Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-06-2004, 07:50 PM   #1
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
Default Turbo banjo bolt same as brake banjo bolt?
Was putting most of my stock parts back on my car so i can drive around for a few weeks until the gruppe-s gt30r kit is released. While tightening the banjo bolt for the oil feed line the head snapped off. Hadn't even applied much pressure and it broke. I was wondering if the stock brake banjo bolt is the same exact thing and can be used here? I went to gruppe-s and mpj and neither shop had bolts in stock and the dealers around me said it would take a week to order one. This is my daily driver so if anyone know please let me know.
dan avoN7 is offline   Reply With Quote
Old 11-06-2004, 08:06 PM   #2
Russ77
Member#: 69369
according to subaruparts.com, they're different part numbers.
have you taken it to a auto parts store to see if they have something that size?
Russ77 is online now   Reply With Quote
Old 11-06-2004, 09:18 PM   #3
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
looks like you should invest in:
mexicanpizza is offline   Reply With Quote
Old 11-06-2004, 11:36 PM   #4
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
haha indeed. looks like ill just have to order one from the dealer and wait for it to come in.
Old 11-15-2004, 05:27 PM   #5
Physics Junkie
Member#: 65609
Is this bolt the same bolt that connects the metal oil line to the block? If so, get me the part # too...
Physics Junkie is offline   Reply With Quote
Old 11-15-2004, 10:25 PM   #6
Bonjo2
Member#: 56521
2002 WRX Wagon
Check a good autoparts store. Napa might have boxes of them that you can compare your broken bit to. Autozone and Pep boys wont have it.
Only other option is to measure it, and look up the part one from Earl's performance plumbing. Behrants and some of the stock car companies sell them pretty cheap $2-5 each. Pegasus racing products will probably charge your $10+.. Most racing catalogs have mechanical drawings with dimensions of each item. The oil passage appeared the same--I did not think to measure..
I ordered some Earls 10mm banjo bolts, fittings, and crush washers for stainless brake lines. I used them on the Miata front calipers, RX-7 slave cyl, and RX7 rear brake calipers. I guess I got lucky when I ordered, because they didn't ask if I needed 10mmx1.0, 1.25, or 1.5 pitch.
Summit Racing--Next Day shipping.
Bonjo2 is offline   Reply With Quote
Need a 12X1.5 banjo bolt for a SBR20G is this the same as stock? Irishman Newbies & FAQs 3 06-25-2006 12:29 PM
Stock Banjo bolt same as Stoptech Banjo bolt? mav1c Tire & Wheel 3 11-22-2004 11:15 AM
MY00 2.5 RS brake assemblies same as Legacy brakes from the same year? Mauricio Brakes, Steering & Suspension 4 06-01-2004 06:55 PM
IHI banjo bolt same as stock turbo? MAD REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-22-2003 01:41 PM
Turbo legacy transmission same as wrx? serious Transmission (AT/MT) & Driveline 5 09-18-2002 05:38 PM
