Old 11-05-2004, 09:22 PM   #1
b4437
Member#: 23162
2006 300c,forester x
silver steel
Unhappy easiest wa to put intercooler? help!!!
what's the easiest way to put the stock tmic back on to the turbo? i have been trying for the last 4 hrs and nothing is working. is there some kind of trick. my back is killing me!!!
b4437 is offline   Reply With Quote
Old 11-05-2004, 09:24 PM   #2
rallysport02
Member#: 68978
What part are you stuck on putting the y pipe back on the turbo?? Yeah ive had to take my ic off before it took me a while to just keeping trying to force the y pipe over the turbo.
rallysport02 is offline   Reply With Quote
Old 11-05-2004, 09:27 PM   #3
b4437
Member#: 23162
silver steel
the black y pipe. it's on halfway and i'm clamping it. my whold body is hurting from this ****. i have spent 9 hrs trying to put my gt-30 on and i can't do it.
Old 11-05-2004, 10:23 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I think I know what's holding you up if you haven't figured it out yet. Work on getting the BOV and throttle body hoses lined up first. Then when you are working on the part of the Y pipe that attaches to the turbo, stop. Now look at the pipe. The pipe is a smooth piece that goes under the intercooler. You should see the accordian section where it curves. You should also see a nub that sticks out all by itself. This nub is what you need to pry on. Get a long screwdriver/jackhandle/broom handle and use it to pry on the nub to move the Y pipe over the turbo outlet. You might use the throttle body hose as a fulcrum point. Once the hose is close to the turbo, you may have to use a hand to align the hose properly and the other hand to pry the hose over the outlet. That nub you see is your life saver. Silicone hoses don't have it and can actually be a bigger paint to put back on.
Old 11-05-2004, 10:32 PM   #5
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Unbolt the 4 bolts between the y pipe and tmic. Put the pipe on the turbo and then bolt on the TMIC.
Trunk_Monkey is offline   Reply With Quote
Old 11-05-2004, 11:35 PM   #6
b4437
Member#: 23162
silver steel
i've tried that and i broke my screwdriver and my check engine light came on while i was driving. i think the hose came off or something. i'll try again tomorrow. i can't put my hand in there at all.
Old 11-05-2004, 11:39 PM   #7
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
i think theres a big chance that you need a lot bigger hoses. that could be the reason
ramair18954 is offline   Reply With Quote
Old 11-06-2004, 11:35 AM   #8
b0dh1
Member#: 35269
2011 WRX
I do the same thing but with a thick piece of wire. That nub holds it in place well. It you dont wanna fulcrum off the TB hose, you could try this. Or even both if you have two people.
b0dh1 is offline   Reply With Quote
Old 11-06-2004, 11:47 AM   #9
Artdog748
Member#: 39947
2003 WRX MBP
1995 AWD L Coupe
I also put a little soapy water on theY-hose & turbo. Helped big time.
Artdog748 is offline   Reply With Quote
What is the easiest way of putting tmic back on? evil02wrx Newbies & FAQs 8 09-11-2006 08:42 PM
whats the easiest way to put stock bov back on? generalwrx Newbies & FAQs 3 11-12-2003 04:21 PM
Is it possible to put an oem EJ20 turbo and intercooler and piping and all on a GC8? FromMugen2STI Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-27-2003 03:57 PM
Is it possible to put a factory EJ20 turbo, intercooler and pipping on my GC8? FromMugen2STI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-25-2003 08:33 PM
air/water intercooler radiator questions. where to put inlet and outlet STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-24-2003 08:48 AM
