Old 11-07-2004, 06:33 PM   #1
integroid
Member#: 49222
2005 Legacy GT Wagon
Limited 5MT 580whpQ16
Default Aftermarket Wiring Harness that plugs into factory HU
Does anyone know if their is such a thing? I noticed that the Hyundai wiring harness is the actual same size and shape as the Subaru wring harness. The wiring diagram is not the same, but the physical plug is. Just wondering if anyone has found anything that will plug into the factory radio on a 02+ WRX.
integroid is offline   Reply With Quote
Old 11-07-2004, 06:57 PM   #2
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
If you know someone who has trashed their factory sub (like me ) you can use the wiring harness from that. It plugs into the factory HU and the car wiring harness plugs into the other side. I hacked into mine (figuring it was not a permanent change to the stock wiring harness) to connect up my amp and Basslink (through an LOC).
Dale
iceNine is offline   Reply With Quote
Old 11-07-2004, 10:35 PM   #3
Crump
Member#: 72305
2006 Sti
SGM
ya, it will plug right in, but the pins are not going to match up in the wiring harness. If you really wanted to use one for the radio you could, however you should use a dmm to test for power, and speaker colors.
Crump is offline   Reply With Quote
Old 11-08-2004, 12:03 AM   #4
integroid
Member#: 49222
Actually, after doing some research online, I found that Scosche makes one. I found a place that sells it for $9. Thanks for your help guys.
Old 11-09-2004, 03:03 AM   #5
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The Scosche reverse harness lacks one of the illumination wires. The stock HU won't light up correctly without this.
I've been making reverse harnesses with all 14 wires. Send me an e-mail if you're interested.
David C.
SVXdc is offline   Reply With Quote
Old 11-10-2004, 12:48 AM   #6
subimp6u08
Member#: 15440
2015 STi
I need one of these wiring harness, I had to cut my harness from the stock amp when i sold my stock one, and i'm putting different stock one again, but it would be nice if i can just get the whole new cable for the amp or something
subimp6u08 is offline   Reply With Quote
Old 11-11-2004, 03:12 AM   #7
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
By "stock amp" do you mean the stock HU (radio)? (as opposed to a subwoofer/amp)
The stock plug for the radio is part of the instrument panel wiring harness. A new one of those will cost >$100 (and require disassembling most of the dash). A replacement harness for the subwoofer is available too, price ~$75.
What I'm selling is the 14-pin plug that plugs into the stock radio (AKA, a "reverse" wiring harness). The wires are about 6" long, with pre-stripped ends. It looks like this... WRX Reverse harness
If you're interested in getting one, send me an e-mail (click on my user name at the upper-left corner of this post, then click the "send e-mail" link). See this thread on the SVX forums for testimonials from other satisfied buyers.
Old 11-12-2004, 01:11 AM   #8
gargleblaster
Member#: 11107
2015 WRX STi
Crystal White Pearl
SVXdc - you've got mail!
gargleblaster is offline   Reply With Quote
Old 11-12-2004, 02:07 AM   #9
integroid
Member#: 49222
Thanks SVXdc for the spare pins and wires. If anyone needs a harness, he is the person to talk to!
Here is a pic of my finished product. Plug and Play RCA output harness for my stock 05 WRX radio! All this so I wouldnt ahve to hack up the factory harness. Notice the green/black wire under the orange. SVXdc supplied me with the extra wire and pin for both connectors so I would retain illumination on my factory radio.
Old 11-12-2004, 03:21 AM   #10
2ndGearFling
Member#: 64466
05, STI on green
wow...thats very interesting.
2ndGearFling is offline   Reply With Quote
Old 11-12-2004, 09:42 AM   #11
Daboro's Rex
Member#: 55915
04 WRX stage 1/2
Wr blue pearl
Not flaming bro but thats a no no, you shouldnt use twist caps or use crimp caps.
