Old 06-26-2001, 02:54 PM   #1
IMPREZAmike
Member#: 169
98 black OBS
move bi*ch get out da way
Question clutch travel/throwout berring noise/etc
i had my clutch replaced about 10,000 miles ago, and recentlly had the 60K mile checkup. since the check up, i have had a very annoying rattle that is being genterated by the throwout berring (that was also replaced w/ the clutch) When the noise occurs, all i have to do is lightlly press on the clutch pedal and the noise goes away. Also, i went to check the clutch cable, and have always been told that where it connects to the lever in the engine compartment, there should be some play in the clutch lever, not constant presure (constant presure making it like you are riding the clutch). well there is no play, and when i loosened the cabel, the lever still didnt budge. I want to stop the noise and make sure that my clutch isnt going to blow up in another few thousand miles. im hoping this is just a small adjustment that i can do and not something that the dealer has to mess with. Any ideas?
IMPREZAmike is offline   Reply With Quote
Old 06-27-2001, 11:57 PM   #2
IMPREZAmike
Member#: 169
98 black OBS
anyone? im baffeled...
FS: NEW EJ25 Excedy OEM clutch and throwout bearing polaris VIC Private Classifieds 8 12-19-2013 12:41 AM
Throwout bearing noise skydes Transmission (AT/MT) & Driveline 30 10-13-2011 12:39 PM
got my ACT clutch and throwout bearing.put the bearing in pressure plate.cant remove! stiboost04 Transmission (AT/MT) & Driveline 2 04-27-2010 08:47 AM
Stock CLUTCH and throwout bearing needed Syncade Private 'Wanted' Classifieds 3 01-25-2006 08:55 AM
clutch fork/throwout bearing. AzNStiImpreza Transmission (AT/MT) & Driveline 4 07-24-2005 11:16 PM
