Old 11-03-2004, 03:15 PM   #1
Unsung Boxer
Member#: 37196
Default 05 rear LSD, gear ratio?
Got an 05 STI rear LSD. Im trying to find out if the gear ratio is the same as my 98L and/or if its compatible. Im having a hard time finding the specs.
I was under the impression that:
pre 01 5sp Imprezas were all 3.90
02+ WRX's all 4.11
04+ STI's all 3.90
thoughts?
(unsung)
Unsung Boxer is offline   Reply With Quote
Old 11-03-2004, 03:42 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
the final drive on that diff will be 3.9.
wrx's are 3.54
all 2.5l impreza 5spds were 4.11, 2.2l's were 3.9
so since you have a 2.2l i would say you have the same final drive, so yes the ratio is the same. using it in your car is going to be much more difficult.(you need either lots more stuff or need to modify current stuff)
do a little search to turn up the rest
Ben
Question on Rear Diff Gear Ratio Surfer Steve Transmission (AT/MT) & Driveline 5 08-28-2006 04:32 PM
Legacy LSD gear ratio question Legacy Rally Guy Legacy Forum 6 05-05-2006 01:36 PM
05 and 06 gear ratio is different? 06 is better? 05 wrx sti Transmission (AT/MT) & Driveline 13 02-24-2006 07:12 AM
rear diff gear ratios (outback/wrx) don4501 Transmission (AT/MT) & Driveline 1 04-20-2005 06:23 PM
Rear diff gear ratio???? Naturally Aspirated Transmission (AT/MT) & Driveline 1 10-22-2001 05:58 PM
