Old 06-27-2001, 03:37 AM   #1
gotawd11
Member#: 5045
01 2.5 rs
black
Smile Help: Sti Engine Swap
im in the process of aquiring a jdm sti engine. i wanted to ask al those who have completed this swap what type of parts and changes i will have to make to get this engine in to my rs. all information will be appreciated.
sorry for the yelling before, just wanted to get your attendion.
gotawd11 is offline   Reply With Quote
Old 06-27-2001, 04:07 AM   #2
nqwan
Member#: 2916
02 duburu arr exu
next time try not using the caps, theres no need to yell at ppl
i dont kno much about the swap but i do kno that most of the trouble is with the wiring harness...
nqwan is offline   Reply With Quote
Old 06-27-2001, 04:16 AM   #3
KK
Member#: 564
2001 Evo 7
Here we go again...
First of all, make sure you have enuf $$$ to go though the swap,
cause there will be lots of thing that u'll def need for the swap...
i mean ALOT!! from all harness to cross member, wiring digram for both current MY and the MY of the STI that going into ur car.
there is no way i can remember all the stuff, but these are the must...
Engine with workable turbo and intercooler
Tranny (gearbox,flywheel,clutch disc and housing)
4 or more WRX Shafts
Wrx rear diff
WRX axle
WRX fuel pump (I have a Supra TT Pump, higher flow for future tunning)
Radiator
correct Ecu and all harness
all vacum hose and piping
WRX cross member
WRX engine coolant reservoir
New timming and engine belt
New spark plugs
STI engine and tranny mounts (option)
Aftermarket brakes and heavy duty brakes line
...and lots of bit and piece and time!
contact me if needed
[email protected]
Gord
KK is offline   Reply With Quote
Old 06-27-2001, 12:33 PM   #4
jeffg
Member#: 2958
2001 6.0?RS
Add to the above list
Clutch master cylinder
Doubt the stock STi ECU will work on its own, you will need either a stand alone ECU or some major piggyback parts.
Time
That should be about it. Have you ever done an engine swap before? This is way harder than the Honda swaps. Make sure that you budget about 10-15% in addition to the parts above for the gaskets that will be bad, the hoses that will be missing, bolts, brackets, the normal little things.
Jeff
jeffg is offline   Reply With Quote
Old 06-27-2001, 04:45 PM   #5
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
As JeffG mention, make sure you have enough funds and that you make sure what the Engine comes with and its condition.
But you don't need a new clutch master cylinder. You will need a new slave cylinder that fits on the JDM gearbox that will use a pull type clutch, that is, of course, if you swap the gearbox as well.
The swap is by no means easy. If you go all hog, and use JDM parts like the power steering cooling pipe, you'll have some custom pipe welding to do.
I did the engine swap on my car by myself. Took much longer than if some people had been around to help me, but it was doable.
The only problem I had swapping the engine, was self-inflicted!
If you look at the picture, the engine was hoisted facing the wrong way (car's in the background) and I couldn't bring it down easily because I had the new exhaust header installed! Took some fancy footwork to unhook it and spin it around.
scooby5 is offline   Reply With Quote
Old 06-27-2001, 05:17 PM   #6
jeffg
Member#: 2958
2001 6.0?RS
would it be easier to swap the clutch master or the clutch slave to a differnent type? I am curious about this one.
Jeff
Old 06-27-2001, 08:51 PM   #7
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
Jeff,
I find it much easier just to swap the slave cylinder that bolts onto the gearbox.
The master cylinder involves going through the firewall.
In any case, as soon as you change the gearbox to a STi type with the pull type clutch, you need to change to the proper slave cylinder.
I've got installation pics of the new slave cylinder with the OE master cylinder if you're interested.
Old 06-28-2001, 01:13 AM   #8
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I seem to have found the solution to your problem. Push this:
garface is offline   Reply With Quote
Old 06-28-2001, 01:58 AM   #9
gotawd11
Member#: 5045
01 2.5 rs
black
hey guys. thanks for teh good info so far. but what types of cars did you guys swap this engine into? will it be easier for a newer car? and the big question is was it worth it?
Old 06-28-2001, 03:11 AM   #10
Maximum
Member#: 2342
Scooby5, what kind of headers did you use?
Maximum is offline   Reply With Quote
Old 06-28-2001, 04:27 AM   #11
KK
Member#: 564
2001 Evo 7
Scooby5 which car u did for the engine swap??Cause there isn't many Swap WRX in Toronto....especially an STI For what i know..
Old 06-28-2001, 06:46 AM   #12
SL1200MK4
Member#: 7857
Question Is that your car?
KK, and Scooby5... I saw an yellow 2.5 RX with STi engine swap recently. Is that your car or does anyone of you know anything about it?
SL1200MK4 is offline   Reply With Quote
Old 06-28-2001, 09:11 AM   #13
nikkicalves
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
2000 Impreza
Tanned - BRP
The name of the place is calle Promax in toronto. I have seen the car, very nice runs beatifully. Everything looks to be in order and I am also looking into this for the future. STi rules and you can't beat the reliability.