Daboro's Rex is offline   Reply With Quote
Old 11-12-2004, 03:07 PM   #12
integroid
Member#: 49222
Says who? I have been installing car stereos for over 15 years and I couldn't tell you an isntaller that used a soldering iron on an everday basis. Hell, the last time I used a sodlering iron was when I was modifying my ecu board in my Honda a few years ago. I agree on the twist caps but crimp connections? Are you serious? Go to any car stereo shop and let me know if you see anyone soldering any of the connections. I can promise you that they will all be using crimp connectors and have a big bin filled with all sizes of crimp connectors and crimp caps.
Old 11-18-2004, 02:39 AM   #13
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
You're welcome. Glad I could help.
Originally Posted by Daboro's Rex
... you shouldnt use twist caps or use crimp caps.
Crimps will certainly work, but I prefer to solder -- makes for much smaller junctions. Like this...
For more pictures and tips, see section 2.5.4 of my SVX Audio Install instructions (scroll down to steps 10 and 11, and click on the thumbnails for larger pics).
It helps in the SVX, where there's very little space behind the radio. BTW, where did you find space to cram that LOC in the WRX?!
Old 11-18-2004, 11:29 AM   #14
integroid
Member#: 49222
I certainly agree but I dont have the time to solder every wire. My wife was already yelling at me to help with the baby so crimp connectors it was.
LOL, that thing is a boat anchor. I shoved it above the radio between a metal beam and the top of the dash. It was actually pretty easy and fit fine. I put some foam insulation tape on both sides so it wouldnt rattle.
Old 11-18-2004, 08:44 PM   #15
iceNine
Member#: 12170
2002 WRX Sedan
I always use crimp-on bullet connectors. I like to be able to disconnect them whenever I want if I put in new gear or want to put it in another car (or realize that I've connected up the wrong wires by accident ).
Dale
Old 04-14-2007, 01:33 AM   #16
tim.medina
Member#: 122209
Default Ipod connector
David C.
I have an '05 WRX wagon and want to connect my ipod to the stock stereo. I read in your post above that you are selling harnessess to make this work. Is that correct? If so i would like to buy one.
Thanks, Tim
tim.medina is offline   Reply With Quote
Old 04-14-2007, 02:34 AM   #17
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
I do sell the 14-pin harnesses, which allow you to access the power and speaker wires. People typically use these to add an amp or a subwoofer. See my "homepage" for more info (click on my username to see link).
Unfortunately, my harnesses won't enable you to create an aux input for you iPod. The easiest way to do that on the '05 radios is with a hack that you can install inside. See this thread: Subaru Radio Aux-in
Old 04-14-2007, 09:07 AM   #18
snowcrazy
Member#: 144220
excuse my ignorance, but is this reverse harness so you can have an aux input on a stock cd player or so you can power an aftermarket amp/sub with the stock cd player. I want to power an aftermarket amp/sub with stock cd changer, do I just need a oem amp/sub harness? Please clarify for me. Thanks
snowcrazy is offline   Reply With Quote
Old 04-14-2007, 10:15 AM   #19
hector
Scooby Scammer- Do Not Buy From User
Member#: 132902
2006 wrx tr silver
99 BMW 323is
Just as a future reference Metra makes a reverse harness for just about every harness they make. Usually it just has different prefix check with metra online.
hector is offline   Reply With Quote
Old 04-14-2007, 10:34 AM   #20
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
so what do you use when you do alarms and remote starts? scotch locks?
thedaddyb is offline   Reply With Quote
Old 04-14-2007, 10:44 AM   #21
hector
Member#: 132902
2006 wrx tr silver
99 BMW 323is
The shop I work at uses T Taps and crimp connectors on everything. Reason being that the average customer will be back in less than 2 years to have there stuff uninstalled and reinstalled in a new car and its just easier. In the last 6 years I have seen one t tap failure and it was because the installer used a red t tap on like 20 ga honda lock wires and it wasnt really a solid connection and it int. didnt work. On my vehicle I solder things just becasue I know I will have it for a while but in a biz where time is money solder just doesnt make sense.
