Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 11-02-2004, 02:11 PM   #1
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Default Fuel Leak? Should I get new fuel rails?
I started my car up this morning and it was leaking fuel around cyclinder#3. I've done some research on the boards and called nate wade. They said they are familiar with the problem and have done a few installs to replace the parts. The guy at nate wade told me about $60 for new oem fuel rails and rubber hoses plus a couple hours in labor. Should I get the oem parts or will they just leak again? Or should I drop in for an aftermarket fuel rail? Also, if anyone is selling a fuel rail kit for an 02 wrx let me know. I am really not sure what to do at this piont???
Thanks guys!
CtGT is offline   Reply With Quote
Old 11-02-2004, 02:13 PM   #2
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Also I am looking for a couple new O rings for the injectors to see if that is the problem. No one has them in stock right now.
Old 11-02-2004, 05:49 PM   #3
mixup52
Member#: 39691
2002 WRX Wagon
You can go to Autozone, they have some. You will just need to take in your O rings to match them up. I order some a couple of weeks ago. I just haven't picked them up. If you need them let me know cause I ordered 8 of them. They are at Ogden Suby. Let me know
Chris
mixup52 is offline   Reply With Quote
Old 11-02-2004, 06:05 PM   #4
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
if you dont know how to do it, and are taking it to nate wade. PM me and ill do it for you, for a good price....
snowman4us is offline   Reply With Quote
Old 11-02-2004, 06:11 PM   #5
mixup52
Member#: 39691
2002 WRX Wagon
what about mine? Free? Cause that is the price I would charge! Hahaha
Chris
Old 11-02-2004, 06:32 PM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
so are you keeping your car chris, or you gona still be a little girl and get that german crap?
jk
Old 11-02-2004, 06:51 PM   #7
mixup52
Member#: 39691
2002 WRX Wagon
Keeping it and thinking about a V7 or V8 swap in the spring. Not for sure though. I just dropped 2800 on a new Alienware Area 51M Laptop. So there goes half of my swap.
Chris
Old 11-02-2004, 07:12 PM   #8
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Chris
why whyoulf you ever do that...does your computer provide you w/ a sorce of transortaion when you are in time of need? dont think so.... what you plan on doing w/ your old engine?
Old 11-03-2004, 10:58 AM   #9
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Thanks mixup and snowman! I looked at it last night and one of the clamps going from the metal fuel rail hose to the rubber hose was a little loose. It doesn't leak now but it didn't leak when I got home last night and started it. Only when it sits all night and is really cold. I am not sure what to do. I guess drive it and see what happens.
Hey has anyone or do you guys know of anyone who has blown a head gasket on an ej20? I'm sure if I did my car would be smoking like crazy. When I was checking out my injectors and fuel rails last ngiht there seemed to be a lot of oily sludge build up around the top of the head and near the breather. Have you experienced this and also my car was low on oil and it never burned a drop until I just checked it? Any ideas?
Old 11-03-2004, 02:26 PM   #10
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
if your head gasket is going bad check your radiator fluid(make sure the car is cold so you dont burn yourself). whe you look at the fluid look for oil to be floating on top of the Radiator fluid, make sure to check the turbo reservor and to radiator cap on the radiator....also the smidge might be from the oil comming out of the breather...do yo have an oil catch can? if you want to, i can take a look at it for you...just send me a PM and we can meet up....im intrested to see what is wrong w/ your car...
how mutch boost you running in your car? and how many miles are on it?
Old 11-03-2004, 02:32 PM   #11
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
pmed you
New Uppipe going in soon, should I get new stock gaskets or aftermarket thicker ones? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-04-2002 10:12 AM
replacing front windshield, should I get new moulding? bemani Interior & Exterior Modification 30 07-02-2002 03:30 PM
springs & struts r on the way! should I get new top mounts or BPMs? wighti Brakes, Steering & Suspension 5 05-08-2002 10:37 AM
Why should I get new sway bar end links? jersey judge Brakes, Steering & Suspension 10 01-14-2002 05:10 PM
Should I get new tires? Piusma Brakes, Steering & Suspension 9 07-11-2001 07:31 AM
