Old 11-04-2004, 04:59 AM   #1
skimmilk68
Member#: 53385
05 Titan 4x4
Puh-tooey
Default Would a bad 02 sensor (P0037) make my car run bad?
Okay my car's currently bone stock but i threw a P0037, bad o2 sensor CEL
can a bad o2 sensor actually make my car go crazy? my car has rough idle and it's in limp mode (i cant get on the throttle hard at all, i've been driving very slowwwly)
reason why i ask is because i was completely catless before without a ECU and my car ran fine even with a CEL. now that im completely stock, my car's running funny with a P0037 and a P0340 (bad camshaft sensor)
skimmilk68 is offline   Reply With Quote
Old 11-04-2004, 05:24 AM   #2
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Yes, a bad O2 sensor can send your car into limp mode.
drees is offline   Reply With Quote
Old 11-04-2004, 05:27 AM   #3
skimmilk68
Member#: 53385
05 Titan 4x4
Puh-tooey
so how does it explain those cars that are running catless without ECU reflash or CEL fix?
Old 11-04-2004, 05:48 AM   #4
drees
Member#: 25905
2003 Silver Wagon
See this thread:
http://forums.nasioc.com/forums/show...hreadid=513437
(PS - Search is your friend)
Old 11-04-2004, 07:16 AM   #5
skimmilk68
Member#: 53385
05 Titan 4x4
Puh-tooey
its just weird because i've been running catless without any ecu reflash or cel fixes and it was running fine til i put the stock parts back on (like mentioned above)
Old 11-04-2004, 11:58 AM   #6
drees
Member#: 25905
2003 Silver Wagon
Have you reset the ECU for kicks since putting the stock parts on?
Old 11-04-2004, 01:33 PM   #7
skimmilk68
Member#: 53385
05 Titan 4x4
Puh-tooey
ya that does nothing, if i clear the CEL's on my ecu with a scanner or if i unplug my ecu and plug it back in, it'll run pretty ok for a second and it'll go back running like sh** again. does the p0037 have anything to do with the uppipe EGT or is it just the downpipe sensor?
Uppipe making my car run like doodoo? RNBauer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-29-2008 10:34 AM
excedy clutch i think making my car run richer VAUGHNB19 Transmission (AT/MT) & Driveline 3 10-04-2006 09:54 PM
How an EM can make my car run smoother?? BBBsti LTD Engine Management & Tuning 2 07-05-2005 11:44 AM
Need help: just got 02 and CEL makes the car run like crap 17cTSi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-26-2004 08:22 PM
mositure makes my car run bad...help!! MattJP Service & Maintenance 9 09-19-2003 11:12 AM
