engine/Power/Exhaust 19 11-20-2009 08:13 AM
New SOA-Approved Intake; Dyno Proven +5 hp, +10 lb-ft Jon [in CT] Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 723 08-15-2006 06:58 PM
Looking for dyno proven Exhaust gains Mechkiller31st Normally Aspirated Powertrain 10 03-20-2006 01:24 PM
any dyno proven gains for STi hood scoop? Butt Dyno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-17-2003 10:46 PM
-Dyno Proven custom 2.5RS header- impRSa01 General Forum Archive 7 03-10-2001 10:59 PM
