Old 11-03-2004, 08:17 PM   #1
theSTIguy27
Member#: 69658
2005 STI
SILVER
Default newbie sti questions
sorry but i just got my sti has about 400 miles now and i was wondering some things because ive noticed some weird things, such as when i turn the key were the radio comes on all the lights on the cluster comes on like the oil and check engine is that normal? also when im in traffic and i push the clutch the car revs itself to about 1500 to 2000 rpm is that also normal for sti's? just want to be safe and sorry for the stupid questions
theSTIguy27 is offline   Reply With Quote
Old 11-03-2004, 08:23 PM   #2
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
- The revs will not drop below 1k unless you are under about 20 mph
- In Accel mode, you can have the radio come on without the cluster coming on.
I hope this isnt a troll post. It sure sounds like it.
- dow
dowroa is offline   Reply With Quote
Old 11-03-2004, 08:50 PM   #3
theSTIguy27
Member#: 69658
2005 STI
SILVER
you dident answere my questiuon why is the check engine light and the oil light on when i turn the key to power everything and the car revs itself sometimes its very weird
Old 11-03-2004, 09:20 PM   #4
theSTIguy27
Member#: 69658
2005 STI
SILVER
Old 11-03-2004, 09:37 PM   #5
MrHorspwer
Member#: 4063
Any time the key is ON and the engine is not running, the check engine light will be illuminated, as will the oil pressure idiot lamp (how can one have oil pressure if the engine isn't running?).
Perfectly normal.
As for the revs. If you are rolling along and push the clutch in, the ECM knows that the car is moving based on a vehicle speed signal. It will keep the revs a bit off idle to anticipate you releasing the clutch again.
Once again, normal.
MrHorspwer is offline   Reply With Quote
Old 11-04-2004, 03:07 PM   #6
ibsmd425
Member#: 52791
03' Impreza WRX
The check engine/oil lights start up with pretty much every Subaru, it's a Japanese thing. It's just to make sure that the lights are operational.... if the lights stay on, well that's a different story.
SEAN
ibsmd425 is offline   Reply With Quote
Old 11-04-2004, 03:12 PM   #7
MistaOctamopus
Member#: 53561
2004 WRX
Check engine light, oil pressure light, and usually ABS light comes on in every car I've had experience with. It's most likely a diagnostics thing, to ensure that all the lights work. Just as if the oil pressure light comes on while driving, if it doesn't come on when powered up, something is wrong. In the second case you've blown a fuse or the light is teh borked.
MistaOctamopus is offline   Reply With Quote
Old 11-04-2004, 03:28 PM   #8
sdogg3kgt
Member#: 38397
2002 Lovemachine
Once again, normal.
My car has never done that, not our WRX, my 2.5RS or our Mini Cooper S. Not even our previous Jeep Wrangler or any other car I know of. All the cars I've ever driven go right to idle.
Maybe you aren't taking your foot all the way off the gas when you push in the clutch, it happens.
sdogg3kgt is offline   Reply With Quote
Old 11-04-2004, 05:34 PM   #9
dowroa
Member#: 17498
No More Subarus :(
No.
With the electronic throttle on the 04s/05s, that is the way it works.
Period.
- dow
Old 11-04-2004, 10:47 PM   #10
sdogg3kgt
Member#: 38397
2002 Lovemachine
Originally Posted by dowroa
No.
Period.
- dow
Funny how my 04 doesn't do it.
Old 11-04-2004, 10:55 PM   #11
squeech
Member#: 38280
2000 2.5RS w/ EJ205
tuned @ teh Ghetto Garage
That's because the WRX and the RS still have a conventional throttle cable. Only the STi has the electronic throttle that dow and MrHorspwer describe.
squeech is offline   Reply With Quote
Old 11-04-2004, 11:06 PM   #12
Scorch968
Member#: 73170
2005 Impreza Wrx Sti
My 05 doesn't do that...and I just bought it. The engine doesn't rev when you push in the clutch. If your too quick to the gas maybe but not if your just coasting and push the clutch.
Scorch968 is offline   Reply With Quote
Old 11-04-2004, 11:27 PM   #13
sdogg3kgt
Member#: 38397
2002 Lovemachine
Exactly what I'm saying. You sometimes don't notice when you don't take your foot off the gas all the way. I've ridden with so many people who do it.