Old 04-14-2007, 12:22 PM   #22
Eluder
Member#: 128706
2016 WRX Sport tech
World Rally Blue
I got my new deck installed just a couple of days ago... the installer actually used the Hyundai harness and just connected each wire to the appropriate wire of the Pioneer harness, plugged one end into the deck, the other into the factory harness, and all is well. It looked like he went colour for colour, but I wasn't paying attention, it's not the first time he's installed a deck into a scooby, so I had confidence in him.
Eluder is offline   Reply With Quote
Old 04-14-2007, 02:52 PM   #23
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Most people use a reverse harness to drive an external amp or sub from the stock radio/cassette/CD (head unit). You can also use this harness to transplant a Subaru HU into another car.
The reverse harness plugs into the stock HU, and provides the power and speaker connections. It looks just like the end of the car's factory radio harness...
(click for larger image)
A "forward" harness is what you normally use to install an aftermarket HU in place of your stock HU. This plug looks like the connector that's on the back of the stock HU...
Subaru stock HUs don't have line-level outputs. So to connect an external amp (for either speakers or a subwoofer), your only choice is to tie into the speaker outputs.
The clean way to do that is to combine a reverse harness along with a "forward" harness (as Integroid did -- see pictures in post #9). Basically you make a short extension cord for the stock HU, so it still gets all 14 wires as it did before. This gives you a place -- between these two harnesses -- to connect wires to send to a Line Output Converter (LOC) or directly to an external amplifier that has speaker-level inputs. This way you can avoid having to cut or splice into the factory wires.
If you ever want to change anything later, you can easily unplug the new wiring and make any mods, or replace it. You can also go back to the stock installation with no evidence -- great if the car is leased.
Just make sure that both harnesses have all 14 wires. See my pin-out table for info on ones that do.
Old 04-14-2007, 02:53 PM   #24
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Metra doesn't make a reverse harness for 93-up Subarus.
As I said above, the Scosche reverse harness lacks one of the illumination wires. The illumination on the stock HU won't work without this.
The whole point of a reverse harness is to use with a factory radio, so I don't know why Scosche continues making theirs with only 13 of the 14 wires.
[Update:] Metra now does have a reverse harness. You still need to verify that it has all 14 wires. I keep looking periodically, and to date "forward" harnesses from Metra, Scosche, and all the other big harness manufacturers still have only 13 wires.
Old 04-17-2013, 12:42 PM   #25
jcardisco
Member#: 353744
Default The new HU turns off when my headlights are on
Last night I installed the HU receiver above but this morning when I turned my headlights on the screen goes blue and the radio volumes goes to near zero. I then cannot increase the volume nor control the receiver in any way (just a blue screen). I wonder if you can help out. I used the appropriate harness, but if I leave off the orange wire (backup camera) would that solve the issue? I don't have a backup camera but the blue screen that comes on when the headlights show says something about the AV input or the backup camera.
Also I connected the pink (parking brake) wire to ground so the DVD player would work. Is this a grounding issue because the unit works great until the headlights come on?
How do I get the headlights not to turn the stereo off?
Please assist.
Here is what I installed:
Harness
Stereo:Stereo:
jcardisco is offline   Reply With Quote
WTB: complete wiring harness or plugs for the HID Leveling motors and leveling switch Speedoponic Private 'Wanted' Classifieds 2 06-18-2009 12:11 AM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 04:05 AM
wire harness that plugs in radio for gauges. StarDogChampion Car Audio, Video & Security 4 11-05-2002 06:37 PM
WRX Aftermarket Wiring Harness quick question Schleppy Car Audio, Video & Security 7 04-05-2002 03:20 PM
Cusco Shift Light that plugs into cigarette lighter..where to buy? Mr. Ixnay Mid Atlantic Impreza Club -- MAIC 7 10-26-2001 10:02 AM
