Old 06-27-2001, 11:10 AM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default Has anyone done valve adjustments
I recently read a post about incresing horsepower and changing the curve by doing a simple valve readjustment. Here is the part of the other post that I was talking about. Has anyone done this with a DOHC EJ25 and experienced good gains? What needs to be done??
Thanks
Brad
"Then I spoke to him about Cams, and told him that I was thinking about the Cobb Tuning cams. He explained that sometimes, you can get as much as 10 HP, depending on the state of tune, from your car with a simple valve adjustment. That surprised me....
He can set the overlap / valve timing by modifying the valve gap. He took my car in and adjusted the valves, the first result was really dismal, no torque until 5000 then zooooom.
We got back to the shop and he drew a RPM vs Power graph and asked where I needed more. After we finished the graph, he took the car back into the garage, adjusted the valves (cold) and when I picked it up at the end of the day, all I could say was WOW!!!
Normal acceleration until 2500 RPM, %10 (about) more torque between 2500 - 3500, and 3500 - Redline, goes like stink. Acts like a VTEC above 3500, tone changes, and pulls like a madman. "
MY99 2.5GT is offline   Reply With Quote
Old 06-27-2001, 04:19 PM   #2
dcoty
Member#: 3149
01 V7 GC/R32 sky
I have the cobb cams and I had my valves readjusted to cobb tuning specs (.007 intake and .009 exhaust). Anyway, are your valve adjustments similar to this, what are the specs? I felt more power increase after the valve adjustment because it needed to be adjusted after 2000klm with the cobb cams and I adjusted them at 4000klm, so there was a noticable difference. Thanks.
Dan Coty
dcoty is offline   Reply With Quote
Old 06-27-2001, 05:55 PM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
The person I quoted above had there stock cams adjusted. I was just wondering if any performance minded DOHC drivers have had this done and what power increases they found.
thanks
Brad
almost done changing interior lighting, has anyone done the power window switch? Tobey Electrical & Lighting 24 08-25-2004 04:11 PM
Has anyone done a ej20t transplant before? ac_gohan Bay Area Impreza Club Forum -- BAIC 0 05-22-2001 02:01 PM
HAS ANYONE DONE THIS YET, FOR A SHORT SHIFTER bruno Normally Aspirated Powertrain 1 03-03-2001 11:33 AM
has anyone done Bankheists or Reiflexs blue light mods??? joostin420 Interior & Exterior Modification 21 12-01-2000 05:27 PM
Flat 4 meet...has anyone done this?!? kevinsUBARU New England Impreza Club Forum -- NESIC 5 09-24-2000 05:38 PM
