Old 06-27-2001, 03:26 AM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Default benifits of increasing intake plenum size
Is it worth the money and effort to increase the plenum and intake runs size? On the EJ22 it's very small, I would venture a guess that the engine would love a larger itake system.
WRXwannbe is offline   Reply With Quote
Old 06-27-2001, 08:18 AM   #2
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Larger intake volume will increase low end torque, but your high end power may suffer (unless you add some sort of boost controller).
--Roy
LUME is offline   Reply With Quote
Old 06-27-2001, 08:47 AM   #3
roninscar
Member#: 2306
2000 RS Sedan
Blue Ridge Pearl
Default I think you might have that backwards
It is my understanding that increasing plenum volume, presumably by increasing the diameter of the runners would have a detrimental effect on the lower end. Increasing the volume will decrease the velocity of the intake charge at lower revs, hurting power. However, having the larger capacity will help higher rpm breathing by increasing potential throughput.
This is why some high performance applications, like the SHO I used to own had 2 sets of runners, longer ones used exclusively up until 3k or so, and then a butterfly valve would open up a very short runner increasing flow considerably. If you looked at the dyno, there were actually 2 torque peaks in the graph, coolness.
Cheers,
scotto
roninscar is offline   Reply With Quote
Old 06-27-2001, 09:23 AM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
the runners in a port injected manifold aren't the plenum!
leave the plenum alone and fabricate a secondary airbox of as large a volume as you can fit in the engine bay and under the hood. the stock torque chamber (black box, sits on top of throttle body) is the right idea but too small.
ColinL is offline   Reply With Quote
Old 06-27-2001, 10:15 AM   #5
mhj
Member#: 3057
not exactly an answer, but if you want to see a custom intake manifold being fabricated, take a look at this:
http://www.sdsefi.com/rv4.htm
mhj is offline   Reply With Quote
Old 06-27-2001, 12:42 PM   #6
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
thats cool, could have teh TB facing foward for a FMIC too, would that clear the hood?
RageHardIntoTheBendies is offline   Reply With Quote
Old 06-27-2001, 09:33 PM   #7
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
The only reason I ask is because the plenum is very small (about the thickness of two sandwhiches.
Could someone explain, why larger intake volume would hurt air flow? To me, at present state, there just seems to be not enought air, or rather a blockage of air.
hmm...
effects of large/small intake plenum bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-03-2004 08:59 PM
Advantages of increasing wheel size ? G.Subramaniam Tire & Wheel 11 07-01-2004 01:46 PM
Jorge's Daily hash: Intakes, Plenums, and Power RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 03-31-2003 05:58 PM
Poor Idle, CEL on, oil in intake plenum maxheadroom Normally Aspirated Powertrain 2 02-14-2003 11:52 PM
That old "vacuum hose on the intake plenum" myth... 8Complex Technical Forum Archive 5 07-08-2000 10:20 AM
