Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 11-03-2004, 01:43 AM   #1
85glwagon
Member#: 73725
1985 GL Wagon
beige
Default JDM ej20 turbo
I was wundering if the JDM ej20 turbo will bolt up to the late 80's gl turbo motors...anyone know??
85glwagon is offline   Reply With Quote
Old 11-03-2004, 10:00 AM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Sure.. with enough work, anything will fit.
To clarify, are you trying to get just the turbo from the EJ20 onto an EA82T?
Maybe something like this
http://www.ultimatesubaru.net/photos...re_056-med.jpg
That is a TD04 13G off of a 2003 USDM WRX mounted to an EA82T crossover pipe. Its in my garage awaiting completion of a new motor to bolt it on to.
Its not a direct fit, requires some fabrication. But it can be done.
Calebz is offline   Reply With Quote
Old 11-03-2004, 10:19 AM   #3
85glwagon
Member#: 73725
1985 GL Wagon
beige
after a bit of thought, what i really want is just a more powerful turbo for the ea82t, dun have to be the ej20 necessarily, that just happened to be the one i read about someone else having, what turbo would give me the biggest boost in power? and what do they cost? also how safe?
Old 11-03-2004, 10:25 AM   #4
85glwagon
Member#: 73725
1985 GL Wagon
beige
hmmm....looking at that pic...i'm a bit confused, prolly because i have never had a turbo engine or really looked at one in real detail, from what you said and that pic showed it looked like the turbo connects to the exhaust??? and is that the only fabrication that has to be done is to the exhaust?? i'm not sure how the turbo connects to the motor....do i have to rig something up for that or do all turbos connect to the heads the same??
Old 11-03-2004, 10:30 AM   #5
Calebz
Member#: 54398
1980 CB400 Hawk
The WRX turbo is probably the easiest upgrade.. A lot of factors come into play.
1) How ready is your motor for higher boost (what other mods do you have that will support a bigger turbo)
2) What kind of fabrication skills do you have
3) How much money do you want to spend
There is no 'bolt on bigger turbo' for your car. It all takes work and money. If you want to go faster and don't have a way to get the work done, get a boost controller off eBay and raise the boost on your stock turbo a little.. Get a boost gauge first.
Everything you do is at your own risk. Beware that given the age of your car, even the slightest increase in boost could result in a blown head gasket
Old 11-03-2004, 11:02 AM   #6
85glwagon
Member#: 73725
1985 GL Wagon
beige
nodnod, thanx for the help, as of now i don't have a turbo, i have an 85 GL wagon non-turbo with a webber. But i can easily pick up a turbo wagon cheap, what would i have to do to the engine other then aftermarket head gasket to make it so it can handle the power the wrx turbo will add? also, how much hp do you think an ea82t with the wrx's turbo and intercooler have?
Old 11-03-2004, 11:16 AM   #7
85glwagon
Member#: 73725
1985 GL Wagon
beige
I don't have much money at all really, i can fabricate all day if it'll save me some money....the TD04 13G came from a 3000gt? i just looked up the wrx turbo on ebay and they look expensive, i looked up the TD04 13G and theres one for $102 (Much closer to what i'm looking to spend on a turbo considering what i'll prolly spend tunning and upgrading the motor so it can handle the turbo) anyhoo, if the TD04 13G will give about the same power as the wrx turbo at a fraction of the cost and twice the work it's still the way i wanna go because i'm pretty tight on cash....BUT i don't want to throw something together too cheap and it be a disappointment in the end....though i think any turbo gl will be faster then my non-turbo...
Old 11-03-2004, 11:40 AM   #8
Calebz
Member#: 54398
1980 CB400 Hawk
You're in shelton?
Turbowagons are abundant around there. Mine came from Olympia
Don't know how much HP the bigger turbo and IC will net. A lot depends on how much boost you intend to run.
Currently I am running an RX7 TMIC, Stock turbo at ~12PSI.. Motor got tired after around 200k, so I have pulled it and am building a new one.
Within the next few weeks, it will have an 8.5:1 compression EA82T with WRX TD04 13G turbo, WRC turbo back 2.5 inch exhaust, XT6 suspension with 16 inch wheels, and WRX coilovers. Plus a blitz DCII turbo timer.
Don't know how much of a power increase the engine mods will bring.. WIll find out shortly though.
I have all the stuff, I just need to put it together. Then I need to find an excuse to drive it wo Washington.
Old 11-03-2004, 11:41 AM   #9
Calebz
Member#: 54398
1980 CB400 Hawk
Its from a 2003 USDM WRX
Old 11-03-2004, 11:53 AM   #10
85glwagon
Member#: 73725
1985 GL Wagon
beige
cool, how much did all the mods cost u? you gatta post about the beast when you get it all put together, i bet it ends up a monster, sounds like what i'm looking to do, if you decide to come to Wa. msg me b4 hand and mabee we can get together and i can see the machine in person, thanx for all the help, i know so much more than i did when i woke up this morning....been on the comp for the past couple hours just researching to find out what i want to do...i think i want to get a gl turbo, car version 4x4 and mod the engine out so it can handle a bigger turbo.
Old 11-03-2004, 12:02 PM   #11
Calebz
Member#: 54398
1980 CB400 Hawk
Heres some pics of stuff
http://www.ultimatesubaru.net/forum/...hlight=preview
http://www.ultimatesubaru.net/photos...CF0046-med.JPG
And ya just never know when I might show up in Wa.. My dad works in shelton.. My mom is in Olympia... I spent 27 years in Tacoma/Puyallup
As far as cost goes.. I will have a tally sheet put together when its back on the road. This is actually round 2 of the modification process.. I will break it down as best as I can when its all over.. then it will be time to start saving for round 3
Old 11-04-2004, 01:53 AM   #12
TurboneX
Member#: 21676
RX 02Foz,05OB
Well, after reading this, I think you should check this out.
Turbo's
TurboneX is offline   Reply With Quote
Old 11-04-2004, 02:39 AM   #13
Calebz
Member#: 54398
1980 CB400 Hawk
Turbo's
Thank you Rob.. I always forget about that site.. It rocks
JDM WRX EJ20 Turbo Motor, AP Fuel Rails, Microtech EMS, HKS uppipe TurboGC8FL Engine/Power/Exhaust 0 04-07-2008 03:06 PM
WTB: EJ20 Turbo Motor Eatoniashoprat Canada Region Private Classifieds 0 03-18-2007 01:47 PM
JDM EJ20 turbo motor NicktheBrit Private 'For Sale' Classifieds 1 12-03-2003 06:23 PM
Need JDM EJ20 Legacy Motor Specs from the past MY99 2.5GT Legacy Forum 4 05-09-2003 10:44 AM
Question about swapping in JDM EJ20 turbo engine and gasoline requirements edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-20-2001 11:39 AM