Old 11-04-2004, 11:28 PM   #14
sdogg3kgt
Member#: 38397
2002 Lovemachine
As far as the 2004 and 2005 Impreza brochures go, it just says the Impreza has electronic throttle, it doesn't specify which model.
Old 11-04-2004, 11:36 PM   #15
d12agonxboi
Member#: 48347
1999 2.5rs
Silverthorn Metalic
It's normal dont know if you are really serious or not, but yah all the lights go on and when u turn it to the next click, the lights on the gauges goes off...
d12agonxboi is offline   Reply With Quote
Old 11-04-2004, 11:37 PM   #16
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Its the STi only.
jamesfacts is offline   Reply With Quote
Old 11-05-2004, 04:09 AM   #17
supermarkus
Member#: 6971
2008 WRX STi
SSM
So go look at yours.
supermarkus is offline   Reply With Quote
Old 11-05-2004, 07:50 AM   #18
Karl
Member#: 13110
Your first car and it's an STi? Yikes.
Karl is offline   Reply With Quote
Old 11-05-2004, 08:10 AM   #19
attitude
Member#: 52043
04 sti
he didn't say it revs up 1500-2000 rpm's above what he was already at, it goes to 1500-2000 rpm's. such as a shift at 3000 rpm's, then just not shift, it will stay at 2000 or 1500, not idle, and every car i have ever had, has done this.
are you the same guy on the huntington streets/upgrades site stiguy?
attitude is offline   Reply With Quote
Old 11-05-2004, 09:54 AM   #20
sdogg3kgt
Member#: 38397
2002 Lovemachine
NO car I have ever driven stays at 1500-2000rpm, not a single one. I highly doubt it. I have driven pretty much any car under 40k because I used to test drive cars for fun and not a single one ever did, not a KIA, not the Evo, not a WRX, no BMW, no Miata, no MR2, no Spec-V, none.
And the brochure does say that all models including the Outback, 2.5RS, WRX and STi have ETC for 2005, so probably 2004 as well.
Old 11-05-2004, 10:09 AM   #21
dowroa
Member#: 17498
No More Subarus :(
I am telling you what my 05 STi does. It is a matter of fact. If you think yours doesnt do it, or if you haven't run into the circumstances that it has not arrisen in your daily driving -- fine.
However, I refuse to banter further about an observered behavior I have seen in contrast to the 03 WRX I had.
It does do it. It Wont rev DOWN past 2000 -- 1000 depending on speed, and it is controlled via a function of speed by the ECU. Put your car in neutral at 45 without your foot on the clutch, and watch what happens.
Enjoy.
- dow
Old 11-05-2004, 10:10 AM   #22
attitude
Member#: 52043
04 sti
well then between me and you sdogg the coincidence is crazy, because whille rolling with the clutch pedal to the floor, or in neutral, at speeds of 30+ all manual cars i have driven have stayed at an rpm above idle. and i have done the test driving for fun thing for as long as i could drive. (did it with parents before the dealers would let me by myself) my truck,trans am, sti, celica, etc. all have as well
Old 11-05-2004, 10:18 AM   #23
Davenow
Member#: 23676
I have never seen more completely uninformed people argueing incorrect points in my life. Just about every one of you that is answering his question, is wrong. Again, please, all of you see this post
http://forums.nasioc.com/forums/showthread.php?t=647701
Old 11-05-2004, 10:22 AM   #24
attitude
Member#: 52043
04 sti
i'm just telling what i have seen in MY cars, and i dont know why they have done it, i didn't claim to. i have always wondered why they did it, and thought it was wierd. but i still know they did it and my sti does, did it this morning. this is somthing i have witnessed, i didn't see it on the intraweb
Old 11-05-2004, 10:27 AM   #25
Nasiocks
Member#: 62023
2013 ST
Every car I've ever seen does this....wth? (Check engine question)
Nasiocks is offline   Reply With Quote
Newbie with stupid Sti questions ALIEN STi Newbies & FAQs 1 05-22-2007 09:26 AM
Newbie STI question AugustusMaximus Newbies & FAQs 20 11-13-2005 02:15 PM
Newbie Insurance Question on STI DilferJr Bay Area Impreza Club Forum -- BAIC 9 08-11-2005 09:58 PM
Newbie here! Question about STi and trailer hitches Tiggyboot Interior & Exterior Modification 33 03-25-2004 09:26 AM
STI question-newbie O1LegacyGT Subaru Conversions 7 01-22-2004 11:29 PM