Nick.
nikkicalves is offline   Reply With Quote
Old 06-28-2001, 10:31 AM   #14
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
KK,
I used a MY99 RS silverthorne as a base to do the swap. I did a complete JDM driveline (engine + gearbox + suspension + brakes) / interior / exterior swap, which takes quite a bit longer than a 'simple' engine swap. The car's been in my garage for a while now, so that would explain why you haven't seen it around Toronto. I've been fitting an Apex-i GT spec front mount intercooler to it, which is almost complete. I have to put the front end back on. You guys are welcome to drop by and peek at it while it's stranded
I found it easier to do the complete swap into a newer car since we have winters here, and it'd be a bit more messy to strip an older model that's been in the road salt. Otherwise, I don't think it matters much which MY you start from. Though doing it off a non-RS with a mechanical clutch mechanism (instead of hydraulic) would mean a bit more work. The car's not my daily driver, so I don't mind taking the time to do it right, which means I'm pretty anal about the swap and used JDM components just about everywhere.
Maximum,
The headers on the engine are MRT tuned length exhaust headers. A bit on the pricey side, but the workmanship is impeccable.
I also put the MRT 3" stainless steel sport exhaust system with SS tip.
This Fall, I plan on doing a front/rear Quaife ATB uprgade, and then I'll see if I have any money left
Old 06-28-2001, 11:44 AM   #15
Maximum
Member#: 2342
Scooby5:
Whoa! You're really going all out. This thing is going to be a monster. We'll have to go cruising sometime!
KK:
I'm using a 1995 brighton, which I think is an appropriate car. It was cheap as hell (1500 USD), and is in pretty good shape all things considered (no accidents, and surprizingly no rust). However, I am doing a complete drivetrain swap, I mean everything. So unless you're going to go that route, an older model might not have the parts you'll need.
Old 06-28-2001, 01:31 PM   #16
KK
Member#: 564
2001 Evo 7
The yellow STI belongs to owner of Promax..
I am using a MY99 Rally blue for the swap...Complete JDM Switchover..
Running 1.1 Bar boost at 6200 rpm
0-60 under 5 sec
1/4 mile on street tires 13.04
All those number are record from my Apex Rev speed meter
Here's some of my mods:
WRX verIII engine , tranny and ECU
Supra TT fuel pump
Skyline GTR33 rad
complete custom 3"dwn pipe,custom 3" Apex N1 cat back, with 3" hi-flo cat
Subaru 4 piston brake
Blitz BOV
Blitz Dual SBC ID boost controller (Not installed)
Blitz ID meter Boost and oil pressure
HKS intake
17" P1 with 215/45/17 Dunlop W10
Pic will be here soon
Old 06-28-2001, 01:52 PM   #17
Maximum
Member#: 2342
Nice!
Old 06-28-2001, 09:59 PM   #18
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Nice , looks like a V3 or 4 . Do yourself the favour and get some header wrap on the up-pipe to the turbo. There is quite alot of heat that comes off that pipe . I have had a few valve cover gasket leaks on the right side of the engine because of the excessive heat.
Make sure your final drives in the front tranny and the rear diff are the same.
Looks like a lightened flywheel too . Cool . I had one buy I went back to the stock. It was a little unstreetable with the chattering and I also felt I lost a little torque in the mid-range.
Good luck.
Ver.III is offline   Reply With Quote
Old 06-28-2001, 10:30 PM   #19
Maximum
Member#: 2342
Hey Rich, what do you think about headers? Are they worth the money?
Old 06-29-2001, 12:53 AM   #20
Ver.III
Member#: 1185
I flap my gums
The headers are good . I love the sound . Just like the WRC cars ......like a Honda !!!
But its not something I would get right away. They are not cheap to buy. It may be something to consider down the road.
Old 06-30-2001, 03:54 PM   #21
gotawd11
Member#: 5045
01 2.5 rs
black
I was just wondering if you all could help me locate a reliable source for these engines as well, the person I have been talking to has had a little trouble with other buyers and I dont want the saem problems. DO you all know any companies that sell jdm subaru engines? thanks gotawd
Old 07-01-2001, 11:53 AM   #22
Ver.III
Member#: 1185
I flap my gums
Try Mike Sheilds from SPD . It may be a little pricey , but I know he is a reliable source for them.
Old 07-01-2001, 12:38 PM   #23
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
Ver III. You're right on the money.
The engine is version 4, with the intake port riding under the intake manifold, but the block is a version 3. The first batch of version 4 engines used the last remaining blocks from the previous year.
As for heatwrap, the header up-pipe is being wrapped and painted with some DEI wrap and high temp silicone paint.
Front diff / rear diff combo are from the same driveline , as is the EMCD centre diff with the thumbwheel that's hooked up to the instrument panel.
The clutch / flywheel combo is from Possum Bourne and is a 1500kg Exedy with their own lightened flywheel.
Old 07-02-2001, 02:06 AM   #24
Ver.III
Member#: 1185
I flap my gums
Cool . Hope to bump into you on the road one day !!
......gravel that is !!
STI engine swap questions RS2000 Normally Aspirated with bolt-on Forced Induction Powertrain 26 06-15-2003 09:45 PM
STi Engine Swap Scooby75 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-29-2001 09:17 PM
('93-'01) Starting research on Sti engine swap MINDGAME Impreza Forum 3 09-24-2001 01:45 PM
US STi engine swap question? garface Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-17-2001 03:49 PM
STI engine swap... MINDGAME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-20-2001 03:29 PM
