Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 03-14-2005, 08:11 AM   #26
rhd
Member#: 81820
2003 WRX sedan
Sedona
i have an aftermarket battery in my 03...and it still does this. i have an optima red top in the rear floor board i'm bout to go put in, though
rhd is offline   Reply With Quote
Old 03-14-2005, 10:26 AM   #27
AWD=Control
Member#: 71575
2003 WRX
Same thing happens here, I've heard that this is quite common. It's happened to my 03 about 8 times over the past 2 years and temperature did not seem to be a common factor.
AWD=Control is offline   Reply With Quote
Old 03-14-2005, 10:33 AM   #28
2004blackwrx
Member#: 59883
2004 wrx
black java pearl
yep I definately have the same problem with my 2004, it just seems to be more frequent when I park on a hill.
2004blackwrx is offline   Reply With Quote
Old 03-14-2005, 12:33 PM   #29
UKscooby
Member#: 33287
RIP Nik
I will always miss you
I fixed mine by replacing the fuel filter. Now, everytime it starts to happen more often, I replace the filter and the problem goes away for 20,000 miles. Bad gas (water) kills filters. This could be the cause for low milage cars.
UKscooby is offline   Reply With Quote
Old 03-14-2005, 12:50 PM   #30
Call_me_Tom
Member#: 60972
My car did it twice with just under 6k miles. I've got 8k on it now....I'll try the trick Unabomber gave and see if this helps.
Call_me_Tom is offline   Reply With Quote
Old 03-14-2005, 01:36 PM   #31
wrx2k4blue
Member#: 59048
2005 Black S60R
w/ 18" Modas & Sport Body
I knew someone with an 02 and it never did that. I have an 04 and it doesn't start once in a blue moon. If I try again, it always starts up. So you guys may be right about 'priming' the fuel
wrx2k4blue is offline   Reply With Quote
Old 03-14-2005, 01:44 PM   #32
Call_me_Tom
Member#: 60972
I didn't think about the model year thing I also have an '04?????????????
Old 03-14-2005, 02:35 PM   #33
Hzracing
Member#: 77294
2005 WRX Wagon
My '05 did it the first week I owned it , not happy, it did start after 5-8 seconds of cranking though.
has done it a few times since.
Hzracing is offline   Reply With Quote
Old 03-14-2005, 03:53 PM   #34
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Tip : Before you crank and car.. turn you key to on position and let the fuel pump get primed before you crank the car..
what i normally do is get in the car put key to on position put on seat belt close door and then crank.
try it.. it helps.. i find this tip from other thread with ppl having similar problem.
Kenji815 is offline   Reply With Quote
Old 03-14-2005, 03:56 PM   #35
Damien3082
Member#: 68710
2005 Impreza WRX
Pearl Blue
This happens to me also and my car is stage 4. Long crank is usually a bad check valve in the fuel pump, leaky injector, low battery voltage or right after you reset the ecm. A buddy of mine is gonna do a fuel pressure test. You might want to try that also.
Mike
Damien3082 is offline   Reply With Quote
Old 03-14-2005, 04:06 PM   #36
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
I dont understand how swapping a batttery out will solve the problem. If the engine is cranking, then the battery is doing it's job.
Mine does this as well occasionally. Read the owners manual. It says you can crank the engine for 10 seconds. If it doesn't start, wait, then try cranking again giving it a bit of gas.
merlot is offline   Reply With Quote
Old 03-14-2005, 04:23 PM   #37
dmah
Member#: 77590
2004 wrx sedan
I turn my car (04 rex) to the 'on' position to get the fuel pump going all the time before starting it. But I still do get the random no start as you guys mentioned. When this happens I can give it a bit of gas and it will start or stop cranking it and try again and it will start. I thought I was the only one too haha.
dmah is offline   Reply With Quote
Old 03-14-2005, 05:35 PM   #38
wonny
Member#: 50241
2004 WRX
Java Black Pearl
I had this problem a couple of times when I first got the car (stock). Called roadside and had it towed to the dealer. They said that a sensor in the clutch wasn't working and needed to be recalibrated. They fixed it for free and it hasn't happened for as long as I can remember.
wonny is offline   Reply With Quote
Old 03-14-2005, 06:39 PM   #39
fliz
Member#: 30342
I've had this problem before...I never thought the fuel filter might have fixed it.
I always noticed it if I parked for 2-3 hours then tried to start it.
Now I try to remember to turn the key to "On" for a few seconds before I turn it to Start, and it hasn't done it in a long time. But I also replace the fuel filter every 15K, so that might have helped it too.
fliz is offline   Reply With Quote
Old 03-14-2005, 06:50 PM   #40
ATXWRX
Member#: 81244
2002 My old SN
dyslexicwrx
Lack of fuel pressure is one thing it could be.. I took mine to the dealer and it did it to him. But he told me they did not find anything wrong. I left my car with them because they were replacing my wheel bearings and when I got the car back it has never done that again. So it seems they fixed it and did not tell me what they did.
ATXWRX is offline   Reply With Quote
Car Just started for the first time after swap! But there are a few problems :(.HELP snowcrzy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 07-24-2007 06:09 PM
Anyone else's trim piece not fitting on the sides? pieces Car Audio, Video & Security 17 02-04-2007 09:29 PM
not sure how i missed this little gem the first time in the 80's Fyxtion Off-Topic 19 07-14-2005 09:22 PM
Anyone else's WRX sound like its about to die out before it starts up? WRXakaBooSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-07-2005 07:29 PM
ECU reset, doesnt start on the first try? moogooob Normally Aspirated Powertrain 4 08-21-2002 01:45 AM
