Old 11-04-2004, 01:12 PM   #1
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Default Need Serious Help...
I'll write a whole report after the full install is done but I installed the AVO kit on the 2002-2003 2.5RS. Has anybody else done it? There are alot of small differences which were done from each generation which was never brought to my attention. Nonetheless, everything is hooked up but I got problems.
a) BOV hose : Where does the other end of the BOV hose connect to?
b) Fuelpressure regulator: I tee'd off on the FPR and had quite a bit of gas leak go through but none through the Link ECU when I fired it up.
c) The Link ECU is all hooked up but the car cranks but doesnt start. I put the injectors/ignition wires to the stock ECU and it fired up fine. Now I have to wonder if the 2002-2003 requires the injectors/ignition to be wired through the stock ECU rather than the Link. Would it be okay to run the injectors/ignition from the stock ECU?
Can anybody help?
I'm going to call AVO in Australia later today and I'ev called [email protected] but he hasn't gotten back to me in days.
fukamoto is offline   Reply With Quote
Old 11-04-2004, 02:50 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Sean is in Vegas oogling women and car parts at SEMA
Old 11-04-2004, 02:54 PM   #3
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
you could give spomotorsports.com a call too if you would like.
-Eli
squirrelmasta is offline   Reply With Quote
Old 11-04-2004, 02:59 PM   #4
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Spo told me to call Rallitek.
Yeah, Sean is tough to get a hold of. I tried calling him before he jetted to SEMA but he never called back.
Old 11-04-2004, 08:49 PM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
When you turn on the car, can you connect your laptop to the LINK and see if it's up and running?
cRayZee is offline   Reply With Quote
Old 11-05-2004, 12:16 AM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
For being "Sponsered by Avo" they sure haven't given you much support yet.
Drac9 is offline   Reply With Quote
Old 11-05-2004, 07:34 AM   #7
Tats
Member#: 5692
WTF? YES! I am
better than you!
One end od the BOV goes to the IC(obviously) The other recirc hose goes from the BOV to the metal air intake tube. After the Filter but before the turbo. By the PCV vent fitting.
???!!!! There should me NO FUEL ANYWHERE!. Since you are only teeing off the vacuum line. If there is fuel in there you have got bigger problems.
No. Then there would be no purpose for the link. You will start and idle fine with the stock ECU...but as soon as boost comes on...BANG...bye bye motor.
Make SURE you have the correct wiring diagram for your ECU. Two injector wire from the moter goe to each wire from the link...And 2 wires from the coil packs go to each wire in the link.
Can anybody help?
PM me your tel # I have minor surgery at 10 am EST but I'll try to call you later.
Tats.
Tats is offline   Reply With Quote
Old 11-05-2004, 10:37 AM   #8
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Fuel coming through the vacuum line???... you have a big problem there. Unless you tee'd off the fuel line instead of the vacuum line....hahaha... Another option is your FPR is ruined and is leaking.
For the LINKPLUS, contact "WRC555" or "WRC 555" they guy is a beast with the Link. He tuned my car in 1 hour and it runs like a charm.
You can run your car with the stock ECU.. just don't boost and you'll be ok.
As far as the BOV goes, I have a Greddy Type S and I have on hose connected to the intercooler and the second one connected to the inake manifold.
maxiav is offline   Reply With Quote
Old 11-05-2004, 10:41 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yeah wrc knows his ish just remember that the firing order is different thatn wiring link wire 1 to cylinder injector 1 its more like 3-1 2-4 1-3 4-2 but there was a post in here for the wiring for a 2k that has a list of what wires to hook to what it made it a lot easier there is one mistake, the purge control is supposedly also radiator fan #2 its a misprint from subaru
Old 11-05-2004, 11:35 AM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
firing order is 1, 3, 2,4 so i would assume you wire injector 1 to 1, 2 to 3, 3 to 2, 4 to 4 if thats what you are saying.
the 02-03 RS's still have the 2 coil ignition system right?
i would just double check that wiring, then if you think its right start checking it, pull a plug out and put it on the block to see if its getting spark, or if you pull the plug and its all wet, chances are you either arent getting spark, or you are putting way too much fuel in on start up. if you flood it like that you will have to change plugs and wait for it to air out.
good luck
Ben
Old 11-05-2004, 06:37 PM   #11
Tats
Member#: 5692
WTF? YES! I am
better than you!
None of this matters since it's NOT a link plus.
It's a Link1 Piggyback.
Old 11-05-2004, 06:38 PM   #12
Tats
Member#: 5692
WTF? YES! I am
better than you!
Kinda hard with that turbo. Full boost at about 2200-2500 rpms.
Old 11-06-2004, 02:44 PM   #13
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Tats : Sent you a PM.
WRC 555 I sent a PM.
Sean @ Rallitek does all of the Tech work for AVO and guess where he went. SEMA.
Well, we checked everything and it still doesnt fire up. We started our wiring from square 1 and nothing. THE wiring diagram from AVO is for the 2000 Impreza RS so I got the service manual for the 2003 and compared it one by one.
we are not gettin fuel .. its because of this one wire (green/red wire which goes from ECU to fuel pump and ignition at same time) .. we hook it back upto stock .. we get fuel but then no spark
Old 11-06-2004, 02:48 PM   #14
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Old 11-06-2004, 06:27 PM   #15
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
So are you removing the stock ecu? Does your link just plug right into the oem harness?
For my tec 3 I used the OEM ecu to controll things like turning on the fuel pump, and just used the TEC for timing/fuel.
subiekid is offline   Reply With Quote
Old 11-07-2004, 03:33 PM   #17
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Thanks Bernie.
Sean is harder to get hold of than a celebrity. I've called Link Australia, AVO Japan, AVo Australia, Subaru New York, Subaru Vancouver, Subaru Montreal and got nothing but ??
I think I talked to Garner (?) @ Rallitek. Thanks./ I'll call in the morning.
Old 11-08-2004, 03:57 AM   #18
asusimpreza
Member#: 4416
1989 Escort
Can anybody help?
Hopefully for both your a) and b) questions, you T-offed the vacuum hoses coming out from the intake manifold (one going to the fuel pressure regulator). These hoses should be on the top left intake manifold (if you are facing your engine).
This is assuming you are using the Link that came with the AVO kit and not the LINK Plus. As far as your c) question. The whole point of the Link, is that it takes control of both your fuel and timing. If you don't hook up the injector/igntion wires, you might as well not use a aftermarket ECM. The Link is suppose to richen your fuel and also lower your timing.
I'm still unsure on which green/red wire you speak of. Did you hook up the AVO fuel cut? Have a good ground for both the fuel cut and the Link? The ground for the Link will have to be on a unpainted surface on the chasis. I would think that the harness will be the same for MY01 or MY02/03. You can always check on Ravensblade for ECU pintout diagrams.
asusimpreza is offline   Reply With Quote
I NEED SERIOUS HELP FROM FELLOW NW'sters! (CEL) zzzzzzzz North West Impreza Club Forum -- NWIC 12 07-09-2005 09:44 AM
Tuners! 02 Rst Need Serious Help Please!!! Kripski Engine Management & Tuning 7 04-13-2004 03:29 PM
Need serious help 9 Service & Maintenance 3 09-06-2003 12:41 PM
Need serious help Pochebum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-06-2002 10:02 AM
Need serious help fast with brake pad/rotor issue. Jasno999 Tri-State Area Forum 13 05-01-2002 07:04 AM
