Old 11-03-2004, 11:06 AM   #1
natoli4
Member#: 66668
2002 wrx wagon
blk
Default vf39 missing bolt on the down pipe?
Just did a stg 4 install this past weekend and when I was bolting up the new turbo I noticed that the center bottom stud that hold the downpipe to the turbo was missing! The center x? Am I supposed to have a stud there? Or is a bolt supposed to go into that location? the stock turbo has a stud on it. now the downpipe had a small leak when cold! what should I do? please help!
x x
0 x 0
--^---missing this stud. am I supposed to put a bolt in this location?
bought the deadbolt turbo used.
natoli4 is offline   Reply With Quote
Old 11-03-2004, 11:13 AM   #2
Davenow
Member#: 23676
its missing a stud
A bolt could work
I never put that nut back on on my car anyway. It is too much of a PITA and never leaks anyway.
Old 11-03-2004, 02:39 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Got to Autozone, Murrays, etc and buy a new stud and nut.
mbiker97 is offline   Reply With Quote
Old 11-03-2004, 04:28 PM   #4
elsanto
Member#: 34832
1989 M3
yah buy a new stud, I found mine in the "HELP!" section.
elsanto is offline   Reply With Quote
Old 11-03-2004, 05:39 PM   #5
natoli4
Member#: 66668
2002 wrx wagon
blk
how does the stud go in? do I just screw it right in or does it epoxy in somehow...sorry for sounding so lame but I don't want to $%^k the thing up.
Old 11-03-2004, 06:31 PM   #6
CMJ
Member#: 39235
I'll 2nd that, and it drops 20 minutes from the remove/replace next time (if your using a bellmouth).
CMJ is offline   Reply With Quote
Old 11-03-2004, 10:06 PM   #7
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Its not a bad idea to put a little loc-tite on it. That way if you ever remove the turbo again.. the stud will not come when you try to loosen the nut. But using loc-tite really isnt all that necessay. your choice on that one
Hayaboosted is offline   Reply With Quote
Old 11-04-2004, 12:12 AM   #8
natoli4
Member#: 66668
2002 wrx wagon
blk
thanks all. I'll leave it out for now and look for the bolt next time i'm at the parts shop.
Would A Missing Nut On The Up Pipe To Turbo Cause Issue lordizzy626 Newbies & FAQs 14 03-10-2010 10:57 PM
2006 Subaru STi - AMR T60R Bolt-On Laying down the POWER!!!! (double the factory HP!) AMR Proven Power Bragging 18 08-26-2008 08:53 AM
Stock Bracket off of the down pipe that holds on the Heat Shield???? BLUETURBOWRX Private 'Wanted' Classifieds 0 08-18-2003 03:34 AM
Help! What is the size of the down-pipe bolts? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-24-2003 12:14 AM
Minnam turbo peeps check your heat wrap on the down pipe Andre Vandenberg Normally Aspirated Powertrain 2 02-19-2001 08:42 AM
