Old 06-26-2001, 02:50 PM   #1
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
Question Exhaust install question.
This weekend I received and installed a Brullen catback exhaust. Upon install I found that the spring loaded bolts that connect the midpipe to the cat were to short due to the fact that the flange on the brullen was about 1/4 to 1/2 inches farther back than the stock set up. As a quick fix, I went to the hardware store and got to bolts and some large washers to hold the spring in place and connected the two pieces. When I fired up the car there was a stong odor of exhaust fumes in the car, so I crawled under the car and tightened my makeshift springbolts a bit further. Next time I fired up the car, the exhaust fumes were gone. Also, after the ECU reset, when the car sits and idles for a while, I did nto notice any exhaust smell. I figured that was that. However, now I have noticed a sweet/hot smell coming from under the car after a spirited drive.
My question is; Have I tighened down my MacGyvered bolts to far and am I cooking the Cat somehow (please note, the springs are not fully compressed) or is that smell just the new midpipe cooking off the black paint it came with (I have noticed that it has bubbled and/or flaked near the cat)?
Is it normal for a new exhaust system to smell "hot" for a while after the install?
Thank's for any help/reassurance you can give me
-Jamie
Reflex-Arc is offline   Reply With Quote
Old 06-26-2001, 03:36 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
It is hard to say about the brand of exhaust you bought. Some have paint or other coatings that get cooked for the first little while after install. As long as you are not getting a leak at the joint, I think you are fine. I would not worry about it too much.
jeffg is offline   Reply With Quote
Old 06-26-2001, 04:39 PM   #3
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Expect weird smells for a few days, but after that it shouldn't smell. I would seriously consider replacing the dognut-shaped gasket that goes between the midpipe and cat. Sound like that is probably shot. You can get it from a Subaru dealer.
Sucking carbon monoxide is not a good thing, IMO.
- Steve
zzyzx is offline   Reply With Quote
Old 06-27-2001, 11:54 AM   #4
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
I replaced the gasket yesterday. We'll see how long the smell persists
thank you!
exhaust install question blaznasn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-11-2002 07:49 PM
Turboxs Exhaust Install Question HS WRB-rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-21-2002 06:52 PM
Exhaust Install Question ylexot Normally Aspirated Powertrain 3 12-28-2001 10:18 AM
Exhaust install question (splicing wires) Gerlando Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-06-2001 07:11 PM
intake and exhaust install questions bluesube Normally Aspirated Powertrain 7 10-25-2000 01:53 PM
